New Bolt-On Rock Guard Design - NOW AVAILABLE!
Discussion in 'All-Pro Off Road' started by allpro, Dec 1, 2010.
  1. Dec 1, 2010 at 8:10 PM
    allpro
    allpro [OP] Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Key Features
    • Angled upward to provide the most possible clearance
    • Signature "Kick-Out" design
    • Gusseted for added strength, with built-in frame support
    • Industry-leading beefy .134 wall tubing
    • Easy installation - minimal drilling required
    • Made in the USA
    Full Description
    All-Pro Off Road has been an innovator in developing products for the 05+ Tacomas, using decades of extreme off-roading experience. We know that rock sliders must be strong to protect your truck, as well as provide the optimal amount of ground clearance. The rocker panels are one of the most vulnerable areas of your vehicle, so leave it to us to provide you with the protection you need!
    These are no ordinary nerf bars. Our Rock Guards have been trail tested on some of the most gruelling trails around, from the Rubicon to the Hammers and Moab. They are built from heavy duty .134" wall tubing, and come ready to bolt on with the included grade 8 hardware. This innovative design features an L-shaped bracket that attaches the back 3 legs and runs down the frame, adding support to the weaker C-channel portion of the Tacoma's frame. Rock Guards mount with countersunk bolts that are flush with the bottom surface, since exposed bolt heads can be easily mangled by rocks. No welding or pinch flange notching is required, and minimal drilling is needed for proper installation.
    The outer tubes of the Rock Guards are 1.5" diameter, and angle upware to provide more ground clearance and door protection. The rear of our Rock Guards extend outward just before the rear wheels to provide extra body protection where it is needed most. This signature "Kick-Out" design protects the rear portion of the cab while maneuvering through tight obstacles. You'll be glad you have this feature next time you're wheeling next to a boulder, because as you near the end of the Rock Guards they will push your truck out and away from danger just in time.
    All-Pro Rock Guards also serve as a convenient lifting point. A High-Lift jack can be used anywhere along the bar to lift one or both wheels. All Rock Guards come unpainted so you may paint or powdercoat in the color of your choice.
    80" Rock Guards - Fits 05+ Double & Access Cab Shortbeds $399.00 (2005T-AP-05-BO-KT)
    Technical Data
    Material: .134 wall tubing; 3/16" steel mount plates
    Hardware: Grade 8 mounting hardware included
    Weight: 120 lbs. (pair)
    Dimensions: 80" L
    PLUS ALL ARMOR IS 10% OFF THRU 12/23/10 (Use Coupon Code 10-OFF)
  2. Dec 1, 2010 at 8:15 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Nice photos, but they don't do them justice.
    I'm just waiting for these to get painted then they'll be on my truck,
    Solid product and good deal!
  3. Dec 1, 2010 at 8:16 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    those are clean... i'd get em if i had the extra money to spend
  4. Dec 2, 2010 at 10:15 AM
    espdtrd08
    espdtrd08 espdtrd12
    Virginia
    2012 4runner w/ kdss
    Icon lift, 285 duratracs, shrockworks sliders, weathertechs, leds throughout, Gobi rack w/ladder, rigid driving fog lights, trd shift knob for extra hp, MGM hood vinyl wrap
    What you have for a long bed?
  5. Dec 2, 2010 at 10:32 AM
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    The angle of the pics are a little tough to tell. Any better shots of how far they stick out on the sides?
  6. Dec 2, 2010 at 10:56 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Will Definately have to look into these after Christmas season is over. Dont think the fam nor the girlfriend would understand me saying "I dont have any money to get anyone decent gifts, but hey look at my new sliders!!!"
  7. Dec 2, 2010 at 11:06 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    How strong are bolt on sliders...vs weld on sliders? I understand that weld on will be stronger but will bolt-on sliders be A LOT weaker?
    or are bolt on sliders just steel step bars?
  8. Dec 2, 2010 at 11:11 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    they looks great. I really like the full length mounting plate as well.
  9. Dec 7, 2010 at 12:05 PM
    allpro
    Montana
    Thanks! Let me know if you have any questions during the install if we don't have the instructions to you in time.
    Sorry, nothing yet for long beds, we need to get one in our shop to check leg placement and verify length.
    I tested them on some hard trails as bolt-on's and they are definately strong enough to be used as sliders. I had the full weight of the truck on them pivoting around a rock as seen here on YouTube on my white '08 Taco about 1/2 way through (thanks to John & Mel for the video) :
    http://www.youtube.com/watch?v=MY8_0SJ9xCM
    Thanks!
  10. Dec 8, 2010 at 2:25 PM
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
    Soon to ditch my stubbs for a set of these. After seeing them in person and how beefy that frame rail plate is... can't wait :D
  11. Dec 9, 2010 at 1:15 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    x2
  12. Dec 9, 2010 at 1:29 PM
    stroM-
    2006 4X4 TRD OR
    Here you go! They tuck up nice and tight!
    (Thanks to Nathan for the pics!)
  13. Dec 14, 2010 at 10:13 AM
    allpro
    Montana
    Here's a few pics on an access cab truck we just did an install on (for reference it has our LT kit in the front with 1.25" wheel spacers in the back):
  14. Dec 14, 2010 at 10:34 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Those look really nice. These are on my after the holidays order list.
    Justin
  15. Dec 22, 2010 at 7:21 PM
    LivianInt
    LivianInt Well-Known Member
    Rodney
    Yorktown, Virginia
    2011 Dbl Cab 4x4 TRD Offroad 6-Speed Manual
    Undercover SE, OEM Bed mat, OEM Bed extender, Fog Lights any time mod, Garage door remote switched by high beams, ScanGauge II on Blendmount, Dome/Map Lights Mod, Illuminated 4x4 switch, Redline gas hood struts, CBI front hitch receiver, Warn 9000i Winch, Lockable Rattle Proof Hitch Pin, All-Pro Bolt on Sliders, Front and Rear Power Quick Connectors, Rear Spring TSB,
    What was the finish on this one? They look really nice.
    Rod
  16. Dec 27, 2010 at 12:08 PM
    allpro
    Montana
    Satin black rattle can!
  17. Dec 28, 2010 at 2:32 PM
    TacoFMS
    Justin
    Louisa County, VA
    hey can anyone tell me why its not showing me the pic of the access cab with sliders? i really would love to see that pic since i have an access cab and am looking to get some of these. is it something im missing in my settings or something? can someone else post the pic a diff way? thanks.
  18. Dec 28, 2010 at 4:57 PM
    allpro
    Montana
    They are linked from our facebook page, I don't know if that matters or not.
  19. Dec 29, 2010 at 12:30 PM
    TacoFMS
    Justin
    Louisa County, VA
    hmm IDK. doesnt make sense cuz i cant see it from my work nor home computer. anyone else out there have any pics of an access cab with these sliders? would really love to see a set up before making final decision.
  20. Dec 29, 2010 at 12:42 PM
    theduck911
    Max
    Locked and Geared!
    I do/well can get'em I just mounted mine last week.
    I'm just at work so I'll get some after for you.
