NEW BATTERY AND ALTERNATOR STILL NOT CHARGING HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lucy1stgentaco, Jul 17, 2020.
  1. Aug 1, 2020 at 7:32 PM
    #81
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  2. Aug 1, 2020 at 7:41 PM
    #82
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OK. I really have no idea what it would cost as I haven't had to purchase one in like 40 years...
    I rebuild my own when needed.
  3. Aug 1, 2020 at 7:44 PM
    #83
    BillsSR5
    bill
    2014 SR5
    I think you can get a new OEM but I think theyd probably be $500 range?? maybe imported from Japan the DENSO's sold at ROCKAUTO are REMANs, they do list a few new ones that are TYC brand and other no names which are the Chinese make more than likely
    Black97v6MT likes this.
  4. Aug 2, 2020 at 1:11 AM
    #84
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Anything that Toyota sells with a -84 at the end of the part number is rebuilt, but I would trust Toyota has high standards for rebuilds. A rebuild if done right can be just as good as a new one as long as they use quality parts.
  5. Aug 2, 2020 at 5:28 AM
    #85
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I can’t believe we are still having this conversation. I will gladly give the OP a grand for the truck and end his misery :der:
    Black97v6MT and BillsSR5 like this.
  6. Aug 3, 2020 at 11:41 AM
    #86
    Hamburgler_101
    Hamburgler_101 Well-Known Member
    Aidan
    Ramona CA
    2001 Tacoma 4WD Prerunner
    4WD Conversion
    So turns out @j4roe was correct. I drove to AZ yesterday to help out and turns out there was a problem with the 3 pin connector. Specifically the IG wire that tells the alternator to turn on was loose at the fuse box connector EA1. And the L wire responsible for turning the CHARGE light on was cut clean off. I had to drive back to CA the same day last night but I am going to re-pin the connector and replace the wires as well as shield them better so they don’t get damaged in the future. We were able to start it and I jumped the IG pin and the voltage would go up to 14.56 so once I finish the harness and ship it back to OP everything should be working again. Thanks to everyone that’s helped diagnose the issue so far!
  7. Aug 3, 2020 at 12:07 PM
    #87
    j4roe
    j4roe Well-Known Member
    Joe
    Phx, AZ
    1st Gen
    Solo Motorsports 3.5 with heimed tubular uppers, Total Chaos spindle gusset, King 8" CO, Glassworks 3'' front glass, tube bumper, 4 25w 1000L Bumper LED, 2 Rigid Pod lights, 35" Toyo Open Country AT, Fiberworx 3'' Bedsides, Deaver F55, Custom 9" Shackle, Bilstein 7100 14" 2.0 smooth body w/resi
    My research and cross reference game is TENACIOUS. Glad you guys got it. Really sorry that I couldn't have helped out directly. After I realized OP lived 50 miles from me it wasn't as realistic for me to just "swing by" real quick.
  8. Aug 3, 2020 at 11:37 PM
    #88
    Lucy1stgentaco
    Lucy1stgentaco [OP] Active Member
    Tyler
    2000 Tacoma prerunner trd offroad
    I appreciate everyone’s help in this thread! Would have never gotten to this point without all of your help, thanks so much guys and especially @Hamburgler_101 i would have been screwed if you didn’t stop by.
  9. Aug 4, 2020 at 1:29 AM
    #89
    BillsSR5
    bill
    2014 SR5
    this story has a great ending
  10. Oct 1, 2024 at 4:32 PM
    #90
    Clearwater Bill
    Billy
    Largo Florida
    I would encourage you to delete your post and make a fresh thread of your own
    Tagging onto one that ended over 4 yrs ago might not get you max attention
  11. Mar 27, 2025 at 1:06 PM
    #91
    SEL4400
    SEL4400 New Member
    SEL4400
    I seem to be having the same problem as
    Lucy1stgentaco
    Which wire is the exciter? All of the other things I have tried. I even replaced the alternator. no change.
  12. May 10, 2025 at 10:48 PM
    #92
    Tacoma lover1212
    Tacoma lover1212 New Member
    Ronny
    2008 Toyota Tacoma SR5 dark blue 2TR
    Fender flairs
    Do you still have that issue?
  13. May 10, 2025 at 10:50 PM
    #93
    Tacoma lover1212
    Ronny
    Fender flairs
    If im correct im pretty sure all of you guys have blown fuses. Don't quote me on that
