New alternator, won't charge battery.
Discussion in 'Technical Chat' started by Alleycat62, May 23, 2021.
  1. May 23, 2021 at 5:51 PM
    Alleycat62
    Alleycat62 [OP] Member
    Alice
    2007 Tacoma pre-runner
    None
    I have 2007 Taco. 4 door pre-runner.
    My new generator won't charge my battery. Fuses good @ battery 8 months old. Any suggestions?
  2. May 23, 2021 at 6:01 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How do you know its an alternator issue? Regardless take a voltage reading across the battery terminals with the truck running, it should be above 14 volts. Less than 14V, its an alternator issue. Check the accessories belt, it could be loose. The battery terminals could be corroded. Cables could be bad.
  3. May 23, 2021 at 6:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've seen batteries last 10 months and I've seen batteries last 10 years. I wouldn't rule out a bad battery just because it is only 8 months old
    Key-Rei likes this.
  4. May 23, 2021 at 7:10 PM
    Alleycat62
    Alice
    None
  5. May 23, 2021 at 7:14 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Have you checked all your connections?
    If the battery load tests okay (not the silly little trickle check that auto parts stores do, those are like 50/50 on accuracy) then it shouldn't be your battery.
    My guess is (Battery failure aside) something isn't plugged in all the way or a wire has been broken by an animal or other.
  6. May 23, 2021 at 7:17 PM
    Alleycat62
    Alice
    None
    Alternator went out, with all the usual suspects. All kind of lights going off, radio on and off, finally quit running on expressway. Battery cables good, posts clean. Voltage check. All shows alternator needed. Put new alternator, new belt. Won't charge battery. Everything checked..getting new battery tomorrow eventhoug it's only 8 months old.
    Hopefully that's it.
  7. May 23, 2021 at 7:20 PM
    Alleycat62
    Alice
    None
  8. May 23, 2021 at 7:24 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Voltage regulator
  9. May 23, 2021 at 7:25 PM
    Key-Rei
    Key
    Florida
    I thought that was built into the back of the alternators?
    Wyoming09 likes this.
  10. May 23, 2021 at 7:27 PM
    Alleycat62
    Alice
    None
    Battery had full charge, drove it for short time. The lights on dash started acting up again. Went from 14v to 11v , won't. The battery charging light on dash doesn't show either.
  11. May 23, 2021 at 9:11 PM
    Key-Rei
    Key
    Florida
    The battery light on the dash should only come on when an issue with the charging system is detected.
    Where did you get the alternator?
  12. May 23, 2021 at 10:54 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Check all fuses . Gauge fuse blown can cause alt to not charge
  13. May 23, 2021 at 11:14 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    alt-s fuse and the main battery fuse. both of these can cause no charge.
    if the alternator was replaced without disconnecting the battery, good chance the main fuse blew.
  14. May 25, 2021 at 2:54 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    In this day failed alternator out of the box.
    But wait it is new it can`t be bad like a 8 month battery.
  15. May 25, 2021 at 2:56 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    They have been since the eighties for the most.
    Then the replacement cost may as well get the complete alternator.
