New 2023 Tacoma - Undercarriage Job [DIY]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rlofthouse, Jan 24, 2024.
  1. Jan 24, 2024 at 8:14 PM
    rlofthouse
    rlofthouse [OP] Well-Known Member
    Robert
    Bay Area
    2024 Tacoma TRD OR
    Hey guys
    I just purchased a new 2023 TRD Off Road! I'm interested in doing an undercarriage job as a proactive means to prevent rust. Ive noticed a lot of folks recommend Cosmoline RP-342 on a new car. Mine is only a couple weeks old.
    Question - Why is Cosmoline recommended over Fluid film on new cars? I live in San Francisco - are there any bay area locals who can recommend this kind of care / products they used?
  2. Jan 24, 2024 at 8:37 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I came for a completely different topic... As it were... o_O
    Congrats on the new truck! :bananadance:
    I am not familiar with Cosmoline and I am not in the Bay (But I am not too far!).
    I did Woolwax because of good reviews and because of the high Lanolin content. I used it on a Land Cruiser previously. (I have also used it on sailing equipment in salty environments also and I know it works well.).
    I spend quite a bit of time in Tahoe, so I thought it was a prudent thing to do to my Taco... (Likely overkill, but I did not want to risk any ugly looking rust underneath from chemicals or reactive soil while offroad.)
    I did it right away after purchase, and because California is not a super hostile environment it has largely remained intact. The stuff does not wash off easily once it 'sets' - it does take a few days to 'dry'. (Again, this quite a benign environment for these trucks.). I have some extra cans for touch-up (Has been minimally needed so far) and I take a peek down there now and then...
    I believe I bought 8 spray cans initially. And 5-6 were enough to get good coverage. The others are the touch-up stash. I did it myself. Is it a bit messy, but not too bad. For CA, it is basically a one time hassle. Ever a direct spray with a pressure washer struggles to make a dent.
    The waxy finish does attract dust which, of course, sticks; so the underside does not look 'as new' after application, but you can tell nothing touches the coated surfaces with the waxy coating. Water just beads off.
  3. Jan 24, 2024 at 8:50 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Cosmoline and the other hardish waxes are more durable than the oils or WW but you do not want to trap the salts between it and the metal like the rubber coatings do. That is the reason for the new vehicle recondition it mostly a one and done were the soft WW and oils need to be redone yearly to keep your protection.
  4. Jan 25, 2024 at 12:34 AM
    bosco76
    bosco76 Well-Known Member
    Near A² MI
    '17 OR DC MT MGM
    I used cosmoline black on the undercarriage and cosmoline creep on all the interior panels (doors, tailgate, hood, fenders etc.) on my Taco. Its much more durable in the conditions than the oil based products. I had our new 4Runner done by New Hampshire Oil Undercoating because I ran out of time and didn't really want to deal with the mess in the driveway again. next year I'll probably have both done by NHOU.
  5. Jan 25, 2024 at 5:28 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    I fluid filmed mine. I will say that next winter I will look into a product that’s a little harder to get off. Fluid film seems to come off fairly easily. Areas that get blasted or packed with snow/salt like the lower control arms and skid shield I’ve had to touch up a few times already.
  6. Jan 25, 2024 at 5:39 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    I went with KBS Coating instead of Fluidfilm and very happy with results: https://www.kbs-coatings.com/cavity-coater.html
    Note that you should NOT buy their cheap chinese sprayer, go with the expensive Fluidfilm sprayer instead. I was able to return the junk KBS sprayer and got the FF one and now very happy with everything, doing an undercoat spray once a year.
