New Bilstein 8112 Coilovers !
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Feb 6, 2018.
  1. Mar 12, 2019 at 11:45 AM
    #421
    Arrieta578
    Arrieta578 Well-Known Member
    2019 Tacoma DCSB OR Calvary Blue
    Thanks for the post! A couple of questions:
    1. How hard was it to crank up your coilovers under the preload?
    2. Did you or do you have to get the truck realigned each time after tuning or making minor adjustments to your coilovers?
    Imphedup likes this.
  2. Mar 12, 2019 at 3:33 PM
    #422
    Imphedup
    Imphedup Trout Addict Whitetail Killer
    CHAD
    LOWELL,MI
    2017 DCLB OR
    1. It wasn't hard at all with a breaker/cheeter bar, even by hand alone it isn't bad. Problem is the lack of space to turn, even with the bump stop off you can only get maybe a quarter turn.
    2. Mine wasn't aligned from install, I wanted everything to settle before I had it aligned yesterday.
    3. FYI Tape you're spanner wrench, a I didn't even think about it and marred up the finish a bit.
    It was my first time adjusting a adjustable coilover. If you would like I can pm you my #, so if you have a quick question during adjustment you can call or text. Up to you?
  3. Mar 12, 2019 at 3:37 PM
    #423
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Way to expensive for me.
    jeffmansion likes this.
  4. Mar 12, 2019 at 3:40 PM
    #424
    Imphedup
    CHAD
    LOWELL,MI
    2017 DCLB OR
    Cool story
    LGOPs504, Taco1.1 and Justwandering like this.
  5. Mar 13, 2019 at 8:46 AM
    #425
    Arrieta578
    Thanks for the information! Your first hand knowledge is very helpful. And thanks for the offer to touch base, again very helpful! Will send a PM if I decide to tackle it. Right now I'm sitting at about 22" from the center of the hub to the bottom of the fender in the front... Was thinking of going up 1/2"....
    Imphedup[QUOTED] likes this.
  6. Mar 30, 2019 at 9:40 PM
    #426
    WRO
    WRO Well-Known Member
    Portland OR
    2016 Taco DCLB Sport
    Scratches
    Just installed my 8110s today, holy shit they're amazing.
    Heavily Meditated and eurowner like this.
  7. Mar 31, 2019 at 1:59 AM
    #427
    Hunter399
    Hunter399 Well-Known Member
    2018 White Tacoma TRD Off-Road
    TRD Pro Grill, TRD Pro skid plate, tuff skins stickers, rekgen mudflaps, 33'' tires, 17'' wheels. Nitro 5.29 Gears. Bilstein 8112 front/8100 rears. Icon delta joint UCA’s and RXT leaf pack. Baja designs Fog, squadron ditch lights, and 30” S8 light bar.
    On Bilstein’s website it lists two new options for springs on the 8112 that you can buy. One lists it as weight and the other it states for .5” of additional lift. They are both 14” springs and was wondering if anyone knows the difference between the two?
  8. Mar 31, 2019 at 3:07 AM
    #428
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Per bilstein.
    Spring is the same dimension just a heavier wire diameter. Not possible to say it will give .5” over the 650 being the shock is adjustable you can set it to your desired height.
    Headstrong explained.
    If your truck is totally stock and no huge amount of weight is up front you’ll gain .5 inch. It explains why my 6112 with a 650 spring gave me extra lift
    700lh springs description I think it accounted for the extra weight up front so it’s the reason there is no mention on lift.
  9. Apr 4, 2019 at 10:54 PM
    #429
    Hunter399
    Thanks! Yeah the website didnt list the spring ib rating but that makes sense
  10. Apr 8, 2019 at 2:11 PM
    #430
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    I’m waiting on the rear shocks,AAL,shims and Fox Roost shields 6E6FE0E2-EE34-48F2-877F-39AD13E06B34.jpg
  11. Apr 8, 2019 at 2:15 PM
    #431
    Hunter399
    Fox rooster guards and shims?
    I am excited, I pulled the trigger and getting the whole setup out on at the end of the month.
  12. Apr 8, 2019 at 2:55 PM
    #432
    Gregw138
    Greg
    NY
    WAY TOO MANY
    Sorry it’s actually called a roost shield by Fox. It’s to protect the passenger side rear which is susceptible to rock kick ups. And the shims are 3* pinion angle shims
  13. Apr 8, 2019 at 3:20 PM
    #433
    Imphedup
    CHAD
    LOWELL,MI
    2017 DCLB OR
    New control arm bolts....where's the fun in that.
  14. Apr 8, 2019 at 3:42 PM
    #434
    Gregw138
    Greg
    NY
    WAY TOO MANY
    Yeah. Definitely taking the easy way out
  15. Apr 8, 2019 at 6:15 PM
    #435
    Hunter399
    Oh I see, I wonder how the guards will fit.
  16. Apr 8, 2019 at 6:42 PM
    #436
    eurowner
    eurowner Duke Sky
    Scoty
    Very cool part!
    HandOfGod likes this.
  17. Apr 8, 2019 at 7:52 PM
    #437
    Gregw138
    Greg
    NY
    WAY TOO MANY
    Will let u know
  18. Apr 20, 2019 at 7:38 PM
    #438
    Gregw138
    Greg
    NY
    WAY TOO MANY
    Waiting on 8100s to be delivered. Shout out to Steve @Wheeler's Off-Road Inc for hooking me up with a great price.
  19. Apr 20, 2019 at 10:05 PM
    #439
    Arrieta578
    For you guys running really heavy loads in the back... I get the 8100s...
    But, honestly, you're really missing the pleasure of 8112s in the front... they are simply amazing...
    Roaming__Taco and eurowner like this.
  20. Apr 23, 2019 at 12:48 PM
    #440
    Gregw138
    Greg
    NY
    WAY TOO MANY
    I have the 8112’s already but now it’s complete with the 8100’s
    oscolivar1 likes this.
