New 2020 TRD OFFROAD 4x4 - Build Suggestions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mrthomasjackson, Nov 1, 2019.
  1. Nov 3, 2019 at 2:39 AM
    #41
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Lol... Do whatever you like!
  2. Nov 3, 2019 at 7:47 AM
    #42
    Recondite
    Recondite Well-Known Member
    NCWA
    2018 MGM DCLB TRD OR
    According to TW overlanding and cross country road trips. and "head-turning" mods are synonymous. If you're talking the original idea of overlanding, you're stock truck will do 90% of that. TWs idea of overlanding is a hybrid where you rock crawl to the midway point of the Rubicon flex your long travel on a 4 ft rock and pitch your RTT overlooking with a view overlooking the Mediterranean.
    In all seriousness though, your stock truck is more than enough to do most overlanding, but if you want it to be a bit more capable a small lift and a bump in tires and maybe some sort of traction like MaxTraxx. Be careful how deep down the "overlanding" rabbit hole you go. I was contemplating this weekend the amount of $$$ I've spent to "overland" and how I have limited the use of my truck in some regards. The more shit you add to your truck, the more mods you will need to get it back to it's original capability to some degree for example: adding aftermarket bumpers and winch for better "overlanding" and tire clearance is going to add weight, which translates to loss of power, which equals mods like gears, etc.
    AKGSD likes this.
  3. Nov 3, 2019 at 8:15 AM
    #43
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    ^^^ Its always a compromise when you start modifying a factory engineered vehicle. I experienced this first hand many years ago when I was into the vintage air cooled VW scene. Lower the front end? You get a rougher ride and watch out for speed bumps. Install a narrowed beam? The turning radius and handling is now compromised. Add HP to the engine? Now the transaxle and clutch needs to be beefed up and the drum brakes are inadequate. It never ends. The large team of factory engineers know best, aftermarket engineering and R&D doesn’t even come close.
  4. Nov 6, 2019 at 11:25 AM
    #44
    Undertow
    Undertow Well-Known Member
    CT
    2020 Cement DC OR 6MT
    Stock
    You get that with DRL on only. You can turn that setting off. Its also foolish not to spring the $485 for the LED light package - the output and color is great.
