NEW 6MT Clutch Pedal Squeak/Creak Noise Revised TSB (T-SB-0112-19)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6MTPro, Oct 22, 2019.
  1. May 4, 2022 at 11:32 AM
    #341
    Rath89
    Rath89 Well-Known Member
    2020 Tacoma TRD OffRoad
    Headache Rack, Front Tow Hitch, CB, 4ft Alum Tool Box.
    T-SB-0112-19 Would have been 740$ but the extended warranty paid it.
  2. May 4, 2022 at 11:55 AM
    #342
    Gonks
    Gonks Well-Known Member
    OC
    SOLD 2020 White TRD Offroad 4x4
    After back and forth they fixed this using this tsb on mine.
    two weeks later the squeak came back
  3. May 8, 2022 at 9:31 PM
    #343
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The TSB applies only for 2005-2019 model years. It does not apply, yet, to 2020 or newer.
    Warranty would probably kick it back if the dealer tried to submit it as the TSB. The parts could obviously still be replaced under warranty for a 2020, but it would just be submitted as a regular warranty claim, without reference to the TSB. The TSB offered no additional warranty coverage anyway, so it is effectively the same.
    If you have the "TSB done" on a 2020, they just put the same parts in that the truck already had.
    Jeff
    Kev250R and shakerhood like this.
  4. May 9, 2022 at 1:36 AM
    #344
    m shark
    m shark Well-Known Member
    Infinity QX-50, E46 M3
    2020 with 38K miles. So far, so good! smooth as butter and quieter than a dead racoon.
  5. May 9, 2022 at 4:40 AM
    #345
    Rath89
    Either way like I stated extended warranty took care of it it was making creaking cracking noises they listed the tsb and parts used on the print out.
    Jeff Lange[QUOTED] likes this.
  6. May 9, 2022 at 4:12 PM
    #346
    Jeff Lange
    Calgary, Canada
    Yeah, it was warranty so no big deal. Just meant as a heads up for other 2020-2022 owners that there aren't newer parts available than what they have. Obviously if there is a concern, warranty (or extended warranty) will cover replacing things.
    Jeff
    Kev250R, shakerhood and tonered like this.
  7. May 10, 2022 at 7:58 AM
    #347
    GBR
    GBR Well-Known Member
    19 TRD OR
    So I get a very audible click/pop noise when coming off the clutch pedal. Does anyone else have that and is there something I can adjust to prevent or reduce this? Thanks.
  8. May 11, 2022 at 2:54 PM
    #348
    meats
    meats superwhite MT taco meats
    Justin
    Grapevine, TX & Cushing, OK
    '20 Super White DCSB 6spd MT 4x4
    Lots--
    yeah what a joke. they won't help me at all.
  9. May 11, 2022 at 3:00 PM
    #349
    meats
    Justin
    Lots--
    I called back before going back in-- And basically said what you said up top. Gonna fight with me until they have to fix it. Why the hell don't they just use the right parts from the start if this is a known issue? Toyota doesn't make many manual tacos let alone manuals period.
    Looks like it's just gonna be a waste of time again back and forth until the idiots fix it. No wonder I never fuck with the dealer. This site shits all over them.
  10. May 11, 2022 at 4:25 PM
    #350
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    From this post, I'd say grease it up?
    shakerhood likes this.
  11. May 11, 2022 at 6:53 PM
    #351
    meats
    Justin
    Lots--
    BOttom line--they shouldn't waste my time. I have greased it for 20k miles. They need to stop wasting all of our time and just replace the parts
  12. May 11, 2022 at 6:55 PM
    #352
    KG Fz1
    KG Fz1 "The Greatest Teacher, Failure is"
    Ken
    Streamwood, Illinois
    2019 Black TRD Off Road DC MT
    OVTune, TRD Exhaust, K&N Performance Air Intake
    There has to be a stand up dealer in Dallas-Fort Worth area. Somebody out there help this gentleman with another dealer to turn to.
  13. May 11, 2022 at 6:56 PM
    #353
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oh. Yeah. If greasing is not helping, then you have a bigger issue.
  14. May 11, 2022 at 7:04 PM
    #354
    Jeff Lange
    Calgary, Canada
    Just because a TSB doesn’t apply to a vehicle doesn’t mean they don’t have to fix a similar problem with the vehicle, haha. What are they even saying? If it’s not working properly you fix it.
    Jeff
    Kev250R and meats like this.
  15. May 11, 2022 at 7:50 PM
    #355
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Did you a use run of the mill grease or High Temp Disc Brake Grease?
    tonered likes this.
  16. May 12, 2022 at 4:44 PM
    #356
    Rath89
    The one in Cedar park is where mine was towed to, but they tried to sell me fluid change front to back for about $600. Since I already had an apt for the the 45k maintenance I declined and asked a a week ago, and they pulled up all the maintenance done at 40k prior to it being put up for sale. So I'd say cedar park is good at getting the work done, but isnt very honest with the rest of it.
  17. May 20, 2022 at 12:23 PM
    #357
    meats
    Justin
    Lots--
    Yeah it came back a few times. I've done that a bunch. They did same. Im almost at 36k too
  18. Jun 6, 2022 at 11:29 AM
    #358
    Gonks
    OC
    So, I wanted to follow up on this a month or two later. They did state that they would extend the TSB to my vehicle since the creak was so bad you could depress the clutch with your hand, and clearly feel the mechanism creak, and matched the description to a t. Perhaps it depends on the dealer, perhaps they did as you said and they simply replaced the same parts.
    I first reported that my creak came back. This was erroneous. After a few more trips, I finally had down time to sit under my car and figure out the source of the squeak to start blasting it. The squeak this time around was a lot less pronounced, and didn't have the same stiff pedal feeling through the leg as pre-tsb. After depressing the clutch pedal a few hundred times with my hand, and hearing nothing, and then depressing it with my foot, and hearing the creak, I thought I was going insane. Well, shit. I found the new "noise". The drive side seat ( I have leather) creases into the plastic, and makes a new creak that was masked by when the clutch was creaking :rofl:. When I realized the source of the new creak, I couldn't stop laughing for a little while. Now, I need to try to figure out why the seat does that, but at least the clutch creak is gone.
    I'll check back in in a few more months / thousand miles, but I am happy to report (2 months / 2000 miles so far) , no creaking clutch, just a creaky seat now.
    Kev250R, jersey jim and tonered like this.
  19. Jun 6, 2022 at 11:34 AM
    #359
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The shift boot starting to squeak in the creases was what threw me over the edge to get the redlinegoods.com shift boot. It's on the wrong side, but it could be the side of the seat rubbing the console when you add pressure? Shove a towel between them to see. If so, some vinyl protectant might help?
    Gonks[QUOTED] likes this.
  20. Jun 11, 2022 at 12:22 PM
    #360
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Just got mine done. Feels great so far! Work order states that I got the following:
    31420-60032: Cylinder Assy, Mas
    31311-04021: Pedal, Clutch
    31434-60010: Hose, Clutch Reser
    90389-06055: Bush
    08887-02007: Body Grease W
    I don't think they gave me a new pedal, as my pedal still has some of the old dirt cached in there. Doesn't bother me though. As long as I don't have the noise I'm happy. We'll see how long it lasts.
