New brakes but still squishy pedal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Linearlynn, Jul 16, 2022.
  1. Jul 16, 2022 at 2:40 PM
    Linearlynn
    Linearlynn [OP] Member
    Hi there,
    I changed the shoes on the back of my Tacoma, the drums looked fine. I was pretty sure I adjusted them properly and afterwards the pedal was still pretty squishy.
    I then bled brakes, but I’m still getting a whole lot of squish and my E brake feels A little too easy to pull. Any thoughts?
  2. Jul 16, 2022 at 2:47 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Sounds like they aren't out far enough. Jack the axle up and Adjust them out some more until there is a slight resistance turning the wheel.
  3. Jul 16, 2022 at 2:54 PM
    Linearlynn
    Got it, that would make sense. It felt like a really tight fit when putting the drum back on. Is there a way to adjust them with the drum on?
    wilcam47 likes this.
  4. Jul 16, 2022 at 3:50 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Should be a little access hole either on the front of the drum or on the backing plate, most likely need the wheel off. I would just take the drum off. Easiest way with least amount of stress
  5. Jul 16, 2022 at 4:07 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Drum goes on loose and you snug up the brake shoes to where they light touch the drum. As you are laying under truck working the adjust, your other hand spins the wheel. At first you may hear nothing, but as you adjust the you will hear the shoe making contact with the drum. As the occurs the wheel will slow down and not spin as free. Then stop, and grab a Heineken. Repeat on the other side , ditto for Heineken.
  6. Jul 16, 2022 at 4:12 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    The adjuster is accessible from the back of the wheel thru a little window. Use a little flat head screwdriver to rotate a bit then spin the wheel.
    Brianz1001 likes this.
  7. Jul 16, 2022 at 4:20 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Alltaco is correct, adjust it in the back with the tire on. Spin tire 2 rotations adjustment done.
  8. Jul 16, 2022 at 4:26 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Make sure you go the correct direction...
    Chew and wilcam47 like this.
  9. Jul 16, 2022 at 4:34 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    How did you adjust the shoes? I've had good luck with the FSM procedure having done this 5 times on 3 Tacomas:
    (a) Provisionally install the hub nuts.
    (b) Remove the hole plug, and turn the adjuster to expand the shoe until the drum locks.
    (c) Using a screwdriver, release the adjuster 15 notches.
    (d) Install the hole plug.
    This should be done with the tire removed so you can look into the hole with a flashlight. Use two screwdrivers when backing off the adjuster 15 notches - one screwdriver to push away the little leaf spring, second screwdriver to turn the adjuster.
    AllTacosFloat likes this.
  10. Jul 16, 2022 at 5:15 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    which way, pressure up or down, when moving the star wheel inside the slot?
  11. Jul 16, 2022 at 6:15 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Also double check your bleed job,,, better yet do a full fluid change, old overheated fluid can have moisture.
    Linearlynn[OP] and kahanabob like this.
  12. Jul 16, 2022 at 6:18 PM
    AllTacosFloat
    Boston ish
    Only can go one way easily. To go the other way you have to hold the catch pin over.
    Tighten 1 tool
    Back off 2 tools
  13. Jul 16, 2022 at 7:13 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    To be honest I'm not sure usually just go one way and see if its the right way lol. I've been a mechanic for a while and for some reason can never remember:rofl:
  14. Jul 17, 2022 at 7:57 PM
    Linearlynn
    Thanks everyone. I adjusted them again and it definitely improved in pedal and braking, but still not as much as I would have liked. I’ll keep tweaking it until it feels better. First time doing shoes/drums and man is it a pain!
  15. Jul 18, 2022 at 12:25 PM
    wayne0
    wayne0 Well-Known Member
    I hate drum brakes!
    Xx_Evilvirus_xX likes this.
  16. Jul 18, 2022 at 1:43 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    And here we go
  17. Jul 18, 2022 at 1:58 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What model truck?
    OEM parts?
