New Bilstein 8112 Coilovers !
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Feb 6, 2018.
  1. Dec 20, 2021 at 7:34 PM
    #741
    eurowner
    eurowner Duke Sky
    Scoty
  2. Dec 21, 2021 at 1:29 AM
    #742
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    "Secondary" implies that the *Primary* bump stops are still necessary, does it not?
    eurowner[QUOTED] likes this.
  3. Dec 21, 2021 at 8:31 AM
    #743
    eurowner
    eurowner Duke Sky
    Scoty
    Quite possibly!
  4. Dec 21, 2021 at 3:28 PM
    #744
    Silverlogic
    Tyler
    Guess I need to call them. Would be cool if your interpretation is correct
  5. Dec 21, 2021 at 3:29 PM
    #745
    drbyrdman
    drbyrdman Active Member
    They do have built in bump stops. I have them and they work well.
  6. Dec 21, 2021 at 3:32 PM
    #746
    Silverlogic
    Tyler
    The question isn't if they have built in bumps, I have them as well and agree they're great. The question is if the built in bumps are suitable to be the only bumps(removing the stock pucks entirely) or if they're supposed to just dampen the hit before the stock pucks limit travel.
    eurowner likes this.
  7. Dec 21, 2021 at 3:34 PM
    #747
    drbyrdman
    I would leave them
  8. Dec 21, 2021 at 3:51 PM
    #748
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Valid questions. Wouldn't want to limit up travel. Also save some money on traditional bumps or quite a bit on hydro bumps
  9. Dec 21, 2021 at 3:58 PM
    #749
    eurowner
    eurowner Duke Sky
    Scoty
  10. Dec 21, 2021 at 7:25 PM
    #750
    wanderecht
    wanderecht New Member
    2015 tacoma 4x4
    I blew my driver side B8100 out. My local shop could not rebuild them with a new seal kit. Bilstein was not taking on any repairs due to the lockdown at the time, but they stepped up and repair them after talk to my local shop. Not sure what happened to them internally but it was pretty major. You can see my previous post for pictures. If you’re running additional weight you definitely want to keep the factory bump stops on. Or make sure the rear leafs are set up for the additional weight. Shouts out to Dallas Offroad for facilitating the repair through Bilstein. I got everything back up and running with the B8112 up front and B8100 in the rear, and they ride like butter!
    WRO, eurowner and Dirk Diggler like this.
  11. Feb 10, 2022 at 11:39 AM
    #751
    Silverlogic
    Tyler
    Finally got around to asking bilstein about the OEM bumps. Their response was that the OE bumps need to stay.
  12. Mar 29, 2022 at 5:22 AM
    #752
    Mescorpio1147
    Mescorpio1147 Well-Known Member
    Ivan
    06 tacoma 4x4
    How do these feel when driving, more comfortable
  13. Mar 29, 2022 at 5:46 AM
    #753
    drbyrdman
    Ride like Fox or Icon. But perform much better. Best coilover I have ever had.
    dk_crew likes this.
  14. Mar 29, 2022 at 7:33 AM
    #754
    Silverlogic
    Tyler
    I would say overall they're more comfortable (than stock offroad shocks), the only road condition where they behave worse is slow speeds over vert small bumps. Everywhere else they amazing.
    dk_crew likes this.
  15. Mar 29, 2022 at 11:04 AM
    #755
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    ive had the rears for about 30k miles and 25k for the fronts. I can only compare them to 6112/5160s and its a huge upgrade from offroad and onroad; gravels roads/washboards going like 40-60mph, rock crowling etc.
    only issue im having is my 8100 bypass shocks is that i cant tune the shock. The allen screw seem to be stuck for whatever reason on the driver side. Bilstein is aware and i can send them in when its time for me to rebuild the shock.
  16. Mar 31, 2022 at 3:24 PM
    #756
    Mescorpio1147
    Ivan
    06 tacoma 4x4
    Oh okay, thats what I like to hear, not many reviews on them for the tacoma, so if you say they are a huge upgrade from stock, and 6112.
    cmacblue42 likes this.
  17. Jun 10, 2022 at 4:00 PM
    #757
    yotafiend
    yotafiend Sup Dawg!
    Detroit, MI
    2024 SR5 DCSB 4x4 Underground
    TRD OR Wheels Falken Wildpeak 33s C TRD OR Struts Trailhunter Skid Toyota Mudguards Toyota Integrated Dashcam Toyota Rocker Bars CH Ceramic Paint Coating Costco 91 Octane
    Question:
    What are compatible coil springs that can replace the 14" 600# Bilstein 8112/6112? I saw one member use an Eibach 14" 600lb 3.0 spring. Wondering what all the alternatives are...
    Backstory:
    Over 60K miles and 3 1/2 years of Michigan salt, here's a good shot of the corrosion. Had a coil break today and trying to find a replacement pair of 600# versions.
    Found out the following:
    e4-fd1-y005b29 is the 600#
    e4-fd1-z005b50 is the 700# (almost picked these up locally bc someone was selling them as 600#)
    Bilstein warranty for the 8112s are only 2 years, sh*t.
    So, I found some shop that rebuild nearby, and Bilstein support said they dont have enough staff to do anything, so they pushed me off to downsouthmotorsports.com to purchase a rebuild kit along with the springs.
    cmacblue42, oscolivar1 and eurowner like this.
  18. Jun 10, 2022 at 4:10 PM
    #758
    Arrieta578
    Arrieta578 Well-Known Member
    2019 Tacoma DCSB OR Calvary Blue
    I have some original 600lb. springs you can have, but I’m in California. Not sure what they would be to ship. 4WP carries the 650lb and 700lb springs. I upgraded to the 650s.
    oscolivar1 and yotafiend like this.
  19. Jun 13, 2022 at 6:38 AM
    #759
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have 2 sets of 600lb springs as well. One set has about 100k miles on them, one set is new.
    Let me know if you are interested.
  20. Sep 1, 2022 at 1:33 PM
    #760
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    THREAD REVIVAL TIME! Just ordered a pair of 8112 coilovers. Boys I’m so tired of this 5100/ome 885 combo. Can’t wait to revolutionize my wheeling experience. Nearly 5 years of DD & wheeling on my 5100/885 plus top hat spacers.
    cmacblue42, alwaysHI and oscolivar1 like this.
