New Air Filters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CrsnHyns, Dec 15, 2016.
  1. Dec 15, 2016 at 12:23 PM
    CrsnHyns
    CrsnHyns [OP] Cock-A-Doodle Carson
    Carson
    Gastonia, NC
    2013 White Tacoma TRD Sport
    I went and got my free oil change at Toyota and they asked if I wanted to pay for a new air filter and a new cabin filter and I told them no. They were going to charge me $70 and I knew that I could get it done myself for half of that. I am not sure where to get a cabin filter from but is this a good air filter for the truck http://www.autozone.com/external-en...mance-air-filter/576195_0_20339?checkfit=true . It says it is able to be washed and cleaned. Is that worth it or should I just buy the basic filter for $20.
  2. Dec 15, 2016 at 1:26 PM
    uwu
    uwu Well-Known Member
    You can give your cabin an extra 5-10hp with the K&N cabin air filter :)
  3. Dec 15, 2016 at 1:34 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    The K&N some people say lets in more fine particulates then paper. Actually I think its been proven to do that... But it will pay for itself with like 2 or 3 filter changes. Especially if you live in a dusty area. As for cabin filters, any brand will do. walmart sells them for about 14 bucks.
    CrsnHyns[OP] likes this.
  4. Dec 15, 2016 at 1:49 PM
    CrsnHyns
    Carson
    Gastonia, NC
    I didn't even notice it said that it improved HP, I was just looking at the "reusable" feature. I was just wondering if it was worth the extra money since it says it only needs to be changed every 50,000 miles.
  5. Dec 15, 2016 at 2:19 PM
    azzwethinkweiz
    Tucson, AZ
    Are you kidding? Cabin filters give the best gains for the money. :)
  6. Dec 15, 2016 at 2:27 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    you will get mixed review on TW. some people, like myself, swear by only EOM products while others believe K&N provides better air flow and will last forever. I had a K&N on my old SUV and it worked fine although I probably over-cleaned it.
    honestly, it's personal preference.
  7. Dec 15, 2016 at 2:30 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    AFE Pro Dry is a good dry, washable, reusable filter without the oils that come on the K&N air filter. Oiled K&N's are notorious for ruining MAF sensors.
  8. Dec 15, 2016 at 5:10 PM
    doghair
    doghair Well-Known Member
    Phoenix
    2013 Single Cab 4x4
  9. Dec 15, 2016 at 7:21 PM
    flying_az
    flying_az Well-Known Member
    Scottsdale, AZ
    2014 TRD Off Road, 4X4, MT
    Old Man EMU, Avid sliders, Pelfreybilt skids, winch mount bumper & winch, 265/75-16 BFG KO2s, fiberglass tonneau cover, flexible mud flaps, locking tailgate, debadged, decals removed, breather relocate
    I live in a dusty area so I change mine when I change the oil. You can pick up a cabin air filter at any auto parts store--don't put a lot of thought into it--just get whichever one they have on-hand.
  10. Dec 15, 2016 at 8:09 PM
    Pigpen
    Dan
    Northwest Montana
    Shit. This reminds me that I need to replace my engine air filter. Where's the best place to buy a case of them? I keep buying singles from the dealer...
  11. Dec 16, 2016 at 3:07 PM
    CrsnHyns
    Carson
    Gastonia, NC
    I just bought one from autozone for like $20. There possibly can't be that big of a difference between that and the dealer one (I hope not at least)..
  12. Dec 16, 2016 at 3:15 PM
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    I use K&N for all my cars. I beleive that it has a better flow then the paper one, but not noticeable increase of power. I also have the cleaning kit.
  13. Dec 16, 2016 at 3:17 PM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    For air filters just use whatever's cheap and change them regularly.
    Unless you're boosted there's no difference in power. Even if you're boosted the difference is minimal.
  14. Dec 16, 2016 at 3:37 PM
    Pigpen
    Dan
    Northwest Montana
    Pretty sure dealer has been charging me close to $30
    OEM air filters have more surface area than aftermarket. I live in a very dusty area, even winters are dusty at times. I threw my POS K&N in the trash - I could see daylight through the holes, and it was new.
    ThatguyJZ[QUOTED] likes this.
  15. Dec 17, 2016 at 9:59 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
