new and hard to shift,lugging
Discussion in '4 Cylinder' started by old dad, May 9, 2010.
  1. May 9, 2010 at 7:19 PM
    old dad
    old dad [OP] Well-Known Member
    mark
    sc
    tacoma pickup
    n/a
    My tacoma is a 2010 reg cab,2x4, manual, when making a turn right or left, in 2nd gear, the engine lugs some, so I try to shift back to 1st, it is hard to get into first while rolling, I'm at a speed that is too low for 2nd. Is this normal?
    mark
  2. May 9, 2010 at 8:12 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    My 09 does that, Anything over 10 mph its hard to shift back to first...buggs the shiet out of me.
  3. May 9, 2010 at 8:14 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I guess it depends on how slow you're going in the turns. Mine lugs sometimes in turns but I have larger than stock tires so it's expected. I would think that if you're around 15 mph or above there shouldn't be too much lugging. I don't think there are any sychros on 1st gear so you can't downshift to 1st unless you're stopped or very close to it.
  4. May 9, 2010 at 8:16 PM
    Apple X C0re
    Apple X C0re Atomic Punk
    Josh
    Franklin, NC
    01 Tacoma SR5 4x4
    De-badged, MetalMiller grille emblem, brush guard, K&N Intake, Thrush tube, Black euro tail lights, Various scratches, Cobra 29LTD CB with custom echo board, 10" sony subwoofer with MTX amp, Black low-profile tool box, 5% tint all around.
    press clutch, wind up motor a bit, downshift. :thumbsup:
  5. May 9, 2010 at 8:27 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    same thing happens with my 99 :/
  6. May 9, 2010 at 9:47 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    "It's Normal" - Toyota
    http://www.tacomaworld.com/forum/2n...throttle-manual-transmission.html#post1687808
    Same here BTW, makes traffic extra fun.
  7. May 24, 2010 at 9:14 AM
    taco G
    taco G Well-Known Member
    van isl bc
    2010 tacoma sr5 2.7L silver 4x4
    same thing happens to me
  8. May 26, 2010 at 1:53 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    how many miles u got? after about 2K my tranny loosened up a bit.
    first and second are very far apart so you kinda need to revmatch to get it in smoothly
    i usually just take turns that are up to 13 mph in first anyway...you get used to it lol
  9. May 26, 2010 at 9:34 AM
    Barnone
    Barnone Guest
    Hey old dad from another old dad,
    Remember back in the old days with non synchronized first gear or even further back with no synchronizer on any gears when we had to double clutch to shift gears?
    Does double clutching help getting it into first gear?
    I'm curious because I'm considering getting a new regular cab 4x4 which only come in stick.
    Thanks,
  10. May 26, 2010 at 11:47 AM
    old dad
    mark
    sc
    tacoma pickup
    n/a
    really not sure that I hadn't that already, but remember doing it for years in the triumph spitfire,,will try again and let you know,,
    mark
  11. May 26, 2010 at 4:06 PM
    Barnone
    Barnone Guest
    I was thinking synchronizers but the more I think about the problem happening in turns, then maybe frame or body flex is causing the problem.
    Maybe the flex is binding the shift mechanism?
  12. May 26, 2010 at 8:20 PM
    numbah57
    kahai
    Maui, Hawaii
    Mine does it going straight to!!
  13. May 27, 2010 at 6:45 AM
    Barnone
    Barnone Guest
    That's a horse of a different color then because I was under the assumption that it only occurred while turning.
    Could you try putting the trans in neutral, letting the clutch out, then depressing the clutch, and then trying to put it in first gear (double clutching)? That what we had to do in the old days when first gear didn't have synchronizers.
  14. May 27, 2010 at 10:14 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    lol mine too...i dont' think it has anything to do with turning lol
    you can double clutch but you still have to rev match. it goes away though after awhile...these trucks seem to take a really long time to break in.
  15. May 28, 2010 at 5:24 AM
    Barnone
    Barnone Guest
    So double clutch/speed matching helps. Sounds like a synchronizer problem. No good on Toyota if breaking in helps because breaking in means wear solves the problem. Modern vehicles shouldn't require breaking in.
    Wonder if a lighter weight/synthetic gear oil would help?
  16. May 28, 2010 at 5:54 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Have found that mine won't lugg out so bad, if when starting to accelerate in 2nd after shifting from 1st, don't give it much throttle for a second or two or until the tach reads 1300 RPM or so. Works for me. Also I just rev it out to 2500 or so if I have to turn right, immediatly after taking off.
  17. May 29, 2010 at 9:41 AM
    taco G
    van isl bc
    The trucks now seem to be alot bigger than 1 gen all we gotta do is giver some gas lol
  18. May 29, 2010 at 9:13 PM
    TacoVerde
    TacoVerde Well-Known Member
    Sean
    So Cal
    09 PreRunner
    URD short shifter, OBX racing pedals and titanium/carbon fiber shift knob, Rear speaker mod, Taco bed mat, Bed extender, taco door sill protectors, Black TRD floormats, AFE stage 2 CAI, Doug Thorley Header and Catback, Glassworks Unlimited front fenders/bedsides, Engage front LT kit,2.5x8 King co's with resi's, dj straps
    the first gear downshift really sucked when i was learning to drive manual, but i found i have to be going about 5 or under to pop it into first
