NEW BATCH! Custom Bracket - Vertical Install ARB Twin Compressor
Discussion in '3rd Gen. Tacomas (2016+)' started by MJ_PDX, Jun 23, 2017.
  1. Jun 23, 2017 at 5:13 PM
    MJ_PDX
    MJ_PDX [OP] Well-Known Member
    2016 TRD OR Access Cab Blazing Blue Pearl
    UPDATE: 1/3/19
    As of today I have 15 people on the list!
    I will be starting production process later today and it usually takes a couple weeks to complete, so I hope to have parts available by the end of the month.
    To those that saw my previous posts about installing the ARB twin compressor vertically using a Slee Offroad 2nd Gen (<2015) mount and custom bracket and inquired about replicating my set up.
    Just to be clear (because some people have misunderstood), This is NOT the entire compressor mount, it is just a custom bracket I made to replace the upper bracket in the Slee Offroad 2nd Gen. compressor mounting kit (http://www.sleeoffroad.com/products/products_air.htm #SOK001) to adapt it to work on the 3rd Gen. Tacoma.
    You will need to have/get the Slee kit for this to work. Installation is per Slee instructions until you get to upper bracket and then just use mine instead of theirs.
    I have had a small batch of brackets made up (laser cut, powder coated, Etc.) for any that are still interested.
    As they are a bit of a niche item and the small batch size, Cost will be $28 (including shipping) to cover my expenses.
    Let me know if you'd like to be added to the list.
    PM me for more information.
    Current Pre-Order list so far:
    1. @seattle_taco
    2. @chaotic_taco
    3. @Charlesp461
    4. @KanPanic
    5. @Tynan
    6. @johntoyota
    7. @Taco.Dan
    8. @CaboTom
    9. @NotBabyFace
    10. @scary_larry
    11. @PcBuilder14
    12. @mtrman86
    13. @taco7
    14. @VooDoo Fi
    15. @PNUT
  2. Jun 23, 2017 at 6:19 PM
    Sandman614
    Sandman614 Snarky TWSS elf, Travis #hotsavannahdotcom, LRGRNR
    Tim
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    :gossip: maybe put "Custom Vertical Mount" in the title. I thought this was gonna be a thread asking if the compressor can be mounted vertically, which obviously it can.
  3. Jun 23, 2017 at 7:09 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Mobtown Offroad
    Hmmm. PM inbound
  4. Jun 25, 2017 at 1:21 PM
    solscooter
    Brian
    Minnesota
    Mobtown Offroad
    Payment sent
  5. Jul 10, 2017 at 1:19 PM
    ShemRahBuck
    ShemRahBuck Well-Known Member
    Buck
    NOLA
    2017 TRD Pro
    Paid. Thanks
  6. Jul 10, 2017 at 7:22 PM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Got mine!
    Thanks!
  7. Aug 2, 2017 at 8:48 PM
    Istan
    Istan Leave it stock they said
    Stan
    Northern NV
    2016 Tacoma DCSB TRDOR
    Can a single mount using this bracket?
  8. Aug 2, 2017 at 8:56 PM
    MJ_PDX
    My custom bracket is NOT the whole mount kit. It is just the upper bracket to adapt the Slee Offroad 2nd Gen mounting kit to work on the 3rd Gen Tacoma.
    Also, the upper bracket is only necessary if you are using the twin ARB compressor.
    Having said that, if you really want/have to use a single compressor, Slee offers a 2nd Gen single compressor mount that does mount in this same location. From what I can tell it should work without modification.
    Tynan likes this.
  9. Aug 2, 2017 at 9:19 PM
    Lwood
    Lwood Well-Known Member
    Lynwood
    16' TRD Sport DCSB
    What type of battery is that in the picture?
  10. Aug 2, 2017 at 10:23 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    35" Trepadors w/ OMF Beadlocks, Kings, OBA, 5.29s etc
    Interested
  11. Aug 3, 2017 at 7:24 AM
    MJ_PDX
    That is an Odyssey battery in a Off-Grid Engineering dual battery mount/system.
    Lwood and Korndog1284 like this.
  12. Aug 3, 2017 at 6:51 PM
    CHG2016TRD
    CHG2016TRD ADVENTURE.OVRLND explore+live+experience
    CHASE GENTRY
    TEXAS
    2016 MGM TRD OFFROAD SB
    Adventure Ovrlnd Tacoma Build Sheet ARMOR: CBI Offroad Fabrication T3 High Clearance Rear Bumper w/ Dual Swing Outs & Tables CBI Offroad Fabrication T3 Aluminum Front Bumper CBI Offroad Fabrication T3 steel skid plates All-Pro Offroad HD Sliders FRONT SUSPENSION: King Shocks 2.5" Coilovers with Compression Adjusters set 2.65" over stock ride hight Pro Comp UCAs REAR SUSPENSION: Archive Garage mid / long travel Shock Relocation Tower kit Archive Garage Hammer Shackle Hangers Mid Travel SOA+SUA OME HD Dakar Rear leaf springs/ Constant Load 661 Lbs All Pro offroad U-Bolt Flip Kit with Timbren Bumpstops All Pro Extended SS Tacoma Brake Lines Bilsein 5160 25-242379 rear left Bilstein 5160 25-242539 rear right OVERLAND GEAR: Smittybilt Overlander Tent #2783 Arq4WD 270 drivers side awning Road Shower4 -- 7 Gallon Coleman Even-Temp™ Propane Stove ARB 50 qt Fridge Freezer RECOVERY: Smittybilt Gen2 XRC 9.5k Synthetic Line winch Factor 55 1" Hawse Fairlead Factor 55 Flatlink WHEELS/TIRES: 305/70R17 Falken Wildpeak A/T3W Method Race Wheels NVs / 16x8 / 6x5.5 / 0 offset / 4.5" BS LIGHTING: XenonDepot H11 HID KIT | Xtreme HID Rigid Industries SR-Pro 20” Driving/Spot Bumper Rigid Industries SR-Pro 30” Driving/Spot Roof 90W Side Shooter LED Pods Ditch lights MISC: CBI Offroad 3rd Gen Overland Bars Rago Fabrication Bed Channel Stiffners Rago Fabrication Hood Mounted Ditch Light Brackets BAMF CMC Cab Mount Chop Brackets Roto Pax 2 Gallon Gasoline Roto Pax 2 Gallon Water Energy Suspensions Cab Mount kit Expedition Essentials Toyota Tacoma Bedside Compressor Mount STEREO: ENGINE: INTERIOR: Weathertech Floorliners Expedition Essentials Toyota Tacoma 3rd Gen USB Powered Accessory Mount (TPAM) 4 Crawler 1" rear seat lift kit EXTRAS: Prinsu Designs Studio's Cab Rack Prinsu Designs Studio Awning Mounts Midland USA MicroMobile MXT275 Midland USA 6Ddb Gain Antenna MXTA11 Midland USA X-Talker T71VP3 Walkie Talkies Midland USA Magnet Mount MXTA12 Dual ODYSSEY Extreme Series Battery 34-PC1500 Genesis Offroad Tacoma Dual Battery Kit
    im interested!!
  13. Aug 3, 2017 at 9:41 PM
    MJ_PDX
    You're on the list.
  14. Aug 3, 2017 at 10:13 PM
    Istan
    Stan
    Northern NV
    Just ordered my twin. Which slow bracket do I need in addition to this?
  15. Aug 4, 2017 at 9:08 AM
    MJ_PDX
    You'll want their 2nd Gen Tacoma twin mount (SOK001). It has additional plates/brackets to support the larger twin compressor vertically. My bracket replaces the upper brace in this kit to make it work in 3rd Gen truck. This is what is in my truck.
    ShemRahBuck likes this.
  16. Aug 6, 2017 at 2:51 PM
    Kennedyusmc
    Christopher
    2017 Cement Pro
    Another clean install.
    Really helpful to just pull your cleaner tank and air box completely.
    Otherwise easy other than dropping shit into the skid plates...
  17. Aug 6, 2017 at 3:16 PM
    MJ_PDX
    Nice! Glad you like it. Looks like you have the same setup I do... compressor, off grid engineering dual battery, hood struts...
  18. Aug 6, 2017 at 3:26 PM
    Kennedyusmc
    Christopher
    2017 Cement Pro
    Yep-
    Any suggestions for ring terminals to get this guy on the battery?
  19. Aug 6, 2017 at 3:39 PM
    MJ_PDX
    I used some large 10 Ga. ring terminals (5/16) I had left over from building the RTMR I made. I got them from Waytek Wire.
  20. Aug 6, 2017 at 5:10 PM
    JoeCOVA
    Joe
    Colorado Springs
    2017 DCSB TRD OR
    Did you install the dual battery system yourself?
