*NEW* 2ndGen 3D Printed Parts- Keyfob Combo, Accessory Mount, Gang Switch mount and more
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Radioactiv, Feb 10, 2025.
  1. Feb 10, 2025 at 9:15 AM
    Radioactiv
    Radioactiv [OP] Well-Known Member
    Georgia
    2015 DCLB 4X4
    NEW 2nd Gen Keyfob, Tacoma Accessory Mount & Gang Switch Mount!
    ETSY Store Link (Use code :TACOWORLD for 5% Off)
    Hey everyone! I wanted to share a couple of new products I’ve designed for 2nd Gen Tacomas (2005-2015) that make mounting accessories clean and easy. All truck products are printed with PETG material unless stated or requested otherwise.
    Tacoma & Tundra Keyfobs 2005-2015
    I designed a custom key fob case that combines your key and fob into a single, compact unit—no more bulky pockets or loose keychains. It's 3D printed from durable PETG, reinforced with a stainless insert for the keyring, and secured with heatset inserts and screws for a solid fit.
    No reprogramming or key cutting required—just transfer your existing key and electronics.
    Easy install: Trim off the outer rubber on your key, insert it into the case, drop in the fob buttons, and secure everything with four screws.
    Fits 2005-2015 Tacoma & 2007-2017 Tundra factory key fobs.
    Accessory Mount 05-15 (Above AC Controls)
    $39.99
    • Holds up to 5 RAM balls with 1/4-20 threads
    • Built-in knife/flashlight slot & clip-in radio holder
    • Strong, lightweight design – built to last!
    • Keeps your dash organized and functional
    • Can be installed with adhesive or screws
    Voswitch 12-15 Gang Switch Mount (Auxbeam 95% done)
    $49.99
    • Clean, factory-style switch panel
    • Perfect for adding auxiliary lighting, lockers, or accessories
    • Easy pop-in install, only drill for wire to pass though.
    • Designed for a perfect fit in your 2.5Gen
    I designed these to solve the common problem of finding a solid place to mount accessories.
    Check them out here: https://lowriseprecision.etsy.com
    Let me know if you have any questions! Always happy to help fellow Tacoma owners get their setups dialed in.
    More to Come!
    I’m also working on some new Tacoma accessories:
    ➡️ Auxbeam 12-15 Gang Switch Mount (these are done, just need to check final fitment)
    ➡️ Ultra Bright Puddle Light Mounts
    ➡️ 05-11 Gang Switch Mounts (Voswitch & Auxbeam)
    Got an idea for something that’s not on the market? Let me know! I’m always looking for new products to design that solve real problems.
  2. Feb 10, 2025 at 12:54 PM
    InfernoTRDPro
    InfernoTRDPro Well-Known Member
    Charlotte, NC
    2015 TRD Pro 4x4
    "OEM+"
    Nice work! If I think of something to 3D print i'll definitely let you know!
    Also if you need any custom decals for your business I can help you out too :hattip:
    Radioactiv[OP] likes this.
  3. Feb 10, 2025 at 4:42 PM
    Radioactiv
    Georgia
    2015 DCLB 4X4
    Some of that stuff you're making is sick! Will forsure hit you up when the time comes!
    InfernoTRDPro[QUOTED] likes this.
  4. Feb 10, 2025 at 5:00 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    You should design a single key/fob all in 1 for the 2nd gen tacoma. been wanting an all in 1 for years now
    InfernoTRDPro and Radioactiv[OP] like this.
  5. Feb 10, 2025 at 5:06 PM
    Radioactiv
    Georgia
    2015 DCLB 4X4
    Basically holds the key and the fob? Probably doable but I could see it getting bulky.
  6. Feb 11, 2025 at 7:01 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    What about an angled mount for the Diode Dynamics Rock lights for a prinsu rack or roof rack.
  7. Feb 11, 2025 at 7:07 AM
    TRD2010SpeedwayBlue
    Brandon
    yeah exactly!!.
  8. Feb 11, 2025 at 7:44 AM
    Radioactiv
    Georgia
    2015 DCLB 4X4
  9. Feb 12, 2025 at 6:23 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I have an idea, but havent had much luck finding a solution. Maybe you can help?
    I have a backseat molle panel (can get the molle dimensions later) and Im looking for a twist in hook. Like something that i can attach to.
    In addition to that, i am looking for one of those heat set threads that i can attach to the molle panel. Basically wanting to attach a quick fist, which uses a bolt, to my molle panel.
  10. Feb 15, 2025 at 6:10 PM
    Radioactiv
    Georgia
    2015 DCLB 4X4
    You guys think this would be too thick to be a keyfob?
    Also ordered 2 more printers this weekend. One to take over my engineering Plastics and one dedicated to prototyping
  11. Feb 16, 2025 at 5:42 PM
    TRD2010SpeedwayBlue
    Brandon
    looks good for a start!
  12. Feb 17, 2025 at 12:15 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    IDK if it would be too much trouble but a cupholder and shifter section with spot for fj shifter and insert for aux beam controller would be sweet.
  13. Feb 17, 2025 at 3:42 PM
    TegoTaco
    Ontario, Canada
  14. Feb 18, 2025 at 6:42 PM
    Radioactiv
    Georgia
    2015 DCLB 4X4
  15. Feb 25, 2025 at 5:37 AM
    Radioactiv
    Georgia
    2015 DCLB 4X4
    Getting really close to the keyfobs to being finished, the stainless plates should be here by next week.
    Anyone have a 05-10 key they want to send over for test fitting? I can send it back with a fob
  16. Feb 25, 2025 at 9:15 AM
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    I’d be down! Do you need the fob and key or just key? I have both
  17. Feb 25, 2025 at 9:56 AM
    Radioactiv
    Georgia
    2015 DCLB 4X4
    Just the key, basically I got to verify itll fit the same housing as the newer keys and possibly make a glue spot for the transponder, but I think i found someone about 30mins from me that will let me get ahold of theirs.
  18. Feb 25, 2025 at 10:02 AM
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    Okay well let me know, I have a spare I don’t mind sending out
  19. Feb 25, 2025 at 3:12 PM
    InfernoTRDPro
    Charlotte, NC
    2015 TRD Pro 4x4
    "OEM+"
    This is super cool looking! Too bad we cant have the flip out style key like the German cars (Audi, VW). Would be quite a bit of engineering im sure. Either way keep up the great work!
  20. Feb 28, 2025 at 6:26 AM
    Radioactiv
    Georgia
    2015 DCLB 4X4
    Well guys good news, I finally got ahold of a 05-10 key to cut up and it fits fine. The stainless middles will be here Monday, they will only be silver for now. I may could torch some color into them, but will look into Black Oxide in the future. One big change is I end up putting brass heatset inserts in the bottom of the fob, so no real worries of it stripping out or loosening overtime, a thread locker could also be added with no issues.
    First run of colors, I'm looking at black, red, blue, forest green and dark grey.
    Also excited about my new table I got this week for $150, hoping to build some under shelving for it and put my printers and shipping boxes there to save some more space.
