New battery!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Adrianfelix1, Jun 1, 2025.
  1. Jun 1, 2025 at 4:45 PM
    Adrianfelix1
    Adrianfelix1 [OP] New Member
    In need of a new battery I have a 2021 TRD Pro which battery is good and well worth the price..
  2. Jun 1, 2025 at 4:47 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Don't go cheap, buy a good AGM type battery. I am going on 5 years now with mine.
  3. Jun 1, 2025 at 5:23 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Don't overspend...
    Get a NeverStart ( Everstart ) from Walmart - 3 year battery for $139.00
    I live in the desert and change mine every 2 years regardless in my 3 vehicles.
    Just as good as any, doesn't weigh a ton like the AGM.
    MannyS, japjoe7, GTGallop and 3 others like this.
  4. Jun 1, 2025 at 5:40 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    East penn batteries I find hold up good and rarely ever get corrosion on the terminals and are competitively priced. The factory interstates seem to need corrosion protection constantly .
    RustyGreen likes this.
  5. Jun 1, 2025 at 6:27 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Toyota batteries are hit or miss. My factory battery developed a bad cell at 33 months in to my warranty. Toyota gave me a free new Toyota True Start battery which is now 6.5 years old.
    I generally get a Costco Interstate battery when I need a new battery outside of warranty.
    https://www.costco.com/automotive-batteries.html
  6. Jun 1, 2025 at 6:32 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I went to a local battery supplier and picked up a blemished factory equivalent battery that has been flawless since the factory one failed at 5 + years of service.
    ( Jeesh!!! Toyota quality has really gone down hill!!! o_O )
    Truck is daily driven so the battery works for a living.
  7. Jun 1, 2025 at 6:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe buy a new serpentine belt while you’re at it.
  8. Jun 1, 2025 at 7:15 PM
    Barok206
    Barok206 Well-Known Member
    2018 Cement Tacoma TRD OR
    I'd got with Costco Interstate. I have Interstate batteries in 3 of our cars. Last one I replaced lasted just over 6 years. Not bad I think.
    TacoLin1234 and henryp like this.
  9. Jun 1, 2025 at 7:15 PM
    Barok206
    And welcome to Tacomaworld.
  10. Jun 1, 2025 at 7:20 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Just replaced mine, plus the 2 upper idler pulleys. One was screaming randomly. 126,000 + kms on them.
    Steves104x4[QUOTED] likes this.
  11. Jun 1, 2025 at 7:54 PM
    LongDukDong
    LongDukDong Oh sexy girlfriend
    Eastern Seaboard
    2022 TRD OR
  12. Jun 2, 2025 at 3:35 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Johnson controls makes the interstate battery which is the same as the TrueStart. OP get yourself a 2nd gen Battery tray which is for the towing package for a 2nd gen. The tray is cheap and drops right in place, then get you a 27F battery with more CCA.
    vivid02 likes this.
  13. Jun 2, 2025 at 3:50 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Hardscrabble likes this.
  14. Jun 2, 2025 at 4:20 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    I'm going to second this advice....
    Always get the biggest (contains the most energy) size you can in the most durable format you can, like AGM. I have however heard that AGM requires a higher charge rate and that requires some circuitry changes around the fuse box under the hood or an OTT Tune to bump up the charge voltage.
    Almost every vehicle out there has a super premium deluxe version.
    That version has more accessories (power hungry).
    Usually the premium version of your vehicle will take a bigger battery (capacity and size). If that doesn't get you a bigger one, do the tray swap mentioned above.
    Or..........
    There are a TON of threads on here with battery advice. One of those threads is unique because a contributor recommends going to a Caterpillar (CAT) Equipment Supply Store and getting a CAT Battery in your size because they stand up to heat and abuse.
    https://parts.cat.com/en/catcorp/8C-3602
    That might be just my game when this battery starts to tank.
    While you are at it - Get a Noco Battery Pack too.
    https://no.co/gb40
    We never get to pick the time and place that our batteries die on us - but they do and they are evil little bastards about leaving you at the worst moment.
  15. Jun 2, 2025 at 5:34 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I recommend the 12 volt kind
    (meaning don't over think this one brother!)
    Chew, henryp, TacoManOne and 2 others like this.
  16. Jun 3, 2025 at 5:13 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    <=== Guilty...
    Batteries are the one area that I really over think it.
    The idea is that maybe a little sweating it now means the truck will die in a Pep Boys Parking Lot and not out on a trail in the desert where there is no cell connection. I know it doesn't work that way but that's what plays out in my head.
    TacoManOne likes this.
  17. Jun 3, 2025 at 5:49 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    two 6 Volt batteries? :rofl:
    GTGallop likes this.
  18. Jun 4, 2025 at 5:10 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    Get a bunch of 18650's and a Spot Welder.
    Juuuuust kidding. At 4.2v charged I tried this and couldn't get it to math out right to match a car battery.
    To get the full charge of a 12v Car Battery you would need 3.6 18650's. 3 would be too small and 4 would be way too big. Tried to make it 3x4 batteries for a total of 12 18650's with a 12v capacitor on the end of it and it never worked out right that I felt safe starting a car with it. I still think there is a way to do this but I'm just not smart enough YET. And at 52, probably not going to be.
    TacoManOne[QUOTED] likes this.
  19. Jun 4, 2025 at 9:20 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    You need four LiFePO4 (lithium-iron) cells to do that (and is what 12V lithium automotive batteries effectively use). 3.6V @ full-charge, 3.2V nominal.
    Another vote for Interstate from Costco, or Walmart (Everstart).
    eaglehawaii likes this.
  20. Jun 4, 2025 at 9:46 AM
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
    Like @2021SR5V64WD said, project farm did a video years ago, still hold true, https://youtu.be/h7rTcBanpMk?si=CwPfQT9idOEKWMZe
    Fireball 00, GTGallop and eaglehawaii like this.
