New and improved way for "Radio ON after IGN OFF"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by arvizu9618, Aug 22, 2011.
  1. Aug 22, 2011 at 1:36 PM
    arvizu9618
    arvizu9618 [OP] Well-Known Member
    RT
    PHX AZ
    06 D-Cab SPORT SB
    Map/Dome Light on same time, Beep onLock, Anytime DTRL's, Fog Light on any time, Cockpit lights in footwells, night light in cup holder and rear of console, Radio ON w/ ignition off (off with timer), 3157 socket for rear turn signals (BRIGHTER), Reverse Light Mod, Tap light in console and engine bay, removed screen prior to MAP sensor, Blacked out lower valance, badges, center caps and door handles, Added door sill plates, JVC-KDHDR50 Head unit (HD Baby), Tinted exterior lights, Borla Exhaust.
    I discovered a more simpler way to do this:
    Parts/tools needed:
    1. 3-4" of 20g jumper wire, expose some copper on both ends
    2. Fuse puller
    Steps:
    1. Pull 7.5A and 20A PWR WDO fuse
    2. Insert jumper wire from your 7.5A ACC fuse slot to the 20A PWR window fuse slot.
    3. Reinsert fuses, test
    In my case, I ran jumper to the P RR P/W fuse
    Works like a champ, 21 steps down to three.
  2. Aug 23, 2011 at 11:28 PM
    arvizu9618
    RT
    PHX AZ
    06 D-Cab SPORT SB
  3. Aug 23, 2011 at 11:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    good find!
  4. Aug 23, 2011 at 11:35 PM
    arvizu9618
    RT
    PHX AZ
    06 D-Cab SPORT SB
    BTW, Radio will turn off when you open the door and or timer runs out :)
  5. Aug 24, 2011 at 3:31 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I think they make fuse block taps so you don't have to stuff wire under the fuse.
  6. Aug 24, 2011 at 6:27 AM
    arvizu9618
    RT
    PHX AZ
    06 D-Cab SPORT SB
    @skytower
    This is true, I think they are called "add-a-circuit" and can be found at Vatozone or O'Really @ about $4 a pop.
  7. Aug 24, 2011 at 6:51 AM
    TacoTabe
    TacoTabe Well-Known Member
    Kevin
    Northeast PA
    '93 pickup
    subb'd for future reference
  8. Aug 24, 2011 at 7:09 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    There is something to be said for simplicity. :) How long is the timer on the window circuit? I thought it was only 30 seconds. :notsure:
  9. Aug 24, 2011 at 7:15 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Mines 10 I think. It was that in the first gen and the tundy.
  10. Aug 24, 2011 at 10:53 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Or until a door opens, the way I usually lose it.
    So find another circuit to tap that's not tied to the ignition switch I guess?
  11. Aug 24, 2011 at 11:26 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica
    Icon, AllPro, Total Chaos, ARB, BAMF, Relentless, SCS, Cooper, Leer,
    you went so far as to do it all right then wrapped a crimp in tape. just solder and heatshrink its easier than wrapping tape around and between a bunch of wires. the next owner of your truck will thank you
  12. Aug 24, 2011 at 11:42 AM
    TruthInLies313
    TruthInLies313 Well-Known Member
    Blaine
    Texas
    05 V6 TRD Sport DC
    Tinted, 5701 Viper Alarm Electric Start, 6 Inch Fabtech Lift, 17'' XD Hoss Rims, K&N 77 Series Intake, BHLM, Black Emblems, Color Matched Dash rings, 2 JL 10's, Pioneer Double Din Head Unit
    Or just use your remote start like me :D But awesome find for people that don't have it.
  13. Aug 24, 2011 at 11:48 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Very cool. A small mod but one that I will definitely do.
    Thanks for taking the time to figure this out and for sharing with us!
  14. Aug 24, 2011 at 5:07 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    This is nice... down and dirty, simple install.... I might recommend soldering the wire to the fuse, or something similar to prevent it from coming loose and shorting, then I would think it would be safe enough for sticky.
    I want someone to make one so that the headlights turn off with the passengers door opened as well.
    I almost drained my battery one day because I started the truck from the passengers side, and shut it off just the same. Headlights were on, and since the drivers door didn't open, they stayed on.
  15. Aug 25, 2011 at 2:23 AM
    arvizu9618
    RT
    PHX AZ
    06 D-Cab SPORT SB
    @wecoyote
    It's a nice little thing to have, especially for us guys who kind of get out of our trucks a little slower than you young'uns.
    The song you're listening to doesn't get disrupted as would having to put the key in ACC.
  16. Aug 25, 2011 at 5:31 AM
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
    Cool idea.........It works but only lasts 35 seconds in my truck..........I may put a switch from a constant fuse to the radio to keep it on w/ the key out..(just dont forget about it) lol
    Otto
  17. Aug 25, 2011 at 11:38 AM
    Fire Taco Fighter
    trd
    Whats the purpose of a few seconds?........I can see having it on for a few minutes while getting gas or picking up your kid.My old F-150 stayed on for a few minutes..was cool.
    Otto
  18. Aug 25, 2011 at 12:53 PM
    arvizu9618
    RT
    PHX AZ
    06 D-Cab SPORT SB
    This is the exact location where I ran the Add-a-circuit.
    I T-tapped the pigtail end of the A-A-C to the gray wire on the remote mirror harness to avoid having to take the radio out. (1st attachment)
    The gray at remote mirror is the same as Radio ACC.
    I put a 7.5A mini fuse on the pigtail slot and a 20A mini fuse on the other.
    Jumper has been removed from ACC and PWR WDO fuse.
    Add-a-circuit MUST be installed the exact same way as shown in the pic because if it was flipped around it would bypass the fuse. (2nd Attachment)
