New brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomwilson74, Sep 9, 2013.
  1. Sep 9, 2013 at 4:43 PM
    tomwilson74
    tomwilson74 [OP] Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    Got my oil changed at the dealership today and they said my brakes would need replaced real soon. I have 38k on it. I didn't have to change the brakes on my Dakota till I had almost 80k. When did you guys replace the pads on yours? (front)
  2. Sep 9, 2013 at 4:49 PM
    Vincent05
    Vincent05 Well-Known Member
    Bucks County, PA
    Tacoma
    I've replaced mine twice already. Got 51k on the truck so far.
  3. Sep 9, 2013 at 5:00 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    120k on my fronts, still got some life in them, gonna replace when I break it down next. A lot of highway miles and I don't ride my brakes.
  4. Sep 9, 2013 at 5:21 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    A set of quality aftermarket pieces will outlast the OE stuff for sure. I use Hawk LTS pads and Hawk rotors. Other good brands are Powerslot, DBA, EBC etc.
  5. Sep 9, 2013 at 5:42 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I am on my third set of fronts and second set of rears at 70000. I tow regularly and drive in stop and go traffic.
  6. Sep 9, 2013 at 5:45 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I have 32k and mine are still within new pad specs. I have gone to three different dealerships to get it maintetenced and when the time comes, they have told me that they were excelent.
  7. Sep 9, 2013 at 5:53 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Depends on driving habits but 38K on the tacoma is a little low.
  8. Sep 9, 2013 at 6:31 PM
    tomwilson74
    Tom
    West Virginia
    I'm 49 years old. I drive like it too, always try to run the speed limit, easy on the gas pedal, etc. I haven't even been pulled over for almost 20 years. I normally wouldn't even think of changing them until at least 50k.
  9. Sep 9, 2013 at 10:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would say that your dealer is trying to screw you. Based on what you say are your driving habits there is no way you need brakes on a 2012 Truck with 38K.
    My last 1993 truck I sold last year with the original brake pads still on it. They were still serviceable too. I replaced the brakes on my wife's 1998 Sienna Van at 110K miles.
  10. Sep 9, 2013 at 10:49 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    WTF????
    I got 90k out of mine.
  11. Sep 9, 2013 at 11:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You must drive with your foot on the brake pedal or there is something wrong with your brake system.
    I see no other way to wear out a set of brake pads 25,500 miles.
  12. Sep 10, 2013 at 4:21 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I had 120 K on mine, and a lot of life left, that's the front. At 141 K the rears are getting close to needing replaced for the first time. Almost all inner city driving. I had to do the calipers, and used OEM pads again.
  13. Sep 10, 2013 at 9:31 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Any way you can snap a pic of the thickness of the front pads? If there is meat on them, I would cry foul..
  14. Sep 10, 2013 at 9:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I got just over 70k out of my fronts but I've replaced 2 members pads under 30k miles. The newer Tacomas seem to eat up pads for some reason, at least that's a trend I'm noticing. I've got 95k on the rears and they're still fine. I don't think I'll need to replace the rears as long as I own the truck.
  15. Sep 10, 2013 at 9:55 AM
    dantastic
    dantastic Well-Known Member
    818<->626
    2012 DCLB 4x4 BLK
    During my 25k service, my service adviser told me my pads probably wouldn't make it to my next service. He was right - I changed my pads at 28k. Strangely, the only pad that was really thin was the inboard passenger side pad (2-3mm). The inner left pad had about twice as much material left. In any case, I found a set of OEM pads on ebay for $58 shipped from a dealership.
    I am pretty hard on the brakes though (hard to break old track habits) and I do haul a lot.
  16. Sep 10, 2013 at 11:21 AM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Only way to know for sure if they need replacement is to look yourself.
    I too have replaced factory brakes at about 22K miles but not on a tacoma.
  17. Sep 10, 2013 at 7:18 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    225k and I did the rears on my '94 once.
  18. Sep 11, 2013 at 2:29 AM
    pebblin
    pebblin Active Member
    Orange County
    Indigo Ink Sport PreRunner
    I replaced mine around 120k with more stock pads. Should probably check on the rears; got almost 153k miles going and they haven't been changed.
  19. Sep 11, 2013 at 3:01 AM
    Hotwire
    Hotwire Active Member
    Raleigh
    2014 Tacoma TRD Off Road
    71,000 miles on my 2012 TRD DCSB and still on factory pads.
  20. Sep 11, 2013 at 3:03 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    59000 on my 2009 still haven't needed to replace them yet just had it inspected they said theres still about 10-15000 left on them. I had 90,000 on my 2001 before I had to change them.
