New Air Filter and Bad MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flatlander, Aug 28, 2009.
  1. Aug 28, 2009 at 11:32 AM
    ToyTime
    ToyTime New Member
    Alberta, Canada
    '06 SR5 SL - DC LB Silver
    TRD Suspension (Bilstein & 4 leaf)
    It usually takes a tank for the ECU to update and adjust mix with the MAS's new readings, you may notice a drop in MPG during this time, keep the new air filter in and give it two tanks and then watch your mileage.
  2. Aug 28, 2009 at 12:36 PM
    flatlander
    flatlander [OP] Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    Yep. I remember me and my dad taking his carb apart before we wnet on vacations in the mountains and changing the jets in it. That was on a big 400 fat block.
  3. Aug 28, 2009 at 12:39 PM
    flatlander
    Good idea. I will keep this thread in my backpocket and update in a week or two. If the mileage does not come back up, I will get an OEM one put it in and then go a couple of tanks.
    Thanks to All!
  4. Aug 28, 2009 at 1:19 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    I was blowing black soot out my tail pipe onto my rear quarter panel for 6 months, was in Toyota the other day getting service and asked the mechenic, he said it sounds like its burning rich, then out of the blue asked if I was running a K&N filter( I was) He said replace with a Toyota Filter and give it a few fill ups. Its only been a few days now but no black soot on quarter panel, I will keep you updated.
  5. Aug 28, 2009 at 7:29 PM
    flatlander
    Is a K&N a standard paper filter like the OEM? The Wix that I installed is the same type of filter as the OEM. I will keep my eye out for any sootiness.
    Thanks
  6. Aug 28, 2009 at 7:37 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    No K&N is an oiled filter. They let a ton of dirt particles into the engine. I will never let one touch anything I own
  7. Oct 5, 2009 at 6:26 AM
    flatlander
    Well I think the ecm or whatever is re-calibrating itself now. I have driven about 600 miles since putting in the new Wix air filter and the last fill-up yielded me 19.4 mpg. Pretty much all in town driving.
    I am heading out on a camping adventure in a couple of weeks so I should get some highway miles, but that will be with a canoe in the back flipped upside down so I may not get real good mpg.
    Thanks again.
  8. Oct 5, 2009 at 9:45 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    No you won't get better mileage. The engine is still working just as hard. The throttle controls airflow, not fuel flow. You don't push the throttle down as far but you're getting more air sucked in for a given throttle position because your filter is allowing more air in. The mixture is pretty constant.
    http://fuelsaving.info/power_economy.htm
  9. Oct 5, 2009 at 10:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Both.
  10. Oct 5, 2009 at 10:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep the charcoal filter. Removing it has no affect on the engine.
  11. Oct 5, 2009 at 10:33 AM
    Rollinn
    Rollinn Well-Known Member
    Vegas
    06 Prerunner sport
    Icon 2.5 c/o,TC uca, bhlm mod, nav, etc etc
    hang on here guys, lets get a consensus about this k&n filter deal here.. Who thinks k&n filters produce better fuel mileage/perf/and longevity vs a paper replacement..
    Basically who thinks k&n is worthy of being used and who thinks they are worthless and why??:confused:
  12. Oct 5, 2009 at 10:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont like them, as out here, they let alot of dirt into the engine. Also, no filter id gonna make a dramatic change in MPG. The engines pumping loss is mainly due to the throttle plate being mostly closed when driving. Its the largest restriction in the intake tract. Also, givent the large surface area of the filter, then engine isnt seeing it as a huge restriction, even under WOT.
