New ARB 100% duty cycle air compressor
Discussion in 'Off-Roading & Trails' started by 4x4Runner, Apr 11, 2011.
  1. Apr 14, 2011 at 3:50 PM
    DevL
    DevL Well-Known Member
    Yeah this ARB Makes the Oasis look like a joke huh? Costs less and you can wire multiples to have more output at less weight than the Oasis all with less Amp draw AND less money. Makes you wonder why anyone would be dumb enough to buy an Oasis with this thing coming out...
    Less $
    Less weight
    Less bulk
    Less current draw
    More output @ 0 PSI
    More outout @ 100 PSI
    It is pure awesome sause!
  2. Apr 14, 2011 at 5:45 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
  3. Apr 14, 2011 at 6:02 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    1.6 CFM
    19 amps
  4. Apr 14, 2011 at 6:07 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Derp..?
    * High efficiency design consumes only 56 Amps at maximum air flow.
    Edit: I now see the chart... thats miss leading....
    I would buy one!
  5. Apr 14, 2011 at 6:27 PM
    DevL
    It would take 3 of those to come close to competing with ONE of the ARB compresors. It would still lose when you ran 3.
    3 of these ARB compessors beats one Oasis by a small amount.
    If you plan on running a single Viair you will be waiting a LONG time once you bleed your air canister down on your first tire air up.
  6. Apr 14, 2011 at 6:48 PM
    TRICOMA
    Tri
    Carlsbad, CA
    Got it. So the ARB comes ready to go. No tanks or anything else? I just need it up air my tires when out on the trail. If I get a front locker I would want to use it as well.
  7. Apr 14, 2011 at 7:00 PM
    DevL
    Tanks are usefull for a number of things... tying in the output of multiple compressors, allowing a part time duty compressor to give pressure for an extended period due ot the sotred air, offering more volume of high pressure air on tap than the compressor can provide, allowing a common source for multiple ait devices to run off of (air horn, lockers, impact gun, etc.)
    For your proposed use you need a manifold kit to use with a locker. You dont need a air tank for filling tires or running tools. It will do the first tire in the same amount of time as a Viair plus tank due to the stored air in the tank... after that the remaining tires will get aired up over 3X faster. I predict this will make the older, smaller compressors obsolete.
    Of course now that I see the 68 AMPS it can draw at 150 PSI I see its not as efficient as I thought. The constant duty Oasis only draws 180, making it a TINY bit more efficient than running 3 ARB compressors. Still... I think dual ARBs would suit almost anyones needs and everyone needs the outout of the single. The other compressors are just SOOOOOooo slow once their tanks get emptied.
  8. Apr 14, 2011 at 7:08 PM
    TRICOMA
    Tri
    Carlsbad, CA
    Thanks for the help. I just hate waiting forever to fill up tires when I finish out in the desert or the trails. This makes things a lot easier.
  9. Apr 14, 2011 at 7:08 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    That is one great sounding air compressor. It is over double of the cfm of mine but also more amp draw by 16 amps over mine though. As long as you have the power for it that wouldnt be a problem. I have the Viair setup that puts out 2.68 cfm and mine came with the tank and wiring for $369.00 from Amazon. Mine can take off all lug nuts running a 3/8" ingersoll titanium impact without having the air compressor come on to fill the tank back up. So not to bad. Also mine is only 33% Duty cycle. So the ARB is 100% which is quite a bit better.
    The good side of the ARB is not half to run a tank though which is good for weight savings and room. My aircompressor is made in China which is not a plus compared to the ARB. If I had to do it again I would go for this ARB. But mine works quite well and I have had it for 2 months now and use it for rotating my tires and offroading.
  10. Apr 14, 2011 at 7:21 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I ran my little ARB for 25min the other day. 4 tires {35s} from 14psi to 45psi. 5 to 6 min a tire. And you could boil water on the damn thing. I really just wanted to see what it was made of:D ARB FTW
  11. Aug 1, 2011 at 11:18 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I didn't want to post a new through about this so I figured I'd bump this one - Search FTW.
    Anybody have one of these yet? I'm in the market and looking for a good portable compressor.
    The biggest tires I would go with are 33's and that won't be for a long time. I simply need a good, dependable compressor to keep in the truck that can air up a couple 31-33" tires without having to wait.
    I am close to buying the Viair 400P off Amazon but I love ARB and might be willing to spend the extra dough if I can get some good, real-world reviews of it.
    Thanks much, cheers!
    Fink
  12. Aug 1, 2011 at 11:28 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Have you looked into C02? i love my C02 set up I can air up my 33/12.5's from 12psi to 35psi in 18sec a tire if your looking at a big tank setup like the Viair consider C02.
  13. Aug 1, 2011 at 11:47 AM
    Fink
    Orlando, FL
    I've been looking at CO2 for years and love all of the setups, but I think it's more than I need.
    I'm just looking for something 100% portable that I can take with me in my truck for commuting, in my girlfriends car for trips, etc...
    If I was looking at a true on-board, vehicle-mounted setup...CO2 is the direction I would go. Some of the setups I've seen are insane.
    Fink
  14. Aug 1, 2011 at 11:50 AM
    JLee
    Jerry
    Grass valley CA
    Yeah I've seen the Viair P i don't know if it's the 400 but it was a pretty good little portable compressor slow but it gets the lob done.
  15. Aug 1, 2011 at 11:55 AM
    #35
    Fink
    Orlando, FL
    I definitely won't try to win any races with it but in a pinch, it seems like it would be dependable and more than capable for what I need.
    For $190...it seems like a good deal.
    Thanks for the advice, by the way!
    Fink
  16. Aug 1, 2011 at 11:56 AM
    #36
    JLee
    Jerry
    Grass valley CA
    Yeah no problem.
  17. Oct 2, 2011 at 11:32 PM
    #37
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    BUMP!
    Anyone have one of these ARBs yet?? A good review would be great! im lookin into gettin OBA
  18. Oct 5, 2011 at 12:37 AM
    #38
    Blackdawg
    Monte
    Wyoming/St. Louis
    On one??
  19. Oct 5, 2011 at 3:51 AM
    #39
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I bought one, but couldnt find a reasonable place to install it. I wanted to keep it under the hood, and I have a 2010 Sport so the obvious place the passenger wheel well is not usable due to my brakes control box. If you DONT have that crap on the passengerside wheel well, it will fit perfectly. It would also fit behind the rear seats in a double cab, but that would require extending wires and venting it outside if running an arb locker.
    After a week of trying to install it, I finally gave up and ordered the smaller ARB compressor. The CKMA12. This thing is a lot smaller so installation was a joke. I mounted it behind my fuse box. Airing up tires is a lot faster than I expected.. I dont have any numbers, but I aired way down to test it and it was similar to using the air pump in the parking lot of a gas station.
    And as far as wiring these up.. they are both super easy with the wire harnesses included. I did find that mine has a longer wireharness than the CKMTA12 did.
  20. Oct 5, 2011 at 7:18 AM
    #40
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks a lot man! good info. i would be curious as to how they would preform side by side.
