New ARE Camper Shell What the hell is this?
Discussion in 'Tonneau Covers, Caps and Shells' started by Woggs1, Jan 23, 2011.
  1. Jan 23, 2011 at 10:49 AM
    Woggs1
    Woggs1 [OP] Member
    San Francisco, ca
    2011 regular cab 4X4 Silver
    I just got a new ARE MX shell put on yesterday, and this morning I found this:
    It looks like a very rough cut. From inside there is this big hole that will probably leak:
    Is this normal for an ARE camper shell? I paid $1600 for this and would hope there would be no leaks. And that rough cut is ridiculous. Does anyone know if this is how ARE Campers come?
    Thanks in advance for any insight.
  2. Jan 23, 2011 at 10:54 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    Maybe they cut it to fit your truck better??? Did you watch them put it on? I've had a couple of caps and they never looked like there.go back to the dealer and freak out.ask to see another cap and compare if they try to jerk you around
  3. Jan 23, 2011 at 11:11 AM
    whiskey101
    whiskey101 Well-Known Member
    Clarksville, TN
    '17 Super White 4WD TRD Off-Road
    Leer 100XQ
    Not sure what the picture shows, but I can tell you that unless you put some silicone in the corners, it's gonna leak.
  4. Jan 23, 2011 at 11:15 AM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    the cut looks normal. however the window needs some tweaking.. bring it back the the dealer.. i can see some light through my cap where the window and tailgate meat, but it doesnt leak
  5. Jan 23, 2011 at 11:21 AM
    paintdiddy
    shithead
    silver bullet
    If it was normal,wouldn't the edge be silver like the cap?it looks like it was cut afterwards to fit
  6. Jan 23, 2011 at 11:37 AM
    Jefenator
    Jefenator Taco Truck Noob
    Oregon
    2010 2WD Reg Cab Stick Shift
    Picture 1, you'd think they could put some moulding over that or something. On the other hand, I'm pretty utilitarian about my rig so interior cosmetic ugliness wouldn't bug me TOO much. (There are some rough-looking cuts on mine, BTW. But without carpeting, it looks more like they belong. ;))
    Picture 2, I'm not sure where/what that is.
    IME the biggest leak spot is at the front. The front lip of the bed is lower than the sides and it's tricky to get a good seal in those corners. The "pro" installer messed that up & I had to redo it. (The camper retailers in this area seem to be pretty seedy, so I decided it was best to do any future work myself.)
    BTW, it looks in photo #1 like the camper shell is lodged as far forward as possible. Just make sure there's at least 1/4" clearance between the shell and the cab. If not, the shell might bash a dent in the cab when you drive over uneven terrain. (Don't ask me how I know...)
    Good luck with everything.
  7. Jan 23, 2011 at 12:04 PM
    Woggs1
    Woggs1 [OP] Member
    San Francisco, ca
    3twenties and a10 likes this.
  8. Jan 23, 2011 at 12:09 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Here's supposed to be window over that I believe. That is a bit odd.
    Caps are very cheaply made my a.r.e . was by far the best... both sides look the same....
  9. Jan 23, 2011 at 1:18 PM
    whiskey101
    Clarksville, TN
    Leer 100XQ
    I went out and looked at mine. It is exactly the same as yours, or atleast pretty close to the same. Your gap looks just a tiny bit wider than mine.
    edit to add:
    On the upside, your truck looks sweet with the cap!
  10. Jan 23, 2011 at 1:41 PM
    Woggs1
    Woggs1 [OP] Member
    San Francisco, ca
    Thanks for the info, I guess I shouldn't be too worried if that is the way they come. I did notice that one of the rivets is only 1/2 way in, maybe that is the problem. I like the way it looks, not bad for a standard cam IMO.
  11. Jan 23, 2011 at 1:41 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    My ARE CX looks like your pictures. I don't really notice if water comes in when it's raining, but it does in a carwash. I've got the oem bed mat so unless it's from a carwash the water runs under the mat. I'd still take it back and see what they say. FWIW, I've read complaints that both ARE and Leer's quality and customer service has gone down in recent years.
  12. Jan 23, 2011 at 1:48 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Take it back and get a SnugTop
  13. Jan 23, 2011 at 1:56 PM
    Jefenator
    Oregon
    That trim part at the bottom of the swinging glass seems awfully narrow. Not a huge deal I suppose. (Rain would mostly get on the lip of the tailgate.) I have a gap at the same spot, but it's much narrower - about 3/16". Definitely can't fit a finger in. That section looks like it could be fairly easily replaced.
    Aside from that, the rig does look sweet. I'd love to have that high ceiling and those swing-up side windows. :)
  14. Jan 23, 2011 at 2:02 PM
    surfrat
    LI, NY
    the dealer should be able to play with the hinges on the window.. seems like its closer on the drivers side.. might just need to be centered..also they did a horrible job with the wiring, you should be able to clean that up yourself easily
  15. Jan 23, 2011 at 2:21 PM
    Skywalker6
    Skywalker6 Goldmember
    Colorado
    Big Ol' Juicy Double
    Just checked my CX and it has the same gap. But just like Jefenator said, not big enough to get a finger through. The bottom trim piece could be replaced with one that was cut to a tighter fit. I had a CX for an F-150, and it didn't need a trim piece at the bottom. Initially, I thought it was a pretty cheap looking fix, but it works fine. I haven't had any major leakage issues, but I also have not been in a lot of rain yet either; it's keeping more water out than it's letting in. Good luck. Keep us posted.
  16. Feb 14, 2011 at 3:29 PM
    twinomad
    twinomad Active Member
    MC
    85937
    09 Access,customsound,4.0,6speed,winch
    front/rear detachable winch, custom sound 4 inch lift, 265/75 tires camper shell color match
    YES my are is exactly like that very rough and I am looking for a better made hi rise model
  17. Feb 23, 2011 at 7:11 AM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    I got quoted 1300 otd for the same cap, what options do you have for it? Looks awesome
  18. Feb 23, 2011 at 7:36 AM
    Switchback
    Switchback Well-Known Member
    22 Mag Grey SR 4wd SX
    i have the same exact setup OP, and it looks just like yours. zero leaks on mine. great cap.
  19. Feb 24, 2011 at 6:55 AM
    Woggs1
    Woggs1 [OP] Member
    San Francisco, ca
    I have both windoors and the fold down front
    slider
  20. May 1, 2011 at 10:36 AM
    zuckdan
    zuckdan Well-Known Member
    Evergreen CO
    2011 DC SR5
