New 4x4 Tacoma Has Vibration When Braking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gwreynolds, Jul 14, 2018.
  1. Jun 23, 2019 at 2:59 PM
    #401
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Not all models fall into the vin range , so you gotta check yours against it . My 2018 sr5 was inside the parameters , FINALLY FiXED. Really enjoying the truck now . Please keep in mind it’s a Tacoma, all Tacoma’s have a little vibe here n there . But that rumblestrip under decel is history. I think it’s 0171-16 . It was just recently revised . Worked for me .
  2. Jun 24, 2019 at 4:19 AM
    #402
    JP11283
    JP11283 Member
    FL
    2019 SR5 PreRunner
    Is there a way to check the VIN range online?
  3. Jun 24, 2019 at 7:10 AM
    #403
    camillethetoy
    camillethetoy Just a Minor Threat
    jeremy
    KCMO
    98 T100
    Just opened a case with Toyota per my dealership's recommendation, they say an expert (Master Mechanic with access to Toyota engineers) from corporate will be in touch within 24 hours.
    They were very helpful with opening my case over the phone fwiw..
    Skull likes this.
  4. Jun 24, 2019 at 7:38 AM
    #404
    ryan760
    ryan760 Well-Known Member
    I've got a very light amount of vibration on mine (400 miles on the ODO), mostly from 25 mph down to 20. Not super noticeable, but its there. For fear of making the situation worse by letting Toyota dick around with it, is it safe to just let it be and live with it? Or does this need to get fixed?
  5. Jun 24, 2019 at 8:08 AM
    #405
    MetalYota
    MetalYota Well-Known Member
    1990 22re, 1999 Tacoma, SOLD 2017 TRD DC
    Did the same. Resulted in nothing. Case was closed....they called it a “normal characteristic of the truck”
    I called it a “normal characteristic to sell the truck immediately”
    90 and 99 still going strong. 99 drives like its off the showroom floor at almost 300k.
    At Jeep dealership test driving new JLs right now.
    camillethetoy[QUOTED] likes this.
  6. Jun 24, 2019 at 8:38 AM
    #406
    camillethetoy
    jeremy
    KCMO
    98 T100
    I hope they don't do this whole normal thing with me again. I still have an 88 4x4 that has 0 vibes.
    There's a design flaw somewhere & it sounds like they don't want to recall, seems very un-Toyota. They usually fix their flaws from what I've seen in the past..
  7. Jun 24, 2019 at 12:01 PM
    #407
    MetalYota
    I hope so bro. I wanted it to work...they just refused to fix my shaking under braking and diff howl. Also saw paint defects that were unacceptable. This along with working night shift....no time for going back and forth with a dealership begging for a fix for my 40k truck. Dealership let me down. And then Corporate.....It was simply time to go.
  8. Jun 24, 2019 at 12:06 PM
    #408
    camillethetoy
    jeremy
    KCMO
    98 T100
    I agree 100%, I have some bubbling above the rear passenger door as well that I have not even mentioned yet, been trying to get them to concentrate on the vibes 1st..
  9. Jun 24, 2019 at 12:40 PM
    #409
    ryan760
    Haven't had time to read through this beastly thread yet, but given the fact that the vibration occurs for some people with or without brakes applied, has anyone tried shifting into neutral while decelerating without brakes to see if the vibe is still there? Wondering if there is some weird coupling effect from the transmission and the rear driveline componenets...
    xsf18cdf likes this.
  10. Jun 24, 2019 at 12:46 PM
    #410
    xsf18cdf
    xsf18cdf Well-Known Member
    Gary
    Texas
    2019 TRD/OR/DC/LB/QS
    None
    It's the same pulse I feel sitting at a stoplight and when first starting the truck. It's not with every application of the brakes either- almost like a random ABS pulse.
    camillethetoy likes this.
  11. Jun 24, 2019 at 12:59 PM
    #411
    Fatmonk8
    Fatmonk8 Did anyone ever tell you you're my hero?
    Paul
    Delco, PA
    2019 SR5 Barcelona Red Taco 3.5 V6
    I have noticed it on my 2019 I just got
  12. Jun 24, 2019 at 6:10 PM
    #412
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    did that on a steep hill as have others in other threads. the more aggressively you decelerate, the stronger the vibration. the only reason you feel it while braking is because
    braking is slowing you down. steeper hill or harder braking will get you stronger vibration.
    i have no idea of cause but likely some resonance induced by decelerating driveline. i feel it in body, pedals, steering wheel etc. the whole beast.
  13. Jun 24, 2019 at 6:38 PM
    #413
    camillethetoy
    jeremy
    KCMO
    98 T100
    Pretty sure it's a driveline issue, wondering with so many different shock configs on the 3rd Gens & the fact that there could have just been a couple big batches of bad flexy leaf packs that we only see this on some models with certain shock & bad leafs combined..
  14. Jun 24, 2019 at 7:11 PM
    #414
    ryan760
    I don't know if I buy the "bad batch" theory personally, but I do agree that its probably driveline related as it happens with or without brakes applied.
    Sounds like more of a minor design flaw to me. Certain combinations of shocks, springs, bed configurations, 4x2s vs. 4x4s, etc. are causing a mild resonance at certain speeds/loading conditions. The fact that the issue has existed for years now, and Toyota has yet to release a solid fix, is both weird and reassuring to me. Reassuring in the sense that if the issue were serious enough, they would have put more effort and resources into resolving it.
    Vibration in mine is minor enough that I am just going to chalk it up to a design quirk and move on.
  15. Jun 24, 2019 at 7:19 PM
    #415
    camillethetoy
    jeremy
    KCMO
    98 T100
    Good call, been a headache
    Also, like your take on the reassurance
    I will continue to update you guys not to fan any flame but so those who are interested in anything I find out can see it here
    4x4spiegel and ryan760 like this.
  16. Jun 25, 2019 at 7:17 AM
    #416
    JP11283
    JP11283 Member
    FL
    2019 SR5 PreRunner
    I put mine in neutral several times while stopping today. Still a little bit of vibration but a fraction of the amount in drive. The vibration on mine seems to be the worst when the transmission downshifts right around 20 MPH and the RPMs jump up.
  17. Jun 25, 2019 at 3:12 PM
    #417
    t0ad
    t0ad New Member
    SD
    2019 Magnetic Gray SR5
    Been silently reading stuff on the forum since joining, thought today would be a good opportunity for post #2.
    Had the vibration for at least 2k miles. Finally, when it was time for the 5k work, I said something about it (even though it drove me nuts).
    At first, advisor said they couldn't duplicate the vibration, so I told them how it usually (90% of the time) occurs and hoped for the best. They called back about 2 hours later and told me the vibration replicated and that they would have to keep my truck for a couple days. Oddly, his voice and demeanor seemed to change just a bit, and after researching it post-work, I can see why (hint; $$).
    Here is exactly what my invoice says:
    Excessive clearance between brake drum and axle drum flange on both rear axles.
    Left drum reading 4.27
    Right drum reading 4.26
    Removed and replaced both rear axle shafts
    OP Code- TC1801A 3.8
    T1 91 T2 50​
    The parts list included:
    Rear Axle Shaft (2)
    Hub Bolt (12)
    Bearing Assembly (2)
    Brake Gasket (2)
    O-ring (2)
    Rear retainer (2)
    Snap Ring (2)
    Seal (2)
    I found a Toyota parts place and ran all the part numbers and the list price on the above was 1700 bucks. I can see why the guy's demeanor changed a bit.
    I will update when I determine whether this fixed the vibration.
    You guys are awesome. Such good info all over this forum.
  18. Jun 27, 2019 at 7:59 PM
    #418
    camillethetoy
    jeremy
    KCMO
    98 T100
    Toyota corporate called me today. Said they checked everything & 'the engineers' have not issued a TSB for an Off-road of 2019, so, I'm stuck she said for now but promised Toyota is always improving..
    MetalYota likes this.
  19. Jun 28, 2019 at 7:01 AM
    #419
    MetalYota
    Bounce around to other dealers hoping they figure it out by chance or sell.....same thing that happened to me.
  20. Jun 28, 2019 at 7:37 AM
    #420
    Skull
    Skull Well-Known Member
    Karl
    NC
    2019 White TRDPro
    Hope you have good luck,the “master mechanic” near me could not understand the concept of road force variation when trying to balance a faulty tire.
