new brakes and other for 2004 toyota tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ben Warren, May 3, 2009.
  1. May 3, 2009 at 4:07 PM
    Ben Warren
    Ben Warren [OP] Member
    apopka florida
    04 PreRunner
    I have listed the following results from my Toyota inspection report. Does any body here have any advice or suggestions on doing this work on my own and buying the parts somewhere online??
    Inspection Evalutation
    Replace front windshield wiper
    blades
    Check brake/ clutch fluid level/condition Found brake fluid to bedirty/contaminated Perform brake system flush
    Inspect air cleaner element Found air cleaner element to bedirty
    Recommend replacing air filter element
    Inspect ignition wires (spark plugs and
    wires) Found worn out spark plugs Replace spark plugs
    Inspect battery terminals/cables Found battery to be dirty and in
    need of service Service battery
    Inspect/measure front brake pads and
    rotors 3MM or less Replace front brake pads and rotors
    Inspect/measure rear brake linings and drums/rotors
    • 3 MM or less (pads)
    • Below minimum thickness
    (shoes)
    • Found rear brakes dirty/out of
    adjustment
    Clean and adjust rear brakes
  2. May 3, 2009 at 4:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    anyway you can make the font a bit bigger....kinda hard to read.
