new battery fron costco story
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kahanabob, Mar 17, 2019.
  1. Mar 17, 2019 at 3:57 PM
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    so before i went to costo i decided to clean the positive battery terminal so i could do the swap in the costco parking lot and take the core in when i bought the new one. battery is 3 1/2 years old and the positive terminal has never been off. took me 15 minutes to work my way thru the corrosion and getting the terminal to spread was a bitch. the copper terminal connector is a piece of crap, very thin and bends but does not spread. after prying and twisting i finally got it off but in doing so the positive post was turning and lifted up about a 1/8 inch. i then separated the copper piece of junk from the two cables and soaked it in baking soda and water. had to change the soda and water 3 or 4 times before it stopped fizzing. that copper connector has nooks and crannies that corrosion builds up in. next time i change the battery i am going to buy a new copper connector from toyota. so there you have it, what a goat rope.
  2. Mar 17, 2019 at 6:16 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Guess you shouldnt have let it get that bad to begin with.
  3. Mar 17, 2019 at 6:35 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i cleaned the corrosion from time to time on the positive terminal.
    Lucifer1 likes this.
  4. Mar 17, 2019 at 6:42 PM
    ferntr33
    ferntr33 Well-Known Member
    Lots of corrosion on my terminals too. Looks fine while connected at a quick glance. Only when you take them off did I see all the acid corrosion.
  5. Mar 17, 2019 at 6:44 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    yea, it is all that corrosion buried inside the connector.
  6. Mar 17, 2019 at 7:31 PM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    I spray a little Corrosion X once every few years...never any corrosion, same with my airplane wing panels during annual inspection. Great stuff for all sorts of electronics...improves electrical contacts as well. Google it and keep a can on the shelf...will last for years.
    hrivera007 and shakerhood like this.
  7. Mar 17, 2019 at 7:43 PM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    Buy AGM batteries.
    Don't need to worry about corrosion or deep discharges .
    shakerhood likes this.
