NEW 6MT Clutch Pedal Squeak/Creak Noise Revised TSB (T-SB-0112-19)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6MTPro, Oct 22, 2019.
  1. Oct 22, 2019 at 10:17 AM
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    Wow, they replace the entire pedal and cylinder assembly..
  2. Oct 22, 2019 at 10:21 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Yea as long as the parts are updated its fine but if they are the same parts, it's just another band aid fix
    tonered likes this.
  3. Oct 22, 2019 at 10:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That has always been the case.
    For myself with squeaks and such, I'd go with grease before trying a pedal replacement. But, new part numbers sound promising?
    Thankfully, mine has been trouble free even considering that I tried pulling out the return spring for a test.
  4. Oct 22, 2019 at 11:03 AM
    su.b.rat
    su.b.rat broken truck
    over and over. it's been worth nothing except the tap on my time. the svc mgr basically said he doesn't care about squeaks, groans, and loose/play at the pedal. because for him to replace with new he needs to send back the old one and if it still works it's a problem for him. i told him it's about to fall apart with all the free play and he said yeah but it hasn't fallen apart yet.
  5. Oct 22, 2019 at 11:08 AM
    Tacowin1013
    Sounds like a load of bullshit to me, no one has the time to test old parts to verify if its broken or not. Have you tried a new dealer?
    AKGSD likes this.
  6. Oct 22, 2019 at 11:17 AM
    su.b.rat
    not for this issue yet. the next dealer down the road is way worse. there's another new one not too far... Toyota of Longo/Prosper out 380. i may try them, because i seem to be falling flat with figuring out a different parts solution.
  7. Oct 22, 2019 at 11:23 AM
    unclejunk
    unclejunk Well-Known Member
    Albany NY
    '18 Quicksand OR DCSB 6MT
    Call corporate? I'm not well versed in warranty/dealer stuff, but this sounds like a no-brainer.. TSB exists, and you have the symptoms; how can they NOT fix it?
    AKGSD likes this.
  8. Oct 22, 2019 at 11:28 AM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    I just grease my every 6 months or so.
    shakerhood likes this.
  9. Oct 22, 2019 at 11:32 AM
    su.b.rat
    on the TSB it says in warranty or no TSB for you. that's one way. another way is to just say anything. they don't call them stealerships for nothing.
  10. Oct 22, 2019 at 11:34 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    Thanks for sharing.....so far so good but I may need this down the road.
  11. Oct 22, 2019 at 12:24 PM
    Knox_Taco
    Knox_Taco Well-Known Member
    17’ Off-road 6-spd Manual
    Just took mine to the dealer for this (TSB) today.
    Pain in the ASS squeak. At first they just wanted to try & tighten the Clutch resistance. "NO BUENO"
  12. Oct 22, 2019 at 12:27 PM
    Knox_Taco
    That't about the time mine started acting up. On our way back from Charleston. And it started.:annoyed:
    6MTPro[QUOTED][OP] likes this.
  13. Oct 22, 2019 at 12:36 PM
    6MTPro
    6MTPro [OP] Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    It sucks because it's such an integral piece of driving makes me dread traffic even more because of the increased use. Had to do what my wife does when something on the car doesnt sound right...just turn the radio volume up higher and pretend like its not there :rofl:
  14. Oct 22, 2019 at 12:53 PM
    Knox_Taco
    Yep. Its definitely annoying!!
  15. Oct 22, 2019 at 2:44 PM
    #35
    6MTPro
    HI -> CA
    I mean the directions on the TSB are pretty clear if you hear squeaking or groaning go to step 2. Whats step 2 you ask? Ding ding ding replace clutch pedal assembly.
    Honestly a lot of it is that the manual drivers are almost the redheaded stepchildren and I'm sure the paperwork and profit margins are garbage for the dealerships on these things so the interest isn't there.
    BrianTaco75 likes this.
  16. Oct 22, 2019 at 3:51 PM
    #36
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Mine creaked. I greased it up recently and it's smooth as glass now. I knew about the old TSB and had no interest because it's same parts. I'm interested if they have new parts though.
    tonered likes this.
  17. Oct 22, 2019 at 4:34 PM
    #37
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    Had the earlier TSB done on my '18 last summer, they replaced the parts, last week it was cool enough to use the heat, sure enough, while I made it through the heat of the summer with little to no noise, it started groaning with the heat on. I hit it with some hi temp brake grease, it's quiet and feels smoother now.
    If they've come up with some new parts I'd consider having them replaced again, otherwise I will just grease it as necessary. I don't see the point of putting the same parts back in again.
    Twize and shakerhood like this.
  18. Oct 22, 2019 at 7:36 PM
    #38
    Nardogg
    Nardogg Well-Known Member
    19 Cement TRD Sport M/T
    Wheels/Tires, Some Meso Stuff, TURD grille. Hoodscoop Light Bar, Can-o-PY
    Mentioned this at my last service. my advisor said they had a new tsb and put in the order for the parts! Cant wait to not have a creaky clutch ( mine is aweful ) has gotten worse since day one my2019
    6MTPro[OP] and SilverBulletII like this.
  19. Oct 23, 2019 at 1:14 PM
    #39
    Knox_Taco
    Mine as well. Parts should be in this week.
  20. Oct 24, 2019 at 9:13 AM
    #40
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    This TSB continues to get updated from time to time. These are newer parts than what would have come in the truck for most people. The newest master was already being used in 2017 trucks, but the pedal in the latest TSB is newer than that.
    It’s probably worth getting it done if you have the squeak. Hope for the best and then lube it again if the squeak comes back or replace it again if they update the TSB again.
    Jeff
    MOC221_ and SilverBulletII like this.
