New battery terminals - Few Questions -
Discussion in '1st Gen. Tacomas (1995-2004)' started by HammerHead, Dec 28, 2012.
  1. Dec 28, 2012 at 5:22 PM
    HammerHead
    HammerHead [OP] Well-Known Member
    Jake
    Georgia
    04 TRD OffRoad PreRunner SR5 DC
    First, I did do a search on this before asking, so unless I'm searching under the wrong key words, there doesn't seem much specific discussion on this (some discussion in the audio/ visual section but not specific).
    So, it looks like I need to replace the positive battery terminal to my 04 Taco as it keep popping off and no amount of tightening the clamp will keep it in position. Good opportunity to upgrade! :) With that a few questions:
    1) Should I replace the cables as well as the terminals, or just the terminals? I know that the terminal switcheroo is pretty easy, but don't know how hard it is to replace the cables as well.
    2) IF (big if), I ever want to add an amp and speakers later, is it better to go ahead and upgrade the terminal? Any considerations to take into account if I do this?
    3) Good brands you could recommend would be sweet too.
    Thanks in advance, and if there is a thread dedicated to this just point me in the right direction.
    Thanks!
  2. Dec 30, 2012 at 1:16 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Jake, if you are planning to add a big amp, you should also consider upgrading your alternator. The fused wiring needs to accommodate the maximum total current plus a least a 20% safety factor.
  3. Dec 31, 2012 at 3:25 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I prefer the basic marine grade terminals.
    Brand name makes little difference... as most are products of china :rolleyes:
    * lose the wing nuts for standard nuts... JMO
    realize the neg. terminal is a smaller diameter then the pos. terminal
    so be sure you don't buy two of the same ID.
    Most every auto parts retailer sells them.
    here's mine using a copper bar for extending the cable reach
