New battery won't fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackandWhite, Jan 25, 2017.
  1. Jan 25, 2017 at 6:19 PM
    BlackandWhite
    BlackandWhite [OP] Lead Foot
    Hunter
    South Texas
    2014 white double cab TRD
    Custom retrofitted headlights, leveled,custom speaker system,275/55r20 open country M/T, 20/12 -44 dropstars,black badges,white grill emblem
    I recently got a new battery and the bar that runs over the battery will not bolt back down.
    Like the battery is to tall.
    I got the same battery that was in it so I don't understand why it won't fit.
    Has anybody had this problem and know a solution?
  2. Jan 25, 2017 at 7:42 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    By same battery do you mean brand, CCA? Because there are also different case sizes. Wider, taller, shorter, etc. let's start with the simple but dumb stuff.
    1- Is the battery all the way in the tray, it's easy for it to catch on something perhaps even the electrical connections.
    2- are the vertical rods that hold the cross bar properly positioned in the tray, sometimes they drop down, rotate etc. which could cause what u experience.
    3- did you buy the wrong case size? Or maybe the auto store gave you the wrong case size.
    Norton likes this.
  3. Jan 25, 2017 at 7:42 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What battery
    shakerhood and Norton like this.
  4. Jan 25, 2017 at 8:50 PM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    What is the battery group size that you purchased? Tacoma use 24 and 27.
    Norton likes this.
  5. Jan 25, 2017 at 9:20 PM
    BlackandWhite
    Hunter
    South Texas
    Yes the wires are connected to the terminals the rods are the right way but it seams like the auto store gave me the wrong case size.I didn't know they came in different case sizes. I brought in my old battery that wouldn't even hold a charge anymore to the auto parts store and told them I need the same battery, and they pulled one off the shelf after I told them all the vehicle specs. It looked the same and i thought it was the same size case. I am guessing the case on the battery they gave me is a little bit wider than the one that was in it because the cross brace dosent fit over the top.
    Thank y'all for the clarification I guess you learn something new everyday.
    Rambo54 likes this.
  6. Jan 25, 2017 at 9:21 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Had the same problem with the Northstar 27F I recently installed.
    Solved it with a TRD Battery Hold Down. (Tell @Coupe you need longer/extended threaded rods with it.)
    Rambo54 and shakerhood like this.
  7. Jan 25, 2017 at 9:24 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I got the same problem when I ordered from the Northstar battery group buy. Are these still available from Coupe?
  8. Jan 25, 2017 at 9:27 PM
    Norton
    They were a few weeks ago... PM him for details.
  9. Jan 25, 2017 at 9:42 PM
    BlackandWhite
    Hunter
    South Texas
    Thank you for the info.
  10. Jan 25, 2017 at 10:46 PM
    OZ-T
    Peter North
    British Columbia
    Just put the hold down under the Northstar handle , its designed that way if you look at the way the battery case is shaped
  11. Jan 26, 2017 at 2:31 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Why not just bring it back and get the right battery
    lawrenccar1 and jv_74 like this.
  12. Jan 26, 2017 at 6:38 PM
    Norton
    Understood, but I preferred to have the handle under the hold down and I like the way Coupe's TRD hold downs look.
    I'm not sure what battery the OP bought, but 27F IS the right battery for my truck. Northstar's version just happens to be taller than OEM.
  13. Jan 26, 2017 at 6:42 PM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    my replacement 27f seemed a tad taller than the 27f that was there. A little gentle persuasion of the rods and the top hold-down bracket took care of it.....
  14. Feb 1, 2017 at 5:09 AM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
