New AC condenser replacement tips?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JimNH, Jun 10, 2017.
  1. Mar 26, 2020 at 2:52 PM
    baldy77
    baldy77 Well-Known Member
    Albuquerque, NM
    05 TRD Offroad Doublecab Speedway Blue
    3" Toytec Adj Coilovers w/Bilstein 5100's front and rear, Toytec TSB AAL, LR UCA, Avid Weld-on Sliders, A.R.E. CX Topper.
    I just completed the replacement of the condenser on my 2005 double cab using the tips on the thread and everything worked out great. I just wanted to add a couple of things I learned since I went ahead and charged the system myself.
    First of all, I found a Denso condenser on Amazon for just under $80 shipped from amazon.
    https://www.amazon.com/Denso-477-0839-A-C-Condenser/dp/B00PYR1QT8
    I followed the instructions listed above by jellybelly22 and was able to swap out the part in about an hour and a half without removing the bumper cover and loosening the radiator without any issues. I also ordered a set of O rings like Benny123 suggested.
    My old condenser was damaged by a rock on the highway which pierced a hole in the condenser which evacuated the system.
    After replacing the condenser, I decided to charge the system myself using some YouTube videos as guides.
    I rented a vacuum pump and a set of manifold gauges from autozone and purchased a bottle of PAG46 oil and two 12oz cans of Freon along with a can tap and thermometer. The system called for 5.5oz of oil and up to 22oz of Freon.
    Getting the oil into the system was a pain because the condenser was already installed. Some tips I’ve seen is to add the oil in the service hose but that was taking too long and the hose didn’t hold the entire amount I was trying to add. My solution was to add it into the top inlet of the condenser. If I had to do it over, I would have added the oil before installing the condenser. Also, make sure not to overfill the system with oil depending on what parts you’re replacing. I added around 4oz which may have been too much considering I was only changing out the condenser.
    I then followed the instructions on the video by checking for a vacuum, letting the system hold the vacuum for about an hour, then if the vacuum held, continuing the vacuum process for an another hour before beginning to charge the system.
    I then added the Freon required. One issue I ran into was that my A/C light didn’t come on when the vehicle was turned on with the a/c running. Because of this, the system took the first can of Freon but didn’t kick on the compressor to draw the rest of the Freon and allow the second can to be introduced into the system. This was an error on my part for not making sure the a/c was working.
    I quickly found that I had a blown 10amp fuse found in the fuse box under the hood which prevented the a/c from kicking on. I replaced the fuse with the spare provided under the fuse box cover and the system kicked on allowing the Freon to turn the compressor on.
    I added the second can to get the 22oz and everything was working fine.
    After disconnecting the manifold gauges, I noticed I had a small leak in the high pressure shrader valve. I went to autozone for a shrader valve repair kit which included the shrader valve tool, a shrader valve for the high and low pressure valves and caps. Using the tool, I slowly unscrewed the high pressure shrader valve until a small amount of Freon began to exit then tightened the valve shut which fixed the leak. I’m guessing that the manifold gauge attachment for the high pressure valve may have loosened the valve allowing the leak.
    My suggestion is if you decide to charge the system, grab the schrader valve repair kit before you begin the process and make sure your current valves are in good shape. I would have probably just replaced the schrader valves from the start since it’s only about $4 for the kit.
    At the end of the day, I spent around $150 for the condenser, O rings, oil, Freon, can tap and thermometer; much less than the $670 I was quoted by a local shop.
    Do this job at your own risk. I’m not a mechanic and am merely sharing my experience.
    Here are the videos is used as guides for the system charge.
    https://youtu.be/bSzH_9blVO4
    https://youtu.be/Pdq8JAlct6s
    https://youtu.be/lglPJuBXVeE
    Partychief67, sgnz and spitdog like this.
  2. Mar 26, 2020 at 6:21 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If You only replaced the condenser, I think you only needed 1.4 oz of pag oil added to the condenser.
    The majority of pag oil is still in the compressor if you only had a leak in the condenser. Did you also replace the compressor?
    sgnz likes this.
  3. Mar 27, 2020 at 7:52 AM
    baldy77
    Albuquerque, NM
    Good point. I believe I added around 4oz since the system had been open for a while and the condenser has the receiver/drier integrated. A little more research on my part should have been on knowing exactly how much oil I should have added.
    sgnz likes this.
  4. Mar 27, 2020 at 9:29 AM
    spitdog
    I understand the research bit, I’m doing the same because I need to replace mine also. I’m collecting tools and parts now.
    sgnz likes this.
  5. May 3, 2020 at 6:38 PM
    sgnz
    sgnz Member
    2010 Black Tacoma TRD 4x4
    thank you all for the info. I'm about to replace the evaporator and condenser on my 2010 taco 4x4 V6. if you have any other tips you can offer or if you ran into any issues what were they? Do you recommend me replacing anything else? How and where do you add the Tag oil?
    Thank you in advance.
  6. May 3, 2020 at 6:51 PM
    sgnz
    sgnz Member
    Hey Benny
    Thanks for the info. Im about to replace my condensers on my 2010 taco v6 4x4 for the first time. Do you have any tips or suggestions? Did you add the Tag oil into the condenser, & if you did where & how much did you add? Thank you in advance.
  7. May 4, 2020 at 12:54 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    @sgnz It went smoothly. Just make sure system is evacuated by a service station, take your time getting condenser out. Get new seals.
    I used 1.4 ounces IIRC, based on this thread. https://www.tacomaworld.com/threads/pag-oil-capacity.504661/
    Once installed, I used the Chrisfix and Kflo videos to recharge. Take you time and follow all the steps. Always note which valves are open and closed and where the flow will be. At least it will be done before summer.
    sgnz likes this.
  8. May 4, 2020 at 3:45 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    There's a filter in the expansion valve at the firewall. You may want to inspect that too.
    sgnz likes this.
  9. May 4, 2020 at 8:28 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Is this the one? I’m changing my leaky condeser seal washer soon and thinking of changing the filter since it’s only a $2.50 part from Rock Auto. Is this filter a pain to change?
    sgnz and Larzzzz[QUOTED] like this.
  10. May 4, 2020 at 8:52 AM
    Larzzzz
    Larry
    MA
    That's it.
  11. May 14, 2020 at 10:51 AM
    JimNH
    JimNH [OP] Well-Known Member
    Jim
    Nashua, NH
    2009 White Dbl Cab, SR5, Tow Pkg, 138K and counting
    Kenwood bluetooth double din head unit trailer brake controller K-Z sportsmen classic 16RBT travel trailer!
    a year later and my AC is still running cold!
    Truckstop13, Partychief67 and Larzzzz like this.
  12. May 14, 2020 at 11:46 AM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    Always flush
  13. May 14, 2020 at 11:54 AM
    Larzzzz
    Larry
    MA
    And put the seat up when you're done! :rofl:
    DFlynn, Fullboogie and Jimmyh like this.
  14. May 17, 2020 at 9:37 AM
    spitdog
    I’m on the home stretch. Just put in a new condenser, valve cores, O Ring and seal washer. Also added 1.4 oz of pag oil for the condenser and a touch of dye.
  15. May 18, 2020 at 9:58 AM
    #35
    Hans Moleman
    Bay Area, CA
    That's great. Did you check your air temps at the center vent after you were all done? Just curious because after I finished it was at 40°F last week and now it's 44°F.
  16. May 18, 2020 at 10:30 AM
    #36
    spitdog
    Yes, It was right at 42. But it was my wife’s cooking thermometer with a cracked face, I’m not to confident in its accuracy. I need to buy one and check it right.
    FastEddy59 likes this.
  17. May 18, 2020 at 10:34 AM
    #37
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Get a pressure/temperature chart for 134a & compare. Your numbers should match those give or take a bit. Would be nice if the system had a sight glass but without one you’ll be just fine as long as your numbers are close.
    spitdog[QUOTED] likes this.
  18. May 18, 2020 at 10:38 AM
    #38
    spitdog
    I actually had printed one but never even though to look at it until your post. Thanks
    FastEddy59[QUOTED] likes this.
  19. May 18, 2020 at 11:22 AM
    #39
    spitdog
    So my tips are:
    When you push back the radiator to get the condenser out and you here a clanging sound. That’s the sound of the radiator bolts falling into the skid plate. Solution: Magnet zip tied to a painting stir stick.:yay:
    Pay attention to your can tap: If it has a point for piercing cans you may need the blue adapter for the new cans they have now.
    I had bought the adapter over the course of the winter but forgot I had it, My pointed can tap would only work in the exact spot by twisting is slowly while looking at my low side guage. That had me stumped. It never dawned on me until I was done and putting away my tools and found the blue adapter on my work bench.:crazy:
  20. May 18, 2020 at 12:15 PM
    #40
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Perhaps the humidity is higher now? It will make a difference in supply temp.
