New brakes/soft pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by newbtacoowner, Sep 16, 2020.
  1. Sep 16, 2020 at 1:13 PM
    newbtacoowner
    newbtacoowner [OP] Well-Known Member
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    Hello!
    I just got new pads and rotors on my tacoma and my pedal is softer than it was before... My truck still stops but I have to push further for it to stop and I haven't done any rapid deceleration yet (60 to 10, I'm hoping the shop did after the change and I'll call and confirm). Is this normal? After getting stopped, I can get my pedal to the floor with a hard push. When my truck is OFF, I can get my pedal to the floor with a light to medium push.
    Normal? Concerns?
    Thanks!
    2014 Tacoma 4x4
  2. Sep 16, 2020 at 1:16 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Sounds a little odd to me; I would expect the pedal to have less travel, if anything, as more fluid would be pushed back in to the reservoir. Have you checked the mastery cylinder? They may have removed some fluid prior to compressing the pistons in order to avoid overflow and forgotten to top it up.
  3. Sep 16, 2020 at 1:40 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    Thanks. It does feel odd. I called the shop and they said they will check it out for me... I'm at work right now. But I will check the master cylinder after work
  4. Sep 16, 2020 at 2:16 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    That wouldn't lead to a soft pedal though. I have seen posts indicating that people had to take their trucks to a Toyota dealer to have them bleed the brakes with a Toyota laptop (because of the ABS system) to cure a soft pedal.
    SR-71A and newbtacoowner[OP] like this.
  5. Sep 16, 2020 at 2:33 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    Interesting. Could it just be softer because the pads/rotors are brand new? With hard pushing, is it normal to be able to get the pedal to the floor? I never noticed I could that before but I never really tried.
    Is it normal for me to be able to get the pedal down to the floor with my engine off?
  6. Sep 16, 2020 at 2:38 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You have a major problem which could turn dangerous. You may have some air in the lines or a master cylinder going bad. I’m guessing most likely they need to bleed the lines again.
    newbtacoowner[OP] likes this.
  7. Sep 16, 2020 at 2:39 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    I mean I can definitely get stopped... It just stops with the pedal pushed in further than before the pad/rotor change so it's concerning me lol. My brakes were very very touchy before the change so this change is so different for me that I want advice. Also, I literally drove from the shop to work (6 miles) so they haven't been "broken in yet" and like I said, I hope the shop bedded them in
  8. Sep 16, 2020 at 2:40 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    Thanks! I'm bringing it back to the shop first thing tomorrow.
  9. Sep 16, 2020 at 3:23 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    I had a soft pedal ever since I bought my truck. Changed pads and calipers. Still soft.
    I drained the resivoir as much as possible. Filled it back up and started bleeding every brake until fluid ran clear.
    This firmed the pedal right up. As brake fluid gets older,it degrades and stop's being as effective
    EdgemanVA and newbtacoowner[OP] like this.
  10. Sep 16, 2020 at 3:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Also have them check and adjust the rear brake shoes. If they are not adjusted properly it will cause exactly the symptoms you are having.
  11. Sep 16, 2020 at 3:48 PM
    Too Stroked
    Tom
    Absolutely not!
  12. Sep 16, 2020 at 3:50 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Did you diy?
  13. Sep 16, 2020 at 4:08 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    No, shop did it
    wilcam47[QUOTED] likes this.
  14. Sep 16, 2020 at 4:09 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    They said they bled the lines, but I'll have them also check the rear when I bring it in
    Thank you everyone
  15. Sep 16, 2020 at 4:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    New pads can feel softer than old thin ones. They should get a little firmer after a few heat cycles.
    But if the shop flushed the system or opened up the bleeders some air may have been introduced.
    And check the rear shoe adjustment
  16. Sep 16, 2020 at 4:29 PM
    wilcam47
    Will
    Bourbon state
    With truck off you should pump the brakes and the pedal should get hard to push in a few pumps...maybe 5. It shouldnt go to floor.
    They got air in system, if it was working "normal" when you took it in
  17. Sep 16, 2020 at 4:43 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just changed my front pads and rotor a couple of weeks ago. I bled all four corners and my pedal is just as good as it was if not better. Like others have said, make sure your rear wheel cylinders are adjusted out properly and have them bleed them again. If you don't have bad parts, the soft pedal is due to too much fluid displacement (wheel cylinders) or air in the system.
    Life's too short to live with crappy brakes.
    newbtacoowner[OP] and wilcam47 like this.
  18. Sep 16, 2020 at 4:52 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    Even with pumps, it remains soft. And yea they were normal to me. Thanks!
  19. Sep 16, 2020 at 4:53 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    Thanks!!
    wilcam47 likes this.
  20. Sep 16, 2020 at 4:53 PM
    newbtacoowner
    Allison
    North Bay, CA
    2014 TRD OR DCSB
    Thanks!
    wilcam47 and b_r_o[QUOTED] like this.
