New 5100s slight vibration non alignment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upnorthtacoma, Nov 8, 2018.
  1. Nov 8, 2018 at 8:08 PM
    upnorthtacoma
    upnorthtacoma [OP] Member
    Damon
    2016 TRD Off Road
    Bilstein Shocks 1.55, 265-75-16 Falken Wild Peak at3
    Just had Bilstein 5100s installed @ 1.55 on my 2016 TRD off road DCLB. The trucks alignment is spot on, Tech said he got it to a hair of factory. Rides straight, steering wheel perfect.
    Issue is a slight vibration through steering wheel at any speed, that’s accelerating or driving or foot off the gas? It almost feels like drive shaft. It doesn’t wander or anything I just feel a constant vibration, can also feel on gas pedal. It doesn’t shake, feels like it’s almost dragging like when you have it in 4wd and you can feel a little resistance. Any ideas? Has anyone else had this issue. The most obvious thing would be tire etc. but tires are brand new Falken ATs,and this didn’t happen before shocks were put on? I’m stumped. The Tech took for a ride, he says maybe your feeling your tires more with different shocks, he doesn’t know how it drives before.
  2. Nov 8, 2018 at 8:10 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Could be needle bearing on the cv axle. Common problem.
    Nunya Bizness likes this.
  3. Nov 8, 2018 at 8:13 PM
    tcjacado
    tcjacado Well-Known Member
    Are the wheels torqued to 85lbs?
    Did you torque everything to spec while the truck was in the air or on the ground.
    Carrier bearing spacer may be needed or axle shims.
  4. Nov 8, 2018 at 8:14 PM
    tcjacado
    I think he is 2wd... no needle bearing.
  5. Nov 8, 2018 at 8:15 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Looks like his truck has 4x badge from another post.
    tcjacado likes this.
  6. Nov 8, 2018 at 8:19 PM
    tcjacado
    Could be, I didn't see his pics. Only going by what it says in profile trd offroad.
    Does his vibration go away in 4wd
  7. Nov 8, 2018 at 8:21 PM
    upnorthtacoma
    Damon
    2016 TRD Off Road
    It’s 4x4 TRD off road
    Skydvrr and tcjacado like this.
  8. Nov 8, 2018 at 8:23 PM
    upnorthtacoma
    Damon
    2016 TRD Off Road
    I was wondering that as well, I’m just wondering why it showed up now? When I didn’t feel it at all before the shocks were installed or could this have added to it where I would feel it now
  9. Nov 8, 2018 at 8:26 PM
    upnorthtacoma
    Damon
    2016 TRD Off Road
    That’s good to know, I asked the tech that . I’m like should I just get a diff drop even if it’s a small amount , and he’s like no that lift is only 1.55 that shouldn’t make a difference at all.... it’s not like you’re lifted, but it sure feels like driveline to me...it can’t hurt to try, Yeah it’s so hard to explain it’s not like it vibrates up and down it’s just a constant feeling of like a dragging feeling through the wheel.
  10. Nov 8, 2018 at 8:28 PM
    tcjacado
    Does it go away in 4wd.... if so.... needle bearing.
  11. Nov 8, 2018 at 8:31 PM
    upnorthtacoma
    Damon
    2016 TRD Off Road
    Thanks for the suggestions
  12. Nov 8, 2018 at 8:33 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I would not know what the needle bearing vibs felt like because I had mine changed out when the lift was installed.
  13. Nov 8, 2018 at 8:46 PM
    upnorthtacoma
    Damon
    2016 TRD Off Road
    I tried it in 4 wheel drive felt the same
    tcjacado[QUOTED] likes this.
  14. Nov 8, 2018 at 8:47 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    The lift is what typically causes the vibes.
  15. Nov 8, 2018 at 8:49 PM
    upnorthtacoma
    Damon
    2016 TRD Off Road
    I can feel it on the floor where my left foot is, thinking the drop diff spacer would be the best thing to start with, at least I would have it to alleviate any future issues.
  16. Nov 8, 2018 at 8:50 PM
    VaToy
    Parts Unknown
    Sometimes yes, same truck but just every truck is a little different. Some settling may have occurred, the mind set when you get into a lifted vehicle with some bigger tires your mind is trying to adjust and your really trying to just feel the truck out.
  17. Nov 8, 2018 at 9:10 PM
    VaToy
    Parts Unknown
    I will add that I drove a few hundred miles before getting the diff drop done and will say it really improved the steering. Feels a lot easier to turn. I felt it really complete the lift package. The guys at the shop just got back in from the SEMA show and had some great things to discuss, my truck being one of them. The slight vib was so little not everyone could feel it but I know my truck.
  18. Nov 8, 2018 at 9:26 PM
    bzzr2
    bzzr2 Well-Known Member
    Lifted one way or another, your diff doesn't know if you used 5100's, spacers or coil overs. The only actual factor would be lift height, which can be different with all of the above lift methods
  19. Nov 9, 2018 at 1:41 AM
    VaToy
    Parts Unknown
    Yea but the CV axles get out of spec a little more with a spacer kit, so I was told. From what I see on here it appears more are doing the needle bearing fix more with spacers than Bilstein.
  20. Nov 9, 2018 at 6:24 AM
    upnorthtacoma
    Damon
    2016 TRD Off Road
    Did you do the front spacer drop or rear? I watched a YouTube video we’re the guy had same yr truck same issues, he did a rear one Old Man Emu one. Worked...I’m gonna put a 1 in block in rear to level, would you do front and rear drop
