NEW 6MT Clutch Pedal Squeak/Creak Noise Revised TSB (T-SB-0112-19)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6MTPro, Oct 22, 2019.
  1. May 5, 2021 at 11:24 AM
    #301
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    It'll take you 5 minutes the first time you do it to figure out wtf you're greasing, after that, less than 2 minutes if you have latex gloves so you dont need to wash your hands. Quick and easy and no squeaks ever
    su.b.rat and tonered like this.
  2. Jun 17, 2021 at 11:50 AM
    #302
    DosTacosPorvor
    DosTacosPorvor Well-Known Member
    Brad
    Midwest
    19’ TRD Sport Dbl Cab M/T
    5100’s w/AAL, Dobinson's 314 coils. 285/70-17 BFG KO2's, 17X8 Pro-Comp 89's 0 offset, BA Highline Front Bumper, K&N FIPK CAI. N-Fab Podium steps, Gatorz Low Profile Hard tri fold Bed Cover.
    I just had my whole clutch pedal assembly replaced today. This is due to TSB Toyota has out. Mine went away during colder months and came back this month. Finally! It was annoying!
    SilverBulletII likes this.
  3. Jul 12, 2021 at 12:49 PM
    #303
    BadBodhi
    BadBodhi New Member
    2021 TRD army green MT
    My brand new 2021 trd or MT began making this noise at less than 5k miles!!!! I live in Arizona got the truck in March start making noise once it starting going over 100 degrees. At the dealer today to see if they fix the issue. weather definitely a factor I say
    DosTacosPorvor and Pablo8 like this.
  4. Jul 12, 2021 at 12:57 PM
    #304
    DosTacosPorvor
    Brad
    Midwest
    On mine they replaced the entire clutch pedal assembly. There is a Service Bulletin on this issue. But it’s not a recall….yet
    Pablo8 likes this.
  5. Jul 12, 2021 at 1:46 PM
    #305
    KG Fz1
    KG Fz1 "The Greatest Teacher, Failure is"
    Ken
    Streamwood, Illinois
    2019 Black TRD Off Road DC MT
    OVTune, TRD Exhaust, K&N Performance Air Intake
    Had this replaced 2 times. Hot humid weather (after a cold Winter?) is what started the noise both times.
  6. Jul 12, 2021 at 2:02 PM
    #306
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    We seem to have some variance. Some get noises in the cold and others in the heat.
    You are on track there though as nylon does absorb moisture from the air and can change dimensionally because of it.
    doublethebass likes this.
  7. Jul 12, 2021 at 2:23 PM
    #307
    KG Fz1
    Ken
    I have had a bunch of bad experience with nylon parts in manufacturing. Storing parts with wet sponges in sealed bags, running batches of parts in environmental chambers with high heat/humidity to make them less brittle. Poor choice for a clutch pedal assembly that will be cycled 200,000/yr for how long? This number of cycles is something I never though about. This assembly should be designed to be trouble free for millions of cycles. Clearly it is not.
    FJ Cruiser clutch pedal assembly? Annual grease ritual? Back to dealer every 11 months for no cost replacement?
    I wonder what a regional service manager will do upon my 3rd failure?
  8. Jul 12, 2021 at 2:28 PM
    #308
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    So, you are familiar! :cheers:
    We're waiting on the third person to do the FJ swap to hear about the actual install and setup experience. The second person used a shop, and they said it dropped in with no issue. We're all sitting back as the very first person said that cutting and welding was need. We need the tiebreaker.
    It may have been test cycled, but like that one setup they used to have at Ikea, it probably didn't represent reality of folks loading it in different ways. Sometimes at an angle and such.
  9. Jul 12, 2021 at 2:43 PM
    #309
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Mine did for 100+ K no noise at all now it really didn't bother me my old 97 did to that too didn't bother me either had no effect other than the slight noise one day some one will build a "perfect truck" how ever I'm not holding my breath.
  10. Jul 12, 2021 at 3:25 PM
    #310
    su.b.rat
    su.b.rat broken truck
    first person, Key-Rei? if so, that was a 2nd gen. has there been two 3g's who have completed it?
  11. Jul 12, 2021 at 3:46 PM
    #311
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Dang. The foot well could be different on the 2nd Gens. But, the latest TSB applies to all from 2005 and up. That is a bit silly from a warranty standpoint, but . . .
    KG Fz1 likes this.
  12. Jul 23, 2021 at 6:17 AM
    #312
    Ichanz66
    Ichanz66 Active Member
    2004 Tacoma SR5
    my 2020 squeak like crazy with just 9k. I mentioned the squeak during the first service but was not addressed. Now I know there is a TSB for this crap, definitely will have this look at.
  13. Jul 23, 2021 at 8:24 AM
    #313
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    the remedy might be worse than the squeak… I’ve read some comments that clutch feel is different, or height of new clutch is different… make sure you are ok if things change after “fix”.. my case: I lube it around once a month..
  14. Jul 23, 2021 at 8:29 AM
    #314
    KG Fz1
    Ken
    Hold their feet to the fire, with a smile on your face!
  15. Jul 23, 2021 at 9:13 AM
    #315
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I had this TSB done and everything is fine. Creaking is gone and clutch feels the same as before the TSB. Guess
  16. Aug 12, 2021 at 2:53 PM
    #316
    KG Fz1
    Ken
    What type of sport pedals? Photos?
  17. Aug 12, 2021 at 5:23 PM
    #317
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    I will get pictures tomorrow of the sport pedals.
    pinochle likes this.
  18. Aug 13, 2021 at 6:36 AM
    #318
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    I had the tsb performed on my 19 Tacoma under warranty yesterday. Took a week to get the parts and a few hours for the install. No more squeaky when it’s hot out. Clutch feels the same.
    Pablo8 likes this.
  19. Sep 9, 2021 at 9:05 AM
    #319
    BernsTaco
    BernsTaco Well-Known Member
    21 Cement Tacoma TRD OR 6MT
    I just started hearing the creaking and some side to side play in my '21 TRD OR's clutch pedal. Got quiet during cooler mornings, but it gets really annoying during the heat of the day. Kids in the back seat noticed it before I did. :/
    Guess it's time to head back to the dealership.
  20. Sep 9, 2021 at 9:09 AM
    #320
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Nice. Mine has started this recently. Ty OP
