New 2018 Tacoma - Need fog light recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redline870, Oct 8, 2018.
  1. Oct 8, 2018 at 9:19 PM
    Redline870
    Redline870 [OP] Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    Hi everyone, just bought my first ever brand new vehicle, first ever Toyota, and I couldn’t be happier. Got a Cement 2018 Tacoma TRD Off-Road premium package with an automatic transmission (I really wanted a manual but wanted crawl control more). I absolutely love this truck, I have zero buyers remorse. I live in NY so I had it Ziebart undercoated it and do their full rust prevention treatment on it. I’m prepared to keep this truck forever! Sorry for the long winded intro, just a proud new owner here.
    The only thing I don’t like about this truck is the dated look of the incandescent/halogen lighting for a brand new $40k vehicle (especially with LED DRL’s!) and the low beams leave a lot to be desired. The first think I did was change out all the interior lights and reverse lights with LED’s. I then replaced the low beams and fog lights with Hikari H11 6000k LED bulbs from Amazon. I immediately removed and returned the Hikari bulbs, they were junk, looked too blue, and didn’t improve lighting at all. I ordered a Diode Dynamics H11 HID kit with their heavy duty relay harness. It should be here tomorrow and I’m hopeful it will give me the improvement I’m looking for in the low beam output. I ordered 5000k because I want a factory look that will match the LED DRL’s as closely as possible. Now finally to my question: I would like to have yellow fog lights to help cut through the fog when needed. I heard an anecdotal story about someone melting their fog light housing using HID’s. Does anyone have any recommendations for either halogen or LED H11 replacements that will give me a good yellowish color? Thanks for the help!
  2. Oct 8, 2018 at 9:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome! Do not put drop in HIDs or LEDs I to halogen reflectors, it will cause significant glare.
    Check out this thread:
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
    LED options for amber fogs:
    -KC Amber SAE G4s
    -Soon to be released Rigid amber SAE pods
    -Soon to be released amber Morimoto SAE fogs
    There are also a variety of yellow/amber halogen options, such as Nokya Hyper yellow H11s.
    https://www.amazon.com/dp/B0064FXRWI/ref=cm_sw_r_cp_api_f5cVBbV8KBD3G
    eurowner and Ensemble88 like this.
  3. Oct 8, 2018 at 9:33 PM
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    I vote for Rigid SAE pods with amber covers but thats $$$. If you just want yellow on the cheap, you can either buy yellow bulbs or get some yellow lamin-x film.
    TacoMedic214 likes this.
  4. Oct 8, 2018 at 9:40 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
  5. Oct 9, 2018 at 12:10 AM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    Go with the KC foglights. I have the white ones and they work ridiculously well. I think the amber kit # is 501. Literally took me 10 minutes to swap them out.
    Taylor@KC HiLiTES likes this.
  6. Oct 9, 2018 at 12:16 AM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
  7. Oct 9, 2018 at 12:19 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Only do that if you don't want to run them on the street. As documented those lights are off road only due to lack of cut off, causing massive glare to oncoming drivers. As well documented:
    Thegenerik1 likes this.
  8. Oct 9, 2018 at 9:33 AM
    Taylor@KC HiLiTES
    Taylor@KC HiLiTES Well-Known Member Vendor
    Taylor
    Arizona
    2010 DCSB TRD OR 4x4
    See build thread
    Thanks for the recommendation!
    Redline870[OP] and crashnburn80 like this.
  9. Oct 9, 2018 at 9:38 AM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
  10. Oct 9, 2018 at 11:54 AM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Another vote for KC's G4s. Stellar output.
  11. Oct 9, 2018 at 12:24 PM
    shawn3210
    shawn3210 Well-Known Member
    california
    2018 turd offroad 2wd
    stock
    rigid here
  12. Oct 9, 2018 at 1:05 PM
    Redline870
    Thanks for all the recommendations guys!
  13. Oct 9, 2018 at 1:47 PM
    An!mal!a
    An!mal!a Well-Known Member
    Southern Oregon
    2018 TRD Premium Sport & Tech Pkg DCSB 4x4 Quicksand
    OEM TRD Pro Grille 2018 OEM TRD Pro Skid Plate OEM Aluminum Cast Running Boards OEM Black Badge Overlay Kit OEM Black Exhaust Tip OEM TRD Pro Center Caps OEM Bed Mat Tyger Auto Hitch Armor GENK45AMB5 Homelink5 Mirror Lund Genesis Elite Tonneau Cover KC Hilites 501 Amber Fog Lights deAutoLED Interior Lighting Kit JDM ASTAR Reverse Lights
    I just ordered the KC G4 fogs from Amazon. How did you access the factory fogs? Is it through the front fender liner? I’ve been searching for a step by step guide but all I’ve seen are the ones on how to replace fog bulbs (not the whole fog pod).
    Thanks!
  14. Oct 9, 2018 at 1:48 PM
    Takeouttundra61
    Takeouttundra61 New Member
    Wyatt
    2017 White Tacoma TRD Pro
    2 Inch lift 33 Inch BFGoodrich KO2 Tires
    I vote rigid as well
  15. Oct 9, 2018 at 2:04 PM
    MCDavis
    RIC, VA
    Open hood. Went down through the top. Somewhat of a long reach but completely doable. Done it twice now.
    An!mal!a[QUOTED] likes this.
  16. Oct 9, 2018 at 2:10 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Hmmmm maybe I'll have to make a video documenting this installation process. It is super simple though. You can go from the top as mentioned, but you can also go in from underneath - it sometimes helps to get the plastic fender apron out of the way. Pretty much just unplug to factory lights, find the best way to get your arm in and remove the stock fasteners, pull the light out, pop the G4s in, and refasten and plug it back in. If you need help during this process, feel free to call us!
  17. Oct 9, 2018 at 2:12 PM
    ChainsawCharlie
    ChainsawCharlie Well-Known Member
    Sean
    New Hamster
    2017 TRD OR DCSB Quicksand
    3 Cans of Plasti Dip, Rain-X 2 in 1 all season wiper fluid, "SAWDUST IS MAN GLITTER" sticker, Mobtown rear bumper, Pioneer AVH 2440NEX
    I vote Rigid as well. Hell, around town I don't even use my low beams.
  18. Oct 9, 2018 at 2:55 PM
    squarenone
    SoCal
    blqchclt and godwinaustin like this.
  19. Oct 9, 2018 at 3:42 PM
    Citizen Rob
    Sacramento, CA
    Pop open the hood and look down below the headlights. You can see where the fog lights are and the harness connected to them. Get a medium sized #2 Phillips and take the screw out of the ear on the side of the fog light. Don't drop the screw. I only had one screw on each light holding them in place. Once the screw is out, slide the light towards the side of the vehicle and it comes right out. Unplug the harness and pull the light out. Pay attention to the location and length of the tabs and find the replacement light that has tabs in the same positions. Make sure the wee little KC logo is facing the right way. Fit the longer tabs on the replacement light into the pockets and make sure that the light is centered in the opening. Use the screw (You didn't lose it did you?) to fasten the light to the front bumper. Plug in the jumper harness and with a little bit of luck, the lights will illuminate. If it does not but the OEM on the opposite side does, then you need to swap the pins in the Deutsch connector on the jumper harness. Thats another whole 2 minutes, maybe ten if you need to find a little screwdriver buried in the bottom of some random pocket of your tool bag. Pull the green plastic piece straight out, gently jam that little screwdriver down in there and wiggle the wires on the back side of the plug. One will come loose and then the other. Turn the plug over and gently jam them in till they click. Reinstall the green plastic piece until it locks, push the silicon seal in until it sits below the cap. Pick up all of the tools that you dumped out of your tool bag.
  20. Oct 9, 2018 at 3:53 PM
    quadcrazy
    quadcrazy Well-Known Member
