New 2021 Tacoma Wheel Alignment Off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jdp1219, May 5, 2021.
  1. May 5, 2021 at 4:34 AM
    jdp1219
    jdp1219 [OP] Active Member
    2021 Cement Tacoma TRD Off Road
    New TRD Off Road goes straight on city roads but veers left or right on highways. Situation is kind of weird but the brand new truck veers left when in the left lane of a highway and right when in the right lane of a highway. When I go about 70mph in the left lane, it is quite noticeable. Any ideas on whats going on? Will be checking tire pressure later today. I was thinking maybe the Northern NJ highway roads (I-95 and I-80) aren't even and that is causing the issue.
  2. May 5, 2021 at 4:38 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Bring it in and have them check the alignment, I've had a couple of trucks, one Tacoma, that had to be re aligned on warranty.
    RedWings44 likes this.
  3. May 5, 2021 at 4:40 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What are your tire pressures at? Also, generally there is a crown in the center of the roadway to help shed water.
  4. May 5, 2021 at 5:06 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Take it back to the dealer and have the alignment checked. Both of my new Tacomas required adjustment with less than 500 miles on them.
  5. May 5, 2021 at 8:43 AM
    mhornco
    mhornco Well-Known Member
    Could be alignment, could be road crown. Some roads can have more of a crown than others which can make this issue worse. No harm in getting alignment checked. My previous Tacoma was pretty far out of alignment from the factory. Alignment on new Tacoma is perfect, but depending on road you still get it to drift one way or the other on occasion
    Professor D likes this.
  6. May 5, 2021 at 8:48 AM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    Yeah most roads are pitched so water will flow off it thatd be my answer if your having no issues during regular city driving
  7. May 5, 2021 at 8:50 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Not that I have a 3rd Gen, but I just put new tires on and had an alignment done, and there is still the very light and gradual drift left or right on the highway depending on which lane I’m in, due to the road crown as others mentioned. City roads tend to be much flatter and you’re going slower, so any drift is either not there at all or difficult to notice.
    If you’re on a 3- or 4-lane highway and in one of the middle lanes, and the truck regularly drifts one way, then maybe you really have an issue. At which point the dealership ought to be able to check alignment and make any adjustments no charge. Assuming you haven’t hit some crazy deep pothole or done serious off-roading since you got the vehicle.
