New Bilstein 8112 Coilovers !
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ROGUE OFFROAD, Feb 6, 2018.
  1. Sep 26, 2024 at 3:26 AM
    #801
    GetterDun
    GetterDun Well-Known Member
    Northern BC, Canada
    2009 Tacoma
    Armor - TG Rock Defense Bumpers, OKX engine and transmission skid plate Suspension - Bilstein 8112 Remote Coilovers (650lb) and 8100 Adjustable Remote Reservoirs, TC UCA's, OME 500lb leaf springs Electrical - 27F Odyssey extreme AGM battery, "big 7" wiring upgrade, 200A alt and MK4 booster, Warn Zeon 10s winch with remote solenoid and upgraded wiring Engine - URD headers
    In the same boat as you minus the seized adjusters. I've sent them an email about rebuild kits, quick adjusters and about a 2" or 3" rod end to see if it would fit these shocks so I can comfortably run a 3" rear lift. Apart from having to use an allen key to adjust mine its a great setup. Likely going to get mine cerakoted as well cause they've started to tarnish. Once I get a reply though I can post some more info.
    What I know so far is you need the BILSTEIN Gas Filling Tool (Part #193000) to top up the nitrogen in the shock (think they say keep it around 180-220psi), but its just a schrader valve connection so you could probably make your own or have a hydraulic shop top it up for you. I heard the oil used is similar to aw-32 hydraulic oil minus the dye or you can just buy a gallon of "bilstein shock oil".
  2. Jun 3, 2025 at 5:05 PM
    #802
    Jseda845
    Jseda845 Well-Known Member
    845 NY
    2019 TRD OR
    Dobinson's MRR coils, Deaver Stage 3 leafs, 295/70/17 Yokohama Geolander MT, ATHFab front & rear bumpers, DRT CMR, WarFab sliders, Archive Garage U-Bolt flip kit, SPC UCA (soon to be swapped)
    Anyone running these on a third gen with 35s? Do they offer 2” front lift or 2.2? Can’t find a clear answer
  3. Jun 3, 2025 at 6:42 PM
    #803
    eurowner
    eurowner Duke Sky
    Scoty
