New 2023 TRD with slight pull/drift to the right.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Andyshine77, Oct 13, 2023.
  1. Oct 15, 2023 at 11:20 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    OP we here in the forum are tired of people complaining about the smallest issue and then saying "truck totally sucks and I totally regret my purchase."
    That's all. It's a small issue, it's covered under warranty. Toyota will take care of it. No need to catastrophize the situation.
  2. Oct 16, 2023 at 12:02 AM
    Andyshine77
    Andyshine77 [OP] Well-Known Member
    Andre
    23 OR/Lunar Rock.
    Not my intention to catastrophiz. However when people pay as much as they do now for a pickup, expectations should be high.
    bulalo likes this.
  3. Oct 16, 2023 at 12:42 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I traded my 2010 in as well for a ‘23 OR. I have back issues and the seat position was rough in my second gen as well. Some seat lifters ended up solving my issue and love it now. The dealer should be able to rotate and force balance if that doesn’t resolve it for you.
  4. Oct 16, 2023 at 1:20 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Talk to my 95k msrp 2024 bmw IX that im going through lemon law for.
    Andyshine77[QUOTED][OP] and Chew like this.
  5. Oct 16, 2023 at 3:09 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    A lot of things can cause a drift from the crown of the road (however slight) to high winds which are common this time of year. It doesn't hurt to get the alignment double checked though.
    The seating position is basically the same from the 2nd gen to the 3rd gen since they're largely the same truck. Seat jackers can help, I've heard. I don't have any issues with my seating position, but everyone's body is different. I'm 5'9" and I've heard people shorter complain while taller people were fine with it. No real rhyme or reason apart from personal preferences.
    As for your remarks about high expectations: I do agree to a degree. But "how much we pay" is often a catch-all phrase people use to justify expecting everything to be perfect and exactly how they wanted it when reality doesn't always support that notion for various reasons. It's like talking about Toyota reliability and being surprised when Toyotas have common problems of their own. While these prices are a lot, they're actually toward the lower end of the spectrum in current truck pricing across the board. Some of that will change with the 4th gen, but still. Reality is that nothing is infallible and not everything will work out exactly how everyone is expecting or (what I find to be more accurate the longer I'm on here) what they're used to.
    Sorry for the rant. I'm not dismissing your pulling to the right issue. It's still under warranty and within the break in period. Maybe see if they're willing to check the alignment for free.
    Andyshine77[OP] and Chew like this.
  6. Oct 16, 2023 at 3:18 AM
    BillyE
    BillyE Well-Known Member
    I assume you’ve checked tire pressure? Didn’t see that mentioned.
  7. Oct 16, 2023 at 10:41 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    If you can post alignment numbers , I’m sure knowledgeable members can chime in
  8. Oct 19, 2023 at 9:37 AM
    dan20225467
    dan20225467 New Member
    Dan
    2023 Lunar Rock Tacoma TRD Sport
    My 2023 TRD Sport developed a slight drift to the right after having different rims swapped out on the stock tires. Nothing major but definitely noticeable at highway speeds. Less than 600 miles on it.
    My only other gripe is having to slide into the truck with my leg out due to the limited tilt of the steering wheel.
  9. Oct 19, 2023 at 9:51 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    An alignment issue can be caused by the owner and not a manufacturing issue. Alignment can be thrown out by driving over a pot hole, rough roads, hitting a curb head on, rubbing against a curb, speed bumps and so much more. But really ? What a lot of whining.
  10. Oct 19, 2023 at 10:29 AM
    dan20225467
    Dan
    I can tell you with 100% certainty that I did none of the extremely obvious owner things you mentioned.
    It’s more likely the suspension components wearing in and will probably not be the last time I’ll go it realigned.
    Andyshine77[OP] likes this.
