New 4wd Actuator Position
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RT_Guy, Aug 13, 2023.
  1. Aug 13, 2023 at 12:16 PM
    RT_Guy
    RT_Guy [OP] Active Member
    2014 Red Tacoma TRD
    Hi Folks.
    I just purchased a 2014 Tacoma 4wd.
    The truck is low mileage and is very clean. I'm having the "4wd indicator flashing" issue when I go into 4hi and 4 low.
    I was under the truck for the first time today and I found that the actuator on the transfer case had the vent tube disconnected so I'm suspecting that I've found the cause of the problem.
    I've watched the videos of the guy taking this apart and I think I have a pretty good idea how to disassemble the thing and check that the position it is set at corresponds to the position that the transfer case is actually in.
    My question is; Does anyone sell a kit with the replacement seals for the thing? it looks like there are 2 o-rings, one for the motor cover and the other where the part goes into the transfer case. Can I get them from toyota? I've looked but haven't come across anything.
    Also, if I just got a new part from Toyota, what position does it come set at or would I still have to do this with a multimeter on the limit switch terminals?
    Any help with this would be much appreciated.
    Thanks
  2. Aug 13, 2023 at 1:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No, there is no seal kit that I know of.
    You could maybe buy a cheap Dorman actuator and rob parts from it.
    But I’m of the opinion, it’s not worth it.
    You’d be better off pulling yours and inspecting it. Most are badly corroded.
    Some guys have had luck cleaning theirs, you could try it.
    If you really want see where the problem is, we have a thread for that.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/
    303tacoma and Dm93 like this.
  3. Aug 13, 2023 at 2:57 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    If you get it apart and think it's worth rebuilding, you can get measurements for the rings with an accurate caliper and order them from McMaster.
  4. Aug 13, 2023 at 3:01 PM
    RT_Guy
    2014 Red Tacoma TRD
    I may do that. I'm in Atlanta, so I'm a regular at the McMaster will call window.
    I read most of the thread in the link and much of what I think I know about doing this is from there. Any thoughts on the factory set position of the new OEM units
    Thanks
  5. Aug 13, 2023 at 3:04 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The actuator should self correct - IIRC it runs on limit switches, so after installing, turn your 4WD selector knob back and forth once or twice and you should be good to go. The position sensors for transfer case position (for the 4WD ECU/dash lights) are handled by sensors on the tcase.
  6. Aug 13, 2023 at 3:06 PM
    RT_Guy
    2014 Red Tacoma TRD
    I'll post the Mcmaster part numbers if I go this route.
    TnShooter likes this.
  7. Aug 15, 2023 at 5:32 PM
    RT_Guy
    2014 Red Tacoma TRD
    So if I got the new one, I would mount it on the transfer case without the rack gear on the shaft, turn the key on and let it take the position that the switch is commanding and then put the gear on?
    Thanks
  8. Aug 15, 2023 at 5:35 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    You shouldn't need to mount it, just plug it in - but also please treat me like I'm talking out of my ass until someone who has more experience with the job can confirm.
    Edit - here's a not terrible video.
  9. Aug 15, 2023 at 7:46 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The actuator has to be timed to the rack, the easiest thing to do probably would be to plug the new actuator in and turn the key on with the truck in 2wd and let it put itself in 2wd then make sure your Transfer case is in 2wd (rod all the way in). I'm pretty sure you can remove the little triangle tin cover and the drive gear behind it to remove the rack from the actuator and install it onto the Transfer Case and reinstall it to maintain the timing.
  10. Aug 24, 2023 at 1:42 PM
    RT_Guy
    2014 Red Tacoma TRD
    Thanks for the responses.
    Does anyone know where the vent line to this actuator terminates? Is it open to atmosphere or is it normal to build some back pressure if you blow into it where it connects to the actuator?
    Thanks
  11. Aug 24, 2023 at 1:46 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Vents to atmosphere.
    If you're running a new vent for it consider also moving the rear diff vent at the same time.
  12. Aug 24, 2023 at 2:00 PM
    RT_Guy
    2014 Red Tacoma TRD
    So, if I'm building any back pressure, its blocked somewhere?
  13. Aug 24, 2023 at 2:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Pretty sure it connects to the Transfer Case on top.
  14. Aug 24, 2023 at 5:08 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I would think so. The tcase vents under the hood to a breather right next to the front diff breather (at least on the 4.0). Could be sludge in the tube, or a pinched hose/damaged breather.
