NEW 6MT Clutch Pedal Squeak/Creak Noise Revised TSB (T-SB-0112-19)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6MTPro, Oct 22, 2019.
  1. Mar 2, 2021 at 5:04 PM
    #281
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    My dealer said there is no clutch TSB.
    doublethebass likes this.
  2. Mar 2, 2021 at 5:28 PM
    #282
    Burica
    Burica Raptor Deracinator
    Texas
    Warranty information codes for T-SB-0112-19:
    Problem codes T1
    (nature of) & T2 (cause of):
    T1 91
    = Abnormal or excessive noise (other than codes=06, 2A, 25, 36, 59, 65)
    T2 14 = Weakened, loss of tension or resilience (spring, cushion, etc.)
    Sent to Toyota by the dealership for warranty claim reimbursement.
    shakerhood likes this.
  3. Mar 2, 2021 at 7:18 PM
    #283
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    LoL!
    Do they think that the internet doesn't exist either?
  4. Mar 2, 2021 at 8:02 PM
    #284
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    In a short while I will be living near Bellingham and will be done with Kirkland.
    The service advisor wasn't a complete ass, they just seemed incompetent. He said they didn't even want to lube it, because of my mods and the warranty................(WTAF???)
    tonered[QUOTED] likes this.
  5. Mar 2, 2021 at 8:52 PM
    #285
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    There is a bit of wiggle room in the spec, but also they may have just not adjusted it properly.
    Jeff
  6. Mar 31, 2021 at 4:54 PM
    #286
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    bumping this, anyone from Canada succeed?
  7. Mar 31, 2021 at 5:06 PM
    #287
    Jeff Lange
    Calgary, Canada
    Toyota Canada TSB 5252.
    Jeff
  8. Apr 1, 2021 at 5:53 AM
    #288
    KG Fz1
    KG Fz1 "The Greatest Teacher, Failure is"
    Ken
    Streamwood, Illinois
    2019 Black TRD Off Road DC MT
    OVTune, TRD Exhaust, K&N Performance Air Intake
    That is funny shit!
    6,000+ miles since my pedal was replaced in January and all is quiet from my left foot :thumbsup:
  9. Apr 1, 2021 at 6:47 AM
    #289
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    That good news. Hopefully it continues.
  10. May 3, 2021 at 9:16 PM
    #290
    Yotamachine
    Yotamachine Well-Known Member
    2001 Yota
    Really annoyed by this creak clutch noise. My local dealer is not able to "replicate" the sound and is not wanting to do the TSB. I might just be out of luck in terms of warranty but I did bring this up to their attention well within the warranty period.
  11. May 4, 2021 at 4:56 AM
    #291
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Have you tried to grease it yourself yet?
  12. May 5, 2021 at 6:38 AM
    #292
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    What/where are the grease points ? Are they accessible from the cab ?
    I'm asking because, the clutch squeak started happening while my truck was still under warranty. The dealer performed the fix under warranty. It was fine for about two years, but the squeak has since returned and the warranty has expired. So, if it's a simple matter to just apply some grease I'd like to try that.
  13. May 5, 2021 at 6:43 AM
    #293
    su.b.rat
    su.b.rat broken truck
    disk brake grease. get a nitrile or latex glove, two fingers with a wad of the grease and apply to the coil return spring at the top of the pedal arm. be sure to get the grease both outside and inside the coil so the grease penetrates anywhere metal contacts metal within the coil.
    that fixed my spring squeak for more than a couple years, but it didn't fix the play and pivot noise well enough though. i had all 3 of those issues.
  14. May 5, 2021 at 6:44 AM
    #294
    Tacowin1013
    After about a year and a half my 2017 developed that barn door squeak, i took it in and my dealer performed the TSB, about a year and a half later, the squeak came back, so i've just been greasing it every oil change and no issues since. Get under the dash, push the pedal down slowly and look up there, you'll see a few 'pivot' points where rubbing and the joints could cause potential noise, just dab some brake grease on there (a few members here found thats the best solution since it holds up to the high heat temps which seemingly is when the noise starts to happen for me is summer)
    Hope that helps!
  15. May 5, 2021 at 6:45 AM
    #295
    Tacowin1013
    For me, i noticed my noise was coming more from the piston than the spring assembly
  16. May 5, 2021 at 6:49 AM
    #296
    su.b.rat
    interesting. my squeak came from the return spring, i actually removed it for a few months and it was silent without it. while that spring was off i began to get pivot groaning and play. at that point i was looking at other options, this plastic crap has to go. i do get some normal minor piston noise, nothing weird.
  17. May 5, 2021 at 9:01 AM
    #297
    SilverBulletII
    New England
    I’ll try that !
    Tacowin1013[QUOTED] likes this.
  18. May 5, 2021 at 9:08 AM
    #298
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I noticed some sticky, black residue on the M/C shaft. It cleaned up pretty easy. I can't remember if there was noise coming from it, but it was pretty easy to clean. You could put nearly any lubricant on the shaft (Astroglide? :D) as it is sealed on the far side. The lube would only help where is passes through the rubber dust cover.
  19. May 5, 2021 at 9:19 AM
    #299
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All parts of the clutch are internal to the cab. The inlet fluid feed line and the outlet pressurized line are the only external parts.
  20. May 5, 2021 at 11:22 AM
    #300
    Yotamachine
    2001 Yota
    Not yet but seems to be the next option in line.
