New brakes and rotors make rubbing sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomatim74, Oct 9, 2018.
  1. Oct 9, 2018 at 6:36 AM
    tacomatim74
    tacomatim74 [OP] New Member
    Tim
    2014 Silver 2WD Prerunner 4DR
    I just installed new front brakes and rotors on my '14 Tacoma. I used the basic brake and rotors available. Nothing fancy or expensive.
    Everything was working perfectly, but after about 15 miles with the new brakes and rotors, when I come to a stop, I can hear and feel a rubbing sound coming from the brakes. It does that when the truck is about to stop. I've searched forums and cannot find anyone with this issue. When people have issues with brakes, they describe a squealing or grinding sound. But mine is different. Mine may be more like a grinding sound, but it's not high pitched. It's a rubbing sound and it causes a minor vibration that I can feel when I'm in the driver's seat.
    I know the brakes are new but can't think of why they make a rubbing sound that I feel. I just need some direction as to what to do.
  2. Oct 9, 2018 at 6:39 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Any chance you are hearing the front differential cage bearing? It's most noticable as you come to a stop.
  3. Oct 9, 2018 at 6:43 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Also did you seat the new brakes?
    I’d pop my head back under there and check everything visually, make sure nothing obvious sticks out.
  4. Oct 9, 2018 at 6:44 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Backing plate or wheel bearing
  5. Oct 9, 2018 at 6:49 AM
    tacomatim74
    Tim
    I’ll have to take that in to get the front differential cage bearing checked but I don’t know if that would be it.
    A few weeks ago, I replaced pads only and that rubbing sound was intense. Three days ago, I replaced rotors but kept the same newer brakes that I just put in. That rubbing sound was gone and stopping was smooth and quiet. But after about 15 stops, the rubbing sound came back.
    And this new post came in mentioned something about seating the brakes. I have never heard of that before. Please explain that to me because I don’t think I did that.
  6. Oct 9, 2018 at 6:58 AM
    koditten
    Kirk
    Central Michigan
    Bedding the brakes is not as common these days. Pad composition really makes it unnessasary.
  7. Oct 9, 2018 at 7:11 AM
    tacomatim74
    Tim
    The brakes I purchased came with shims already attached to them. I did not use the shims that came standard with the truck. Also, I put brake lube on the back of the brakes before I inserted them into the caliper. Could that also be the issue?
    I also used the cheapest brakes and rotors that Auto Zone sells in stock. I wonder if I should've gone up a level with the brakes.
    Also, I was reading about brake and rotor bed-in and it mentioned something about brake judder. The term "brake judder" would be the best description of my issue.
    Alexely999 likes this.
  8. Jun 14, 2023 at 8:58 PM
    AndyOR
    AndyOR Member
    2021 Tacoma TRD OR
    Btf LT kit Dmz sua with 12’ locked shocks
    I know this is an old thread but were you able to ever figure out the problem to your rubbing noise? I just replaced my rotors and brake pads and now when braking at low speeds I hear a rubbing noise from the front driver side brakes.
  9. Jun 15, 2023 at 12:48 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    The last time I used the cheapest pads I could buy I was replacing the pads in about six months. Never did that again.
  10. Jun 15, 2023 at 3:34 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    When you do the brakes, it is important to remove the slide pin (for lack of a better term) that the disk housing rides on and clean it up and lubricate it. Also, clean the pistons because they will be set in deeper with the new pads and dirt and rust is a piston seal killer.
    Not doing that once cost me a new set of rotors when the brakes rode them and they warped. That mistake will never be made again.
