BUYER BEWARE: 3rd Gen Plug-N-Play Tailgate Bolt-N-Lock & Tailgate Bolt-N-Open
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KTJO 4x4, Feb 10, 2019.
Thread Status:
Not open for further replies.
  1. Feb 12, 2019 at 11:57 AM
    #61
    wessyder
    wessyder Enlightened OR Bro who don't need no skewp
    2019 Tacoma TRD OR, basically an off road race truck
    Tied several boat anchors to my truck to destroy MPG.
    Has anyone done the mod with a shell on, so run one set of wires to the cab for unlocking both the gate and the shell door (two pop lock kits)? Wondering if I can just use one wire run and control both pop n locks...
    bigmw and KTJO 4x4[OP] like this.
  2. Feb 12, 2019 at 12:32 PM
    #62
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    The PNP harness is in the left side of photo which is what she is selling. You would need to buy the kit online like Amazon. https://www.amazon.com/Pop-Lock-PL8535-Tailgate-Toyota/dp/B00LST3022
    You would essentially wire the kit per the instructions but using her harness simply plug n play into factory connection at passenger door kick panel and avoid the need to splice/tap into factory harness.
  3. Feb 12, 2019 at 12:33 PM
    #63
    KTJO 4x4
    KTJO 4x4 [OP] Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    I am sure that can be done. You just need to up the wire. Like instead off 20/22 you would want to make sure to do 18 all the way around I would assume. That’s what I would do if it were me
    wessyder[QUOTED] likes this.
  4. Feb 12, 2019 at 12:39 PM
    #64
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Katie, please put me down for a full kit.
    Thanks,
    Greg
    KTJO 4x4[OP] likes this.
  5. Feb 12, 2019 at 12:39 PM
    #65
    wessyder
    Thanks, I'll have to do that. I'm not going to do it for a little while, but eventually once the snow melts around here I do plan on it! Also gotta buy a couple poplocks for each application.
    KTJO 4x4[QUOTED][OP] likes this.
  6. Feb 12, 2019 at 12:40 PM
    #66
    KTJO 4x4
    Katie
    Oregon
    The Full Kit is all you would need as it comes with the PNP Harness, the 14-15ft Wire Harness to go from the Tailgate to the Cab, and the Actuator for the Tailgate Pop-N-Lock. All you have to do is Install the Kit for $65
    r1200gs4ok likes this.
  7. Feb 12, 2019 at 12:48 PM
    #67
    BFRT_King Ranch
    BFRT_King Ranch Well-Known Member
    Northern VA
    '18 Cement TRDOR DCSB
    Put me on the list for the next batch and full kit.
  8. Feb 12, 2019 at 12:53 PM
    #68
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    I'm interested in a full kit as well. So for $65 you get everything you need to tap into that harness on the passenger side floor and you just run the wire back to the tailgate and put the pop n lock in the tailgate and hook it up and that's it?
  9. Feb 12, 2019 at 12:58 PM
    #69
    KTJO 4x4
    Katie
    Oregon
    I can do that. When it gets closer to shipping I’ll let you know about additional fees to Canada ;)
    CanadaToy[QUOTED] likes this.
  10. Feb 12, 2019 at 12:59 PM
    #70
    KTJO 4x4
    Katie
    Oregon
    You got it :thumbsup:
  11. Feb 12, 2019 at 1:10 PM
    #71
    moe2o4
    Corey
    Pittsburgh PA
    Curious where you ran the wires to the back of the truck and also did you run these wires thru the same harness as the backup camera wires?
  12. Feb 12, 2019 at 1:24 PM
    #72
    thunderstick12
    thunderstick12 New Member
    Washington
    2009 DCLB; 2018 DCLB
    Put me down for a full kit as well. Thanks for your effort. When do you want payment?
  13. Feb 12, 2019 at 1:31 PM
    #73
    Frito
    Frito Well-Known Member
    Yer all right kid ! :hattip:
  14. Feb 12, 2019 at 3:56 PM
    #74
    06toyoboy
    06toyoboy Well-Known Member
    I would like to get added to the list if there is one.
  15. Feb 12, 2019 at 4:10 PM
    #75
    KTJO 4x4
    Katie
    Oregon
    In the full kit picture, you can see the wire harness I include that comes in its own wire loom.
    I personally ran my wiring along side the drivers side next to the rest of all the othe wires that go from the front of the truck to the back. In the front, I went into the cab through the firewall. However, you have to remember when I first did mine, Wiring was fresh to me and not a lot of people were doing this mod at all. I was one of the first or there weren’t many if any writeups at that time to follow. We tapped into the Drivers side under the side door panel. I hated it, but it worked. When I first saw this, I had to do it right away. It was a no brainer. So I just untapped and ran my wiring under the carpet in front to the passenger side and connected it to the PNP Harness. If I was doing my install fresh today, I would route the wiring to the passenger side and go in through the passenger side firewall bc it is located right there by the kick panel. As for the rear of the truck, I do not have my spare tire mounted under my bed of my truck, but even when I did, I still ran my wire loom through that opening and then into the same opening that the Reverse Camera goes through in the tailgate. I ended my wire loom right there so that my wires could fit through the small opening in that black grommet and nothing would be altered. It looks clean to me and is out of the way. Hope this helps!
  16. Feb 12, 2019 at 4:17 PM
    #76
    KTJO 4x4
    Katie
    Oregon
    When I complete this current batch I will open up the next and run it like I did this one for a certain amount of time before I close it. At that time I will take all payments and then I will place the order.
    Tombiology70, Frito and moe2o4 like this.
  17. Feb 12, 2019 at 4:24 PM
    #77
    KTJO 4x4
    Katie
    Oregon
    Got it :thumbsup:
  18. Feb 12, 2019 at 4:36 PM
    #78
    moe2o4
    Corey
    Pittsburgh PA
    Sounds pretry easy! Do you need to get power or you just hook up the harness on the passenger side kick panel and run it back?
  19. Feb 12, 2019 at 4:37 PM
    #79
    ctmedic
    ctmedic Well-Known Member
    2018 TRD OR DCSB
    Seems like you’re taking names for a next batch - please put me down for a full kit. Thanks!
  20. Feb 12, 2019 at 5:51 PM
    #80
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    In for the full kit!
Thread Status:
