New Battery Wont Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NorthG07, Mar 10, 2025.
  1. Mar 10, 2025 at 1:39 PM
    NorthG07
    NorthG07 [OP] Member
    2014 Black Tacoma SR5
    Hi All, I have a 2014 4c SR5 - original battery was needing a boost to start. last time i gave it a boost the check engine light came on along with the 'track off' indicator.
    I changed the battery and now it wont start - not even a click.
    I have dash board light, radio and remote key fob all working.
    Dash board shows check engine light and battery light on.
    Any advice?
    Note
    - yes i took negative off first/ positive on first
    - tried locking and unlocking with fob in case of anti theft
    -tried turning the key 5 times as a reset.....(read from another post)
  2. Mar 10, 2025 at 1:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'll guess a bad connection at the battery or the battery ground.
  3. Mar 10, 2025 at 1:43 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Did you put it in backwards? It happens
    Jimmyh likes this.
  4. Mar 10, 2025 at 1:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the 50 ampere AM1 Fuse, the 30 ampere AM2 Fuse and Alt Fuses. Use a meter or a test lamp. These fuses are also bolted in place.
    It is common for these fuses to blow if the battery was inadvertently connected backwards ( even for a second or two...).
  5. Mar 10, 2025 at 2:00 PM
    NorthG07
    Appreciate it, battery was not connected backwards - even left the caps on to ensure. negative on the outside positive on the inside.
    Jimmyh likes this.
  6. Mar 10, 2025 at 2:03 PM
    NorthG07
    Thanks, i will try cleaning them again they were pretty dirty.
  7. Mar 10, 2025 at 2:15 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I don't suppose you left those caps on when connecting the cables back up did you?
    TartanEagle, winkel and GTGallop like this.
  8. Mar 10, 2025 at 2:20 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Was just about to ask that. Glad I scrolled and saw your post.
    winkel likes this.
  9. Mar 10, 2025 at 2:22 PM
    MGMDesertTaco
    baking soda and water will clean up any corrosion
  10. Mar 10, 2025 at 2:31 PM
    NorthG07
    lol no i took them off
  11. Mar 10, 2025 at 2:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  12. Mar 10, 2025 at 3:16 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    So I would check the grounds by the battery… kind of old school but if you can jump the starter or try a different battery it might help lead in a direction
    Sprig likes this.
  13. Mar 10, 2025 at 3:27 PM
    NorthG07
    Thanks, i did try jumping the new battery with no success. I was thinking that i might put the old battery back and try to jump it as i was doing this before. You're right if it works it will be telling
  14. Mar 10, 2025 at 5:34 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    A meter would be helpful.
  15. Mar 11, 2025 at 5:36 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    Was the replacement battery dead / flat / malfunctioning?
  16. Mar 11, 2025 at 6:35 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    The order in disconnecting your battery cables is a safety thing and has zero to do with the vehicles electrical operation later on.
    WOODY2 likes this.
  17. Mar 11, 2025 at 9:08 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Wouldn’t be the first time a new battery was DOA.
    Why I oughta... likes this.
  18. Mar 11, 2025 at 11:55 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Got to start with basics. You were having problems starting the truck with the original battery and with a new battery the starting problem is worse. It probably isn’t the battery but I’d still start by checking the battery voltage. If it’s less than 12.0 it’s a battery problem or it needs charging.Then make sure the battery cables are tight. Next check the ground connection and the starter/solenoid connection. Make sure they are tight and are not corroded. If corroded clean them up, tighten them up and try again. Also check the fuses.
  19. Mar 11, 2025 at 11:58 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    How's the alternator output?
    Sprig likes this.
  20. Mar 11, 2025 at 12:06 PM
    Why I oughta...
    Why I oughta... Well-Known Member
    2014 Base AC 4x4 2.7 5speed
    Bought a battery from a well known autoparts store and had this exact thing happen.
