NEW 6MT Clutch Pedal Squeak/Creak Noise Revised TSB (T-SB-0112-19)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6MTPro, Oct 22, 2019.
  1. Nov 16, 2020 at 9:24 AM
    #241
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    So, now after 2200 miles, the creek/squeak is coming back. :annoyed:
  2. Nov 16, 2020 at 9:27 AM
    #242
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    On the latest TSB with the updated parts? If so, I think you're the second person to say that.
  3. Nov 16, 2020 at 10:07 AM
    #243
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Correct - I had TSB T-SB-0112-19 performed with the "updated" parts. It's not that bad yet, but it is starting to make noise when its cold...just how the original clutch pedal started.
    tonered[QUOTED] likes this.
  4. Nov 16, 2020 at 10:10 AM
    #244
    1202firemedic
    1202firemedic New Member
    Was your “updated” clutch pedal noticeably higher than the factory pedal?
    K Williams and tonered like this.
  5. Nov 16, 2020 at 10:12 AM
    #245
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm sorry to hear that.
    Looking at the detail of the molded pedal, all the TSB work involved, and such, they would have been better off throwing a bit more into the design of a better metal pedal.
    The non-linear clock spring is my biggest gripe. Thankfully, my noises have been fixed with a quick adjustment for clicking and some brake grease (twice) for squeaks.
  6. Nov 16, 2020 at 10:20 AM
    #246
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    No. It appears to sit exactly like the original. When I first received the truck back, my friction point was very close to the firewall, but I bled the clutch and it went back to feeling "normal." After bleeding, I couldn't feel a difference between the parts aside form the side-to-side, wobbly feeling being gone.
    tonered likes this.
  7. Nov 16, 2020 at 10:32 AM
    #247
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The new parts don't change the pedal height or the ability to change the adjustment whatsoever. The dealer didn't do the compete procedure and the master cylinder pushrod length and/or pedal height is set incorrectly. Have them adjust the pedal freeplay and height as per the TSB/repair manual instructions.
    To assist, I have attached the last step of the instructions that the TSB tells technicians to do when replacing the clutch pedal.
  8. Nov 16, 2020 at 12:23 PM
    #248
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You are the man, as always!
    :hattip:
  9. Nov 18, 2020 at 10:56 PM
    #249
    Desert War Eagle
    Desert War Eagle Member
    Simmons
    2021 Cement Tacoma TRD Off-Road 4WD MT
    What was your fix for the clicking? I've just started noticing that on mine, due to maybe a little more play, after only 350 miles. Just a slightly different sound and feel...
  10. Nov 19, 2020 at 5:23 AM
    #250
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For the clicking, I adjusted the pushrod length on the master cylinder. There was too much gap.
    You just have to make sure there is some free play after the adjustment.
  11. Nov 19, 2020 at 5:26 AM
    #251
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    Adjusting the push rod fixed both squeaking and clicking for me. I did dab some grease on one spring.
  12. Nov 19, 2020 at 9:52 AM
    #252
    Desert War Eagle
    Simmons
    Thanks.
    tonered likes this.
  13. Nov 19, 2020 at 9:53 AM
    #253
    Desert War Eagle
    Simmons
    Thanks!
  14. Nov 19, 2020 at 9:54 AM
    #254
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    See @Jeff Lange 's post just above for the details.
  15. Nov 19, 2020 at 10:33 AM
    #255
    Jeff Lange
    Calgary, Canada
    Essentially, set the pedal to the correct height, then adjust the pushrod to get a small bit of freeplay, I usually prefer for that to be minimal and like to adjust the clutch pedal to where it makes sense for the individual vehicle, especially if not using an original clutch/flywheel setup. The repair manual's specs are definitely a good place to start though, and should be where dealership technicians are setting it when performing the TSB on a vehicle that is under warranty.
    Jeff
    shakerhood and tonered like this.
  16. Dec 14, 2020 at 9:49 AM
    #256
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    My clutch pedal was squeaking so the dealer replaced it under warranty. The new one still clicks and now it doesn't push the floor button far enough to start the truck every time. Is there a way to adjust this part? I dont want to have to go back to the dealer.
  17. Dec 14, 2020 at 10:12 AM
    #257
    Jeff Lange
    Calgary, Canada
    Read the PDF attached to the post you quoted.
    Jeff
  18. Dec 23, 2020 at 4:30 AM
    #258
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    Anyone know if they will still do this “under warranty” if the truck is now at 73k? lol
  19. Dec 23, 2020 at 5:37 AM
    #259
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. It is in the bumper to bumper period only. But, you never know if there might be some goodwill with your dealer?
  20. Dec 23, 2020 at 5:38 AM
    #260
    Watkinseli91
    Eli
    Greenville, SC
    2021 LR PRO
    So annoying when they have to know it affects A LOT of newer model manual trucks. Mine has been doing it much more after 50k
