New Blower Motor and Clutch Pedal replaced
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moondeath, Jan 15, 2013.
  1. Jan 15, 2013 at 5:03 PM
    moondeath
    moondeath [OP] Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I just dropped my truck off yesterday to have my 2nd blower motor replaced on the newer TSB that was issued back in oct 2011. I had the TSB done that was just before that one. Blower speeds 1-2 chirp chirp chirp chirp chirp chirp chirp chirp chirp chirp chirp chirp chirp chirp chirp chirp :censored::frusty::violent:
    We'll see if this fixes it. Also getting my clutch pedal squeak/creak fixed. I've been waiting since I've had about 3k miles (41k miles now) to get this done. They finally issued a TSB for this recently. Replaces clutch pedal assembly and master cylinder. Hopefully this works, Im SO TIRED of the creaky pedal when its warm out!! Drove me crazy.
    They were giving me a little bit of a hard time because my warranty has expired and they didn't know if the blower would be covered. But they called me today and said they are doing a good faith repair.
    I'll throw some TSB numbers on here once I get my truck back tomorrow. I hope, I hope I hope this fixes these problems once and for all!!
    **TSB for creaky/squeaky clutch. TSB 0186-12
  2. Jan 15, 2013 at 5:30 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    There's a TSB for the creaky clutch pedal?? :eek:
    Please post it!!
  3. Jan 15, 2013 at 5:44 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Its not new though, been around for a while, unless they've changed it again. I cured mine with some lithium grease in the socket, YMMV.
  4. Jan 15, 2013 at 5:48 PM
    TACK
    Nevada
    I've done the lithium grease and it has worked pretty well. I was just hoping that there's a real fix.
  5. Jan 15, 2013 at 5:52 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Might as well get any updated parts if you still have warranty too. I'm well out, so a TSB is a non-issue for me so long as occasional greasing keeps things happy.
  6. Jan 15, 2013 at 7:08 PM
    moondeath
    Pa, Gardners
    There is different TSB's for the clutch/tranny. When I went in about this, there were about 4 TSB fixes for clutch problems. The issue that I have, I've been waiting for about 2 years for a fix. Consistently calling toyota and seeing if a TSB had been issued for my problem, and finally there is.
  7. Jan 15, 2013 at 7:10 PM
    moondeath
    Pa, Gardners
    When I get home tomorrow after picking up the truck I'll post the TSB
    # thats stated on the worksheet.
  8. Jan 15, 2013 at 7:37 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    I was refering to the creaky pedal TSB only, which there has been one of those around for a couple years or so. So it sounds as if its been changed again, or maybe your truck was too new to qualify for the original TSB. The TSB number and issue date will clarify I guess.
    The latest -043 blower motor seems to be a fix, finally, I put mine in a couple months ago now and have no issues, and the toyota techs on the site have been reporting good results as well. Silence is a wonderfull thing, unless its from the wife, right?:p
  9. Jan 15, 2013 at 7:47 PM
    moondeath
    Pa, Gardners
    I hope I have the same luck as you with this blower motor! I'm so tired of hearing it chirp! The same goes for this damn clutch pedal! And yes, there is no fix for the wife.;)
  10. Jan 16, 2013 at 4:45 PM
    moondeath
    Pa, Gardners
    TSB# for clutch 0186-12
  11. Jan 25, 2013 at 10:04 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    So I was not aware of the new TSB out for the blower motor and decided to take my truck to the dealer. Recently moved out to Temecula and popped in to Toyota of Temecula. The had the new blowers in stock and they replaced it on the spot in 2 hours. Sounds better than it ever did, even after I pulled the motor out and lubed the bearings. Tech said that the bearings were scored and no amount of lube would fix it. Good service and great experience there...having a staff of 5-6 very attractive service writer assistants didn't hurt either...
  12. Mar 27, 2013 at 1:01 PM
    silverbullet2011
    silverbullet2011 New Member
    Marcus
    Charlotte, NC
    2011 4x4 6sp manual SR5
    I just got my blower motor replaced and my clutch fixed. Still under warranty, so no charge. I hope the blower motor doesn't go bad like moondeath's.
  13. Mar 28, 2013 at 6:38 AM
    moondeath
    Pa, Gardners
    At this point my blower so still nice and quiet.
  14. May 1, 2013 at 5:48 AM
    N8Dizzle
    N8Dizzle Well-Known Member
    Nate
    Sumner
    2020 AG TRD PRO MT
    Cooper S/T Maxx 255/85/16
    Just had my squeaky clutch TSB done yesterday. Took a day to order parts (they kept my truck and provided a loaner) and about 4 hours for them to install the next day. Finally no more squeak.
    I also had the fan blower done last year and haven't heard a noise from it since.
  15. May 1, 2013 at 5:53 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    I had the creaky clutch pedal tsb done too. Knock on wood its been fine since then. Mine did it when it was cold outside.
