New 2021 Tacoma 4x4 OV Tune Software Not Working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CowrockMtn, Feb 4, 2021.
  1. Feb 4, 2021 at 6:39 AM
    CowrockMtn
    CowrockMtn [OP] Member
    Paul
    Tacoma Off-road 2021
    Black Cat Exhaust
    Hey Tacoma World
    I need some help with OVTune for my 2021 Off-road V6 3.0l Tacoma.
    First I asked for the 93 tune but seems OV Tune does not offer anything but Stock Tunes now
    Is that 87, 91, or 93? Presume it's 87.
    Second, I cannot get the flash to complete successfully, the software goes through the steps and ends abruptly and says "Complete Unsuccessful" Any suggestions?
    Thanks in advance.
  2. Feb 4, 2021 at 6:59 AM
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    Is your truck turned on 2 clicks?
  3. Feb 4, 2021 at 7:12 AM
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
    2 things. I find it helpful to first press Identify just to make sure that it's reading the ECU version that is a sanity check to make sure the truck is set to Ignition On.
    It sounds like you may not have received the tune pack yet. Check your spam folder if you think you should have by now.
  4. Feb 4, 2021 at 7:16 AM
    CowrockMtn
    Paul
    Black Cat Exhaust
    I have the Stock Tune in my folders and open it when prompted. Yes, I have the push start button and use the two push to turn the power on without starting the engine.
  5. Feb 4, 2021 at 7:38 AM
    cemented
    Cole
    Portland, OR
    Is your anti virus software turned off?
  6. Feb 4, 2021 at 7:42 AM
    dave5623
    2020 TRD Pro
    So all that will do is revert your ECU back it's stock settings. The Tune Pack is provided to you in a separate download.
    xxTacocaTxx likes this.
  7. Feb 4, 2021 at 7:51 AM
    CowrockMtn
    Paul
    Black Cat Exhaust
    Yes the Antivirus is turned off.
  8. Feb 4, 2021 at 8:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You might want to blur you name and System ID?
    The Stock tune is Octane Learning, just like you Taco is now. Also, all 2.0 Tunes are OL also.
  9. Feb 4, 2021 at 10:11 AM
    CowrockMtn
    Paul
    Black Cat Exhaust
    Thank you. Removed.
    tonered likes this.
  10. Feb 4, 2021 at 10:17 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
  11. Feb 4, 2021 at 12:44 PM
    CowrockMtn
    Paul
    Black Cat Exhaust
    Mystery solved. Matt sent me the wrong file. He sent 04C30 for a MT and not 04C20 for an AT whch is the transmission I have. No wonder the flash would not work. Asked him to send the correct file.
    whatstcp and tonered like this.
  12. Feb 4, 2021 at 12:49 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very cool.
    Don't say 04C30 too loud. There's a few folks looking for that TP. :D
    @MNTTRD @wingsformyway
    whatstcp likes this.
  13. Feb 4, 2021 at 2:09 PM
    CowrockMtn
    Paul
    Black Cat Exhaust
    unfortunately they want more money for the correct file? Nightmare on elm street.
  14. Feb 4, 2021 at 2:16 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  15. Feb 4, 2021 at 2:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    PM sent.
  16. Feb 4, 2021 at 2:21 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Subbed... Hoping to hear more about the availability of the Tunes for '21 Manuals.
    Would appreciate input for those familiar with this... I'm not well versed on this tech!
  17. Feb 4, 2021 at 2:22 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    What aspects you want input on? In all honesty, there isn't much difference between any of the 3rd Gen model years on the driveline side.
  18. Feb 4, 2021 at 2:29 PM
    OZ TRD
    Central Coast CA
    Well, really I need a OVTUne MT 101...
    1.- So I could get a tune now for the '21 manual?
    2.- I understand there are a variety of tunes for every occasion - how does one choose a specific tune among the many? (if this is in fact the case). I would seek to be tuned by someone with the software. I would have no inclination to explore building my own... so I would not buy the whole software...
    3.- I understand that there are not many differences in the driveline - does one need a specific tune for a model year / vehicle OEM ECU program?, or are they all the same and work accross different model years?
    Sending hoping you are still on...
    tonered[QUOTED] likes this.
  19. Feb 4, 2021 at 2:34 PM
    dave5623
    2020 TRD Pro
    - Yes, I believe there tunes available for the 21 Manual.
    - The tune pack will have various configurations and you pick the one that most closely aligns with your setup and desired performance. More often then not though you will want to opt for the performance based tune, SFOB, which has more throttle response and a steeper throttle curve.
    - The tune packs are tied to a specific ECU. You could have multiple ECUs per model year. It's highly suggested you update your ECU to the most up to date and order the tune pack for that ECU ID. That way you are somewhat future proof'd from someone mistakenly updating your ECU because it is outdated.
    tonered likes this.
  20. Feb 4, 2021 at 2:38 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    1: I am checking on that with the OP. It is the first time that I am hearing about a possible 2021 MT (04C30) Tune Pack in the wild.
    2: Most of the MTs folks, me included, are generally happiest on the SFOB tune. The MT performance tune. For the MTs, there is only Base and SFOB. We don't have to worry about tires sizes and gearing as those are AT shifting and speed limiter features. Most folks that offer flashing will give you time for a test drive and possibly a reflash. So, you would have time to test the tune.
    3: For whatever reason, Toyota has dropped more than one ECU calibration for each model year. Some of it might relate to TSS-P happening in 2018 and the 2020 MY refresh. But, it seems at all Tacos get the same driveline parts. For example from everything that is posted around here, the latest TSB for my 2017 (TSB-0043-20) drove very similarly to what folks are reporting for the latest 2019 / 2020 TSB-0092-20. It seems that Toyota is updating calibrations to replicate what is rolling off the line. So while the name might be different, the tunes work the same regardless.
    I also drove a late production 2020 MT (04B91) and it felt like my TSB tune.
