New 4X4 owner. Question about 4Hi engagement.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomoni, Nov 12, 2020.
  1. Nov 12, 2020 at 9:26 AM
    DeeKay20
    DeeKay20 Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    these transfer cases have neutral, we just don't have the option to put them in neutral. ;)
  2. Nov 12, 2020 at 9:29 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    The Crawl Control cant be used on flat pavement because it may ruin the computer FYI. You can however get on a little dirt incline and try it out before you go somewhere and get stuck trying to figure out how to use it.
    tacomoni[OP] likes this.
  3. Nov 12, 2020 at 9:32 AM
    Wixo
    Hank
    Tint, LED interior
    He's old, just ignore him.
    tacomoni[QUOTED][OP] and tonered like this.
  4. Nov 12, 2020 at 9:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am very curious how the use of CC at all could ruin the ECU? 2020 folks have been testing it over pavement curbs and lumber for a bit now trying to figure out if it is even working.
    There is no system on the Taco that can be hurt on pavement driving straight. Beyond that, OVT has at least 400mi in 4Hi on pavement testing the driveline with his TT kit.
    :cheers:
    shakerhood, hiPSI and Wixo[QUOTED] like this.
  5. Nov 12, 2020 at 9:36 AM
    Wixo
    Hank
    Tint, LED interior
    IDK but the manual said it so :evil: Actually, IDK if it was the manual or the toyota app that the dealership recommended I download that said that. It said to not try CC on a flat even surface, like pavement, because you risk damaging the computer (not sure if it meant ECU or some other computer component). :drunk:
    tonered[QUOTED] likes this.
  6. Nov 12, 2020 at 9:39 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Things kinda have to be lined up for it to engage. Sure you can be sitting still in N and engage it and if the stars are aligned it will work
    tacomoni[QUOTED][OP] likes this.
  7. Nov 12, 2020 at 9:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's an odd one. If all the wheels are moving at the same speed, I just cannot see a problem. Even if the electronic booster locked up some or all of the wheels while CC was appling a bit of throttle, it wouldn't me much different that holding your brakes at a stop? After all, it is just the ABS system on steroids.
    Of course, it might just be a legalese warning for folks who want to head down to the store with CC / MTS engaged. :santa2:
    Wixo[QUOTED] and hiPSI like this.
  8. Nov 12, 2020 at 9:41 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    @Wixo
    You have no idea about my age.
    Although, I do believe people can help themselves with a little effort. Like reading the Owner's Manual..............or looking at the placard on the bottom side of the driver's sun visor.
    hiPSI likes this.
  9. Nov 12, 2020 at 9:42 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Front wheels straight, and drive train under minimal loading makes a difference in how easily 4wd will engage. If it does not want to release back to 2wd, stopping and backing up a foot or two helps. I imagine this action allows gears to unmesh and disengage.
  10. Nov 12, 2020 at 9:43 AM
    coopcooper
    alberta canada
    my placard just tells me which way to face a kid seat. i dont have any damn kids.
  11. Nov 12, 2020 at 9:45 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Correct, ECU is not going to be harmed.
  12. Nov 12, 2020 at 10:18 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It means the person driving has some responsibility too, meaning it is not as user friendly as an all wheel drive like a little crossover. With the Tacoma you actually have to learn and do things to make it work. BTW the instructions are on your sunvisor...
    Knute likes this.
  13. Nov 12, 2020 at 10:25 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Maybe it's like VSC can't retard the throttle if you are not applying throttle?
    Maybe if all four wheels are on hard level ground it has no "delta" like wheel spin or inclines so it just don't know what to do?
    Just throwing it out there!
  14. Nov 12, 2020 at 10:25 AM
    CoTacos
    CoTacos Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    Didn't read the thread so not sure if this is being repetitive, but I noticed 4 hi engagement doesn't work when I'm on the gas/accelerating. I usually coast, flip it to 4, have it engage, then back on the gas.
  15. Nov 12, 2020 at 10:26 AM
    #35
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    So you need kids?
  16. Nov 12, 2020 at 10:27 AM
    #36
    coopcooper
    alberta canada
    I can barely take care of my self never mind another human. No thanks ill pass.
    hiPSI[QUOTED] likes this.
  17. Nov 12, 2020 at 10:49 AM
    #37
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Look up at the sticker on your sun visor.
    Skidog1, mattleg and BlkTaco47 like this.
  18. Nov 12, 2020 at 11:01 AM
    #38
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is certainly a scenario that the system will encounter, but I cannot see any harm being caused. In the corp vids, they show CC being used for ascent and descent control and other cases where it is basically no-slip off road cruise control. In those situations, even on the lowest setting, it is mainly keeping the wheels turning at the same rate.
    I have witnessed CC / MTS in action. Zero personal dislike other than the transmission choice, for me. It is voodoo-like, and after being stuck in sand with other vehicles before, can see how it would be a killer app there. I just can't see HW or SW issues with its use on pavement with no steering input. With steering input, I can't see it being worse than an accidental dry pavement turn in 4Hi that most of us have done at some point.
    My biggest 4wd fear? Hard throttle using the 2Lo Mod. Even there, I can see tire slip happening before any damage, but there is the 2.57x transient that might grenade something in the rear driveline?
    Recently, I did have the 2LM accidentally engaged for a short step climb. I was wondering why I was scrabbling for traction, but the TRAC system got me up while I had the throttle pinned. As far as I could tell, the ABS was holding both rear wheels at just above idle and kept me moving.
    Freegolf and hiPSI[QUOTED] like this.
  19. Nov 12, 2020 at 11:17 AM
    #39
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    On my visor it's a sleeve with a plastic laminated card that you can take out.
  20. Nov 12, 2020 at 12:11 PM
    #40
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    If you can, find a local 4x4 club. There is bound to be another Tacoma owner in the group who can guide you, and most of the basics have no brand allegiance so even the Jeep guys could help you. Nothing beats a hands-on session with an experienced person.
