New battery sure spins the engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RushT, Mar 11, 2021.
  1. Mar 11, 2021 at 5:44 PM
    RushT
    RushT [OP] Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Upgraded my battery when the old one took a dump overnight. Went with the Northstar AGM in a group 27F. 900+ CCA. Sure spins the engine fast when starting up. There shouldn’t be an issue with that?
    T-yoda and SJBrown like this.
  2. Mar 11, 2021 at 6:17 PM
    philth
    philth .
    Rods into the atmos.
  3. Mar 11, 2021 at 6:19 PM
    RushT
    North Texas
    LOL... I think.
    philth[QUOTED] and T-yoda like this.
  4. Mar 11, 2021 at 6:20 PM
    Bishop84
    Bishop84 Well-Known Member
    You're good, I have a 27F and its a satisfying sound for sure.
  5. Mar 12, 2021 at 5:37 AM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    The starter motor is only going to draw what it needs to turn the engine. The remainder of all those amps just sit in the battery. I loved seeing people overspending on their batteries when I worked for Interstate. No-it-alls buying high CCA capacity batteries in the Southern states made me lots of $$.
    auskip07, RatDaddy, Itchyfeet and 2 others like this.
  6. Mar 12, 2021 at 5:43 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    If this is true then wouldn’t the starter turn and sound the same with any battery?
  7. Mar 12, 2021 at 9:57 PM
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    Nice, where did you get the battery from?
  8. Mar 12, 2021 at 10:10 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Send your high cca batteries up here to MN, we need all that we can get.
  9. Mar 12, 2021 at 10:27 PM
    RushT
    North Texas
    Batteries plus. Buy it online and pick up in store for 10% off. You realize you’re getting to be an old fart when it’s a heave to get it up and over the front grille. Pulled it out and put in my $35 Toyota Tupperware tray this evening. Heavy bastard. I keep chewing into my payload with permanent crap. I’m afraid to hit the scales and see how much I’ve lost.
    225lbs for sliders
    50lbs roof rack
    25lbs lighting
    +25lbs battery
    10lbs bed frame crap
    -10lbs cool window stickers
  10. Mar 12, 2021 at 10:35 PM
    RushT
    North Texas
    I remember flying into Plattsburgh New York for my final year of service. Piedmont double prop. Chatted up the guy next to me on the way and he offered me a ride from the airport to the base. We landed in a winter wonder land and walked out to his old K5 blazer with 3 feet of snow sitting on it. For the past week. I’m thinking “This is going to be interesting”. He turns the key and and it turns over slow gaining speed until about 4 seconds later it fires off and we have a nice V8 rumble. He looks at me and smiles: “Triple batteries”.
  11. Mar 12, 2021 at 10:38 PM
    RushT
    North Texas
    But seriously, is it a consideration? I’m assuming oiling, spark and fuel are all proportional to rpm at startup.
    philth[QUOTED] likes this.
  12. Mar 12, 2021 at 10:45 PM
    dubktrd
    Wichita Kansas
    Thanks for the reply. Cool window stickers added 10+ horsepower
    kgilly likes this.
  13. Mar 12, 2021 at 10:57 PM
    RushT
    North Texas
    dubktrd[QUOTED] likes this.
  14. Mar 13, 2021 at 12:11 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Nope, your starter is more happy now.A weak battery causes the starter to draw more current, this will cause more heat and wear on the brushes.
    BarcelonaTom67 and Lt. Dangle like this.
  15. Mar 13, 2021 at 1:52 AM
    philth
    philth .
    Nah, you’re good, as others have mentioned.
    I just saw ‘spin’ and my mind went immediately to rod bearings.
    I’m actually considering the same type of battery as yours for next winter.
  16. Mar 13, 2021 at 3:08 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Re: new battery. It likely does spin it faster. The old battery probably wasn’t putting out what the starter could draw so the engine turned over slower.
    New battery is just doing things like it should.
    Lt. Dangle and cwdog like this.
  17. Mar 13, 2021 at 4:29 AM
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    No, if "just enuf" amperage, the starter will turn just fine. With extra amperage, it will also turn just fine. It is when you are marginal that the starter sounds sluggish.
  18. Mar 13, 2021 at 4:52 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Or up in Alberta...you need all the juice in the world to turn over any vehicle at -40!
    philth and 5nahalf[QUOTED] like this.
  19. Mar 13, 2021 at 6:46 AM
    TacomaTRDman
    TacomaTRDman Member
    2016 Blazing Blue Pearl Tacoma TRD Sport Access Cab MT
    None
    Did your stock battery tie down work or did you have to replace it?
  20. Mar 13, 2021 at 6:55 AM
    RushT
    North Texas
    Good question. I don’t really know because I’m running some aftermarket bling from one of the guys on here. But I still have the original and can check for you.
