New amp
Discussion in '3rd Gen. Tacomas (2016+)' started by Dr. Emmett Brown, Nov 7, 2019.
  1. Dec 5, 2019 at 8:40 PM
    #41
    SpeySquatch
    2016 TRD OR DCSB
    C4Fab LoPro, BAMF Sliders, Adj. Ext ADS, 4.88's, OVTune
    I was thinking of doing this because I re-did all my factory speakers with the Rockford Fosgate Prime component set that has the inline crossovers. I’m not sure the OHM impedance would work, but this sounds like it could definitely make them sound a hell of a lot better. I like music like Tool and hard rock with well composed drum solos...blah blah....and the factory head unit doesn’t sound like it gives the new album quite the justice it deserves
  2. Dec 5, 2019 at 11:25 PM
    #42
    Roldy
    Roldy Member
    Harry
    2017 Tacoma TRD
    TRD Pro Grille BFG KO2 265/75/16 K&N Cold Air Intake Bed Mat 35% Front Windows Tint
    Hey Op, I recently installed the Kicker Key Amp 180 and it is fantastic! There's a great writeup on it as well on this forum asking for wiring help. As long as you get the metra harnesses, you won't have to splice any factory wires at all. The other great thing is the amp can sit behind the headunit.
    Tekpnw likes this.
  3. Dec 6, 2019 at 3:07 AM
    #43
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    For the key amp you need battery power
  4. Dec 6, 2019 at 4:31 AM
    #44
    TacoSupremo19
    TacoSupremo19 Active Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
  5. Dec 6, 2019 at 5:38 AM
    #45
    fiftyxp
  6. Dec 6, 2019 at 5:47 AM
    #46
    RX1cobra
    RX1cobra Well-Known Member
    It'll make a huge difference. I've read the kicker key is slightly better but I got the power pack for 99 bucks so couldn't pass it up.
    It's the reason I did. Didn't feel like running separate power to the amp. And both the kicker key and alpine power pack don't require it. Fit right in the dash. Easiest amp install and makes a big difference.
    SpeySquatch likes this.
  7. Dec 6, 2019 at 5:54 AM
    #47
    Tarvis
    Tarvis Well-Known Member
    Travis
    2018 Metallic Gray SR5 Double Cab
  8. Dec 6, 2019 at 7:05 AM
    #48
    RX1cobra
    I think you have it even easier. No wiring at all. Since you have an Alpine headunit it plugs into the back of the stereo and you're done.
  9. Dec 6, 2019 at 7:06 AM
    #49
    Tarvis
    Travis
    Thats what I was thinking. I'm not sure how the speaker wires will tie in though, and can't seem to find any installation videos since it is new. Will it just use RCA cables?
  10. Dec 6, 2019 at 7:55 AM
    #50
    RX1cobra
    I don't know for sure since I have the stock head unit. Mine just wired inline. Took about an hour to make the harness and plugged right in.
