New Adjustable rear lift shackles for 1st gen's!
Discussion in 'Toytec Lifts' started by Toytec Lifts, Jun 5, 2013.
  1. Jun 5, 2013 at 12:20 PM
    Toytec Lifts
    Toytec Lifts [OP] Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    http://toyteclifts.com/index.php?pa...tegory_id=122&option=com_virtuemart&Itemid=72
    We now have rear height adjustable shackles for 1st gen Tacoma's available! These share a similar design to our old 2 inch shackles with 2"x3/8" steel legs, heavy-duty cross member welded in for extra support, and zinc plated for a long lasting finish. The height can be set at 1, 1.5, or 2 inches of lift.
    The 1 and 1.5 inch setting will require some minor trimming on the stock bumper brackets for proper clearance.
    Shackles installed on the 2 inch setting
  2. Nov 12, 2013 at 7:11 AM
    bluebr65
    bluebr65 Active Member
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    Will these require new extended rear struts even on the 1" or 1.5" setting?? I'm about to order some for the rear and currently have an all stock setup with new oem leaf springs installed. I just don't know if installed the longer shackles will necessitate longer rear struts.... thank you so much for any help, I know this is an old thread I just hope someone sees it.
  3. Apr 16, 2016 at 8:20 PM
    Nicklovin
    Nicklovin Just Keep Swimming Swimming
    Nick
    HB, CA
    04 Brorunner & 01 Mall Crawler
    Copious amount of horsepower gains through stickers, decals and devil horns
    @ToyTec Lifts could you tell me the difference between using shackles over add a leaf for a rear lift? Feel free to pm me at your convenience
  4. Apr 22, 2016 at 11:06 AM
    Toytec Lifts
    Rocky Mountains
    Nick,
    The AAL will firm up the rear spring pack a little which is not necessarily a bad thing since most Tacoma's have a weak rear spring. The shackles will not add any support to the spring pack so if you do have any extra constant weight you are going to be running, The AAL would be a better option
    Thanks
    Dylan
    CO4Runner likes this.
  5. Apr 22, 2016 at 11:35 AM
    Nicklovin
    Nick
    HB, CA
    Appreciate the info Dylan :thumbsup:
  6. Jul 19, 2016 at 9:55 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    Hey ToyTec I'm interested in buying these shackles OR your 1" non-adjustable shackles. But everything I've read says these aren't compatible with 5-lug Tacos. Can you confirm?
  7. Jul 20, 2016 at 7:35 AM
    Toytec Lifts
    Rocky Mountains
    It should work, although we have not tested our shackles on a 5 lug.
  8. Dec 16, 2016 at 8:17 AM
    BadNews82
    BadNews82 Member
    Meridian, TX
    2015 Tacoma prerunner
    Hey Toytec lifts are these available for a 3rd Gen tacoma? I've looked on your website but can't find anything. If you have a good link I could follow that'd be great thanks
  9. Dec 30, 2016 at 7:38 AM
    Toytec Lifts
    Rocky Mountains
    We actually do not have anything for the second or the third gen Tacomas as they already have a shackle system on them. Sorry about that, we do have other lift options available.
  10. Jun 15, 2017 at 7:25 AM
    Toytec Lifts
    Rocky Mountains
    Hey, @Watt maker
    The Poly bushings help reduce road noise but do not increase the comfort of the ride. What do you do with the vehicle mostly?
    The ICON mini leaf pack will provide lift while being able to increase some weight carrying abilities over the single add a leaf, but the truck can still only carry so much. The Icon progressive leaf pack is going to give you a bit of a smoother ride overall. Airbags would be the best bet when you do go for the trailer.
    Watt maker likes this.
  11. Jun 19, 2017 at 7:27 AM
    Toytec Lifts
    Rocky Mountains
    The Icon leaf pack will come with the u-bolts so nothing else needed there.
    With the TRD exhaust it can push the leaf pack into it, we had a shop here that actually rerouted the exhaust down slightly to get it out of the way.
  12. Dec 13, 2018 at 6:21 AM
    BP348
    BP348 Well-Known Member
    San Diego, CA
    2004 DC 4x4
    Is there no modification necessary at the 2" setting?
  13. Dec 13, 2018 at 7:14 AM
    BP348
    San Diego, CA
    2004 DC 4x4
    understood, but no modification to the bumper bracket correct?
