New Brake Pads, which ones?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DriverSound, Dec 10, 2012.
  1. Dec 10, 2012 at 11:03 AM
    DriverSound
    DriverSound [OP] Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Looking to replace my brake pads and looking for opinions on which to use. :confused:
  2. Dec 10, 2012 at 11:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I went with Autozone Duralast pads. They have a lifetime warranty and seem to be performing very well. I'll never have to buy pads again :)
  3. Dec 10, 2012 at 11:07 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    As I understand it, Lifetime warranty on those pads are for wear? At least that's what an Autozone associate explained to me when I bought them for another car.
    Anyone have any experience with EBC green stuff or Hawk LTS/HPS?
  4. Dec 10, 2012 at 11:13 AM
    Pugga
    Massachusetts
    I asked the associated when I bought them if I brought them back next week worn to the nub with 50k miles on them, they'd replace them and he said yes. I didn't read all the red tape but it seemed to me they're banking on people either forgetting about the warranty or not keeping their vehicle long enough to need a third set of brakes.
    Even without the warranty, I'd buy them again. They were $50 for the pair for the ceramic pads. They are quiet and seem to have a better bite than the stock pads did. Dust isn't bad either, I'd say they dust a little less than stock also. I don't find myself cleaning my wheels as often with these pads.
  5. Dec 10, 2012 at 11:20 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
  6. Dec 10, 2012 at 11:24 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    At what mileage did everyone replace their pads? I have 72k on my truck (I'm the only owner) and I've never replaced the pads. I took a wheel off the other day and it looks like I have plenty of pad left. I was blown away. How long do the stockers usually last?
  7. Dec 10, 2012 at 11:27 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Pad life depends on how you drive, where, and if you tow or load the bed.
  8. Dec 10, 2012 at 11:28 AM
    Pugga
    Massachusetts
    At 70k miles I replaced the pads and rotors. Seems the newer vehicles are eating through them faster because they use the brakes as traction control.
  9. Dec 10, 2012 at 11:32 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    My rotors still look good though I haven't measured thickness and the machine shop measures them anyway before resurfacing. Anyone one what oem is made of? Semi or ceramic?
  10. Dec 10, 2012 at 11:35 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    oem is semi-met
  11. Dec 10, 2012 at 11:38 AM
    ManMan
    ManMan Well-Known Member
    Hawk LTS are working very well for me thus far. Significantly better stopping power
  12. Dec 10, 2012 at 11:38 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I actually had this exact same concern earlier this year. Here's my specs from when I posted in the BS thread http://www.tacomaworld.com/forum/texas/136970-texas-bs-thread-1642.html#post5553583
    I had the same mileage when I posted that also... :spy:
  13. Dec 10, 2012 at 11:43 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I'm leaning towards the hawks LTS though they are on the expensive side. I'm also going to upgrade to SS lines to get a firmer pedal when I go OME with my suspension.
  14. Dec 10, 2012 at 11:44 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i have had Hawk LTS pads on both of my last Tacomas. Very good pads, in my opinion. Good feel, great stopping power, low noise.
    Only downside is they do produce a bit of brake dust. I would (and have) most definitely purchase again.
  15. Dec 10, 2012 at 11:46 AM
    TacoFMS
    Justin
    Louisa County, VA
    they are still MUCH cheaper than any of the EBC pads and only slightly more than the duralast ceramics. autoanything has them for i think around $75 shipped.
  16. Dec 10, 2012 at 11:46 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
  17. Dec 10, 2012 at 11:54 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Hawk pads looks like a winner. Worth it to flush the brake fluid or is it best just to bleed the system? How hard is it to bleed em?
  18. Dec 10, 2012 at 11:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I went with OEM pads.
    Rotors were good but I had them turned anyway. Now I should be good for another 5 years (50k miles)
  19. Dec 10, 2012 at 11:57 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    It's always worth it to flush the system to get rid of all the fluid and residue. I believe machine flush uses a 20 psi.
  20. Dec 10, 2012 at 12:00 PM
    Pugga
    Massachusetts
    I usually bleed the lines a few times to try and flush as much of the old fluid out as possible. Just make sure you keep the reservior topped off when you do.
