New 5100's and IM NOT HAPPY!!!
Discussion in 'Suspension' started by TRDSPORTtaco, Apr 13, 2011.
  1. Apr 13, 2011 at 2:09 PM
    TRDSPORTtaco
    TRDSPORTtaco [OP] Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    So I saved up a butt load of money to finally buy the coveted Total Chaos UCA's and 5100's all the way around. I was ditching my Tough country 2.5" spacer lift with 3/8" top plate for the 5100's at 2.5 thinking I was going to get close to the same amount of lift.
    HERE IS MY PROBLEM!
    It turns out .5" makes a big difference, so I had some body rub from my tires at half turns (285/70/17 wheels have 4.5bs). To solve this I put the 3/8" top plate spacers on to give the extra lift needed to barely clear and get as close to 3" as possible. Yet Im still experiencing a bad case of the "Rubs."
    WHY I'M UPSET!
    Since switching to the 5100's at 2.5 with a 3/8" top plate I now have an even worse case of "the lean." Close to a full inch drop on driver side! I didn't have this problem as bad before with just the spacer lift (preloading, with top plate). I've read a lot about not mixing lifts with 5100's due to messing up suspension or getting WAY too much lift.
    MY IDEA
    So without spending anymore money I figured I could set my 5100's at .885 (or whatever the second setting is) Put my tough country spacer back on, and only use the 3/8" top plate on the driver side. If I am thinking correctly than that should put me back to being close to 3" or a tiny bit over with enough lift on the driver side to compensate for the "lean."
    Is this correct? Also what is the difference in using the 5100 at the 2.5" setting to preload the coil for lift compared to setting the 5100 at "0" and preloading with a spacer for lift?
  2. Apr 13, 2011 at 3:36 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Your still preloading the springs at 2.5 setting and those springs arent meant for that. You need new coils to support the heavier shocks. Eibach's and 5100s at .85 should put you close to 3". Do not at any cost put the spacer back on with the 5100s....the springs can't handle that. Also, the uca's can change your caster and cause rubbing, it needs to be adjusted. Mine are adjusted to 3 degrees, so I would suggest an alignment and adjust accordingly.
  3. Apr 13, 2011 at 3:47 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    What if I was to set the 5100's at .85 an put a 2.5" top plate spacer on so its not adding to the preload?
    My last alignment shows passenger side caster at 3.1 and driver side at 2.5.
    Ill have to look into the new coils. Where is the best place to buy the coils?
  4. Apr 13, 2011 at 3:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like you put the driver side springs on teh passenger side....
  5. Apr 13, 2011 at 3:56 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Did the springs go back on the same side as they came off?
    Edit: Chris4x4 FTW
  6. Apr 13, 2011 at 4:03 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    yeah, I guess I could pull the complete shock assembly off both sides and swap.
  7. Apr 13, 2011 at 4:04 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    x2
  8. Apr 13, 2011 at 4:17 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Ok after doing some more searching im sold on the 885's. I just need to find them at a descent price.
  9. Apr 13, 2011 at 5:09 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    So I am guessing in the span of 14 minutes you didnt try swapping the spring first?
  10. Apr 13, 2011 at 5:12 PM
    silvertaco82
    silvertaco82 No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    I ran toytec spacer lift with 5100s set at .75 on my 05 and it road great
  11. Apr 13, 2011 at 5:14 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Also I am wondering why your caster is so far off. Wouldnt the 2.5 on the drivers side put the wheel closer to the cab? I thought one of the points of UCA's was to be able to get aligned better with lift. Now my alignment is way off but Im LT so I gave up the chance at alignment awhile ago. But I would think his caster numbers should be able to get closer
  12. Apr 13, 2011 at 5:40 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Ill try swapping sides before ordering new coils.
  13. Apr 13, 2011 at 5:41 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    What size spacer? 2.5?
  14. Apr 13, 2011 at 5:48 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    X3
  15. Apr 14, 2011 at 7:25 AM
    silvertaco82
    Bozeman, MT
    no its 3" the toytec basic kit with 5100s and i had ride rite airbags in rear to fix the "taco lean".
  16. Apr 14, 2011 at 7:30 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Get the adjusters and coil from toytec...then they will be coilovers
  17. Apr 14, 2011 at 7:47 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I did billies set at 0 with OME 885's and new UCAs. I had a 1/4" top plate spacer put on the driver's side only to get rid of the lean and it sits perfectly level and I'm almost at 3" of lift with a great ride.
  18. Apr 14, 2011 at 8:04 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    ^^ That's it right there! Then get the caster dialed in till there's no more rubbing!
  19. Apr 14, 2011 at 8:19 AM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Ordered the 885's from rocky road outfitters, I'm not sure now if I should set my 5100's at .85 or 0 when they come. Ill get my truck in and the caster fixed after I put the coils on. I want to be as close to 3" as possible.
  20. Apr 14, 2011 at 8:29 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Leave them at 0 with the 885's, as they will provide 3" without any assistance from the 5100's.
