New 21 TRD Off Road.. only one issue [advice]
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CRev, Sep 17, 2021.
  1. Sep 17, 2021 at 4:32 PM
    CRev
    CRev [OP] Member
    Tennessee
    ‘21 DCSB TRD OR
    Hey everyone,
    So I wanted to see what the community could offer to my ‘issue’. This isn’t mechanical or electrical or any of that. Anyways..
    The truck is brand new, not even 1k miles yet. I cannot see a damn thing out of the windshield when it’s raining. The wipers create a huge haze over the windshield when they wipe, and it quickly fades until the next motion. At night it’s dangerous because others headlights absolutely kill any visibility you had.
    I am a bit stunned because being new, I can’t imagine the windshield, wipers, or anything related would be “wore out”. Is there something that wasn’t done prior to my taking possession? I cleaned the windshield with rain x cleaner and still the issue persists. I wiped the blades as well and cleaned where they rest. There’s just nothing on either to be causing this haze.
    I’m curious if anyone has had this issue, or knows a process to remedy it. I will add that when the window is dry it is extremely clean and not ‘slick’.
    any advice would be awesome!
  2. Sep 17, 2021 at 4:37 PM
    badhand2
    badhand2 Well-Known Member
    utah
    2021 tacoma trd off road access cab
    Try some denatured alochol on the windshield and wipers just a thought op.
    RedWings44 likes this.
  3. Sep 17, 2021 at 4:37 PM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Try cleaning your forward wind screen with alcohol.
    Replace your wiper blades. OEM wiper blades are really cheap from dealership.
    Hopefully that'll help.
  4. Sep 17, 2021 at 4:39 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Even though wiper blades are consumables, dealership ought to be willing to replace them if they’re bad after 1K. Worth an ask.
  5. Sep 17, 2021 at 4:41 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    If you are sure the windshield is good and clean (I like the Stoner Invisible Glass wipes) try changing the wiper blades.
    Although they are "new" they might have been contaminated somehow along the way, personally I feel the quality of most all wiper blades has gone downhill over the years, seems like a year and they are done. I usually buy the Trico brand ones.
    Lt. Dangle, Slashaar and shakerhood like this.
  6. Sep 17, 2021 at 4:56 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Mines done this a bit since new, as does some of my family’s Toyota’s. Haven’t gotten around to investigating it yet. I have replaced my wiper inserts once due to ripping. The Toyota wiper blades are good quality and work well in the winter, I dont think they are the cause. I had this similar issue when I used RAINX washer fluid in my old 4Runner and have never purchased it since. I wash the truck routinely and clean windshield with Windex. I think it’s some sort of mineral deposits on the glass itself.
  7. Sep 17, 2021 at 5:03 PM
    CRev
    CRev [OP] Member
    Tennessee
    ‘21 DCSB TRD OR
    Thanks for everyone’s replies. I will try all the suggestions and if none seem to remedy it, I’ll replace the blades. I planned to just stick it out until it’s first oil change then mention it if I hadn’t corrected it by then. I’ve never owned a new ride, mostly 100k plus trucks and never had an issue like this with simply getting a clean windshield with my wipers
  8. Sep 17, 2021 at 5:15 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I asked the last time I went in as one of mine has a centimeter sized chunk out of it. They said no.
  9. Sep 17, 2021 at 5:17 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Rain x can get dangerous if you put too much on. A long time back I had a problem with the anti fog version for the inside. If you put too much on it had a reverse effect creating foggier windows.
    supmet and shakerhood like this.
  10. Sep 17, 2021 at 5:21 PM
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Word of advice, never let a dealership touch your vehicle.
    willtill and ernscott like this.
  11. Sep 17, 2021 at 5:22 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
  12. Sep 17, 2021 at 5:26 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't like Rain X on my windshield either, never had the desired results with it.
  13. Sep 17, 2021 at 5:34 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    This is in my option the best way to clean a windshield. You don't need the rainex because that might be some of the problem. Make sure that you use the "0000" steel wool only.
    https://www.youtube.com/watch?v=D05vX-G9iV4
  14. Sep 17, 2021 at 5:39 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    This with some good window cleaner and if you don't have any try a clay bar or a magic eraser. Then clean with some news paper and glass cleaner ammonia few, then wipe your wiper blades with a rag with some rubbing alcohol on it. This should qork.
  15. Sep 17, 2021 at 5:41 PM
    SilverSky195
    SilverSky195 Well-Known Member
    Western PA
    2019 Silver Sky TRD Off Road
    I’d clean the windshield with denatured alcohol or pure white vinegar and paper shop towels. Twice. Including the blades.
  16. Sep 17, 2021 at 8:16 PM
    ADcraftworks
    ADcraftworks Active Member
    Alex
    2022 Lunar Rock TRD Offroad
    My mom had this issue with her new mazda cx5, the windshield wiper fluid was too concentrated so we had to dilute it a bit.
  17. Sep 17, 2021 at 10:01 PM
    CRev
    CRev [OP] Member
    Tennessee
    ‘21 DCSB TRD OR
    I personally haven’t had a bad experience at all with my local dealer. I don’t bring it to them for anything other than routine maintenance that I cannot do on my own. My purchase came with 2 years free maintenance and my dealership offers a lifetime powertrain warranty under the conditions of a tire rotation every 5k, and oil change every 10k (can be sooner but no more). Still playing with that idea but it was on the table at no extra charge. Toyota of Gallatin
  18. Sep 17, 2021 at 10:20 PM
    squamishdroc
    squamishdroc Well-Known Member
    Powell Riveria
    2021 Off Road Premium in AG
    5100's and Cooper 265/75/16's
    I have had good luck with cleaning the windshield with a clay bar to remove any fall out - then I use a product called 20/10 Windsheild cleaner (in a green bottle) to get the oils off and then the alchohol on the wiper blades. Used this combo for years on the ambulance fleet I maintained with good results.
    CRev[OP] likes this.
  19. Sep 18, 2021 at 5:44 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Betting the dealer sprayed some kind of quick detailer on the whole thing, including the glass. I've heard of this happening when P&S Beadmaker and other detailing products are applied to the glass so I've avoided it. Hit it with a good solvent cleaner and swap the wipers and you should be good to go. FWIW I've had great results with the Rain-X but it's a pain to apply right. Use sparingly and keep buffing until you think you've removed it all again, otherwise it'll leave swirls and haze like crazy.
  20. Sep 18, 2021 at 3:27 PM
    WiFiDoctor
    WiFiDoctor Well-Known Member
    2021 TRD Pro
    That dealer (Toyota of Gallatin) used to be the worst dealer in all of the southeast when it was owned by Ron hibbard. They finally bought him out and fired all the staff responsible for the nightmares that went on there. (I know, it happened to me) I have been back since the new owners have taken over and it was a night and day difference. They know they have a long way to go repair years of damage to the local customer base.
    I would not be afraid to bring the truck to the service department for the wiper issue. I am also from the Gallatin area.
    CRev[QUOTED][OP] likes this.
