NEW 6MT Clutch Pedal Squeak/Creak Noise Revised TSB (T-SB-0112-19)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6MTPro, Oct 22, 2019.
  1. Dec 23, 2020 at 5:40 AM
    #261
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine squeaked and clicked while still in warranty, but grease and adjustment fixed it for me.
    It's just not the best design to start with.
  2. Dec 23, 2020 at 6:35 AM
    #262
    su.b.rat
    su.b.rat broken truck
  3. Jan 14, 2021 at 7:21 PM
    #263
    KG Fz1
    KG Fz1 "The Greatest Teacher, Failure is"
    Ken
    Streamwood, Illinois
    2019 Black TRD Off Road DC MT
    OVTune, TRD Exhaust, K&N Performance Air Intake
    I had the tsb performed 11 months ago. Last night the creaking came back. I'm under warranty until 120k so my 2019 goes back to the dealer next week.
  4. Jan 14, 2021 at 7:27 PM
    #264
    DrewMaca
    DrewMaca Well-Known Member
    Drew
    2016 TRD Sport 4x4 Double Cab
    Does this TSB hold up in Canada as well? Didn’t read through the entire 14 pages. But yes, clutch squeak is real, and really annoying.
  5. Jan 14, 2021 at 7:32 PM
    #265
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mine turned nasty yesterday. I was waiting to do fuel pump at the same time.
    I may see if I can contortion some spray grease all up in there.
  6. Jan 14, 2021 at 7:43 PM
    #266
    KG Fz1
    Ken
    I might try greasing up the pedal after having a look at it this weekend.
    Pablo8 likes this.
  7. Feb 26, 2021 at 2:21 PM
    #267
    KG Fz1
    Ken
    Ended up having the dealer replace the clutch pedal assembly under the latest TSB. Technician greased it up good before installing. Quiet like it should be but for how long?
    Bad timing: When I left the dealer it was dark and rural. I decided to "Road test" my truck. At 80+ MPH the nice policeman decided he needed to slow me down. 62 in a 45 zone, not too bad @ $130. :burnrubber:
    doublethebass likes this.
  8. Feb 26, 2021 at 8:19 PM
    #268
    MonsieurHodge
    MonsieurHodge Well-Known Member
    Nick
    Carmel Valley, CA
    2014 Blue Ribbon TRD Off Road AC 4x4 V6 6MT
    Glad I found this thread, my 2020 just started doing this. 22k miles.
  9. Mar 1, 2021 at 1:46 PM
    #269
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Mine is at dealer. Of course, dealer does not hear noise.
  10. Mar 1, 2021 at 1:57 PM
    #270
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Which dealer?
    Unfortunately with the other issue, getting to another wouldn't be easy.
  11. Mar 1, 2021 at 2:06 PM
    #271
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Kirkland
  12. Mar 1, 2021 at 2:07 PM
    #272
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I've heard of issues on the service side there from a few folks. Good luck!
  13. Mar 1, 2021 at 2:12 PM
    #273
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Mine came back after 1k miles after replacement. I used some lithium grease on it it helped. But it looks like I’ll be lubing from now on .....
  14. Mar 1, 2021 at 3:04 PM
    #274
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Try using Disc Brake Grease on all the pivot points and it won't melt away like other greases.
    GOTSAND?18[QUOTED] likes this.
  15. Mar 1, 2021 at 5:08 PM
    #275
    KG Fz1
    Ken
    It is hard to believe that all the geniuses at Toyota can't come up with a quiet clutch pedal assembly. A sealed needle bearing on an axle and a rigid frame would do it. Crazy part is this has been an issue for almost 20 years.
    Pablo8 likes this.
  16. Mar 1, 2021 at 5:10 PM
    #276
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Yep. Cheap ass bullshit.
    AdventureKid and shakerhood like this.
  17. Mar 2, 2021 at 3:15 PM
    #277
    Marlowe_McFly
    Marlowe_McFly New Member
    2020 Tacoma TRD OFF-ROAD DCSB 6MT CEMENT
    SCS F5 Wheels 16x8 +0 offset Prinsu Roof Rack Softopper Pedal Commander
    I just had this TSB done and the clutch catch point is closer to the floor (about 2” lower) Not sure if this was intended or if the clutch pedal adjustment wasn’t done properly to match how it comes from the factory. I like how it feels now with the catch point lower but I also hope it hasn’t shifted the rest point to allow more slip.
  18. Mar 2, 2021 at 3:22 PM
    #278
    slistings
    slistings Well-Known Member
    SoCal
    I just had this done as well. Clutch feels about the same though. No squeak at the moment...
  19. Mar 2, 2021 at 4:57 PM
    #279
    KG Fz1
    Ken
    I experienced the same lower catch point. I have read this is intentional due to the different pedal hydraulic cylinder. Everything was great for 11 months until the noise returned. TSB parts are under a 1 year warranty so they put in a new pedal assembly. Toyota can keep doing this indefinitely as far as I am concerned. It would be even better if they could figure out how to manufacture a robust, quiet clutch pedal assembly.
    I wonder if anything is available from the aftermarket :jerkoff: Wish I had an old one to reverse engineer
  20. Mar 2, 2021 at 5:01 PM
    #280
    su.b.rat
    they did come up with it. it's on the FJ, all metal, no plastic, strong & quiet. get you one.
    shakerhood likes this.
