new brakes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kwackin, May 16, 2017.
  1. May 27, 2017 at 5:54 AM
    #61
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Those will look good behind those wheels
    MurkEm likes this.
  2. May 27, 2017 at 5:57 AM
    #62
    mechanicjon
    Jon
    Scottsdale Arizona
    You can make it work without it.
    The correct way is to buy the kit with the short S hard lines, metal brackets and new SS lines. Thats in the near future for mine
  3. May 27, 2017 at 5:57 AM
    #63
    MurkEm
    MurkEm Well-Known Member
    Rocky
    2002 Lunar Mist Taco DBL Cab 4x4
    Toytec Boss Lift, Total Chaos UCA, OME Dakar Leaf, FN Wheels 5-Star, Federal Couragia MT's
    I have not read anything that allows you to use your existing brake lines(im sure someone on here can chime in if im wrong). I went ahead and purchased Wheelers offroad front and rear tacoma brake lines. From what I've seen and read the banjos on the front brake lines from wheelers are just small enough to be used on the tundra calipers. I went with 13wl calipers from NAPA
  4. May 27, 2017 at 5:59 AM
    #64
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Shit. I just had new ss extended lines installed. I dont want to have to buy another set.
  5. May 27, 2017 at 6:00 AM
    #65
    mechanicjon
    Jon
    Scottsdale Arizona
  6. May 27, 2017 at 6:01 AM
    #66
    mechanicjon
    Jon
    Scottsdale Arizona
    Yours will work fine. I've been running stock lines for 6 months
    Matic[QUOTED] likes this.
  7. May 27, 2017 at 6:02 AM
    #67
    MurkEm
    Rocky
    from what company ? It wouldn't hurt to give them a try to see if it bolts up fine and no leaks... worst case scenario you'll have to just buy new front lines and sell the ones in the front you have now and buy more brake fluid.
  8. May 27, 2017 at 6:03 AM
    #68
    Matic
    Tricky Dick
    Easley, SC
    Trail gear or low range off road.
  9. May 27, 2017 at 6:04 AM
    #69
    Matic
    Tricky Dick
    Easley, SC
    So, is there another set of hardlines that are just on the calipers themself?
  10. May 27, 2017 at 6:05 AM
    #70
    Matic
    Tricky Dick
    Easley, SC
    Was heading to toyota here in about an hour and need to know what all to pick up. All i have are the wl13 calipers.
  11. May 27, 2017 at 6:06 AM
    #71
    MurkEm
    Rocky
    you dont need to use the hardlines if you used the wheelers offroad lines.
  12. May 27, 2017 at 6:06 AM
    #72
    mechanicjon
    Jon
    Scottsdale Arizona
    Ya they go from calipers to knuckle. If you look at @Timmah! s video you can see tjem.
  13. May 27, 2017 at 6:08 AM
    #73
    mechanicjon
    Jon
    Scottsdale Arizona
    I believe wheelers still uses banjo fitting. Its just thicker so you don't have to drill banjo bolt.
    MurkEm likes this.
  14. May 27, 2017 at 6:09 AM
    #74
    MurkEm
    Rocky
    if you look on page 2 post #31 on this thread you can see that @Sicyota04 just used the lines from wheelers and didnt have to use a hardline.
    Sicyota04 and Matic[QUOTED] like this.
  15. May 27, 2017 at 6:37 PM
    #75
    Mugen
    Mugen Member
    Jordan
    Temecula, CA
    2000 Xtra Cab 3.4L PreRunner TRD
    I used Wheeler's SS lines and the banjo bolts they came with bottomed out in the calipers prematurely. It was really close, like a mm too long on the drive side and maybe 2mm on the passenger. They looked like they were tight but the line could still turn freely around the bolt. I had to double up the washers with a couple of extra crush washers I had lying around from another brake job. Not ideal, and I kinda wish I had put down the extra money for the LCE hard lines.
    I've read that the Wheeler's lines work fine for some people, I think it just comes down to the casting of your particular calipers.
    MurkEm likes this.
  16. May 27, 2017 at 6:46 PM
    #76
    mechanicjon
    Jon
    Scottsdale Arizona
    The casting needs to fairly smooth and flat.
    Buck18 likes this.
  17. May 27, 2017 at 9:39 PM
    #77
    MurkEm
    Rocky
    hopefuly i dont have that problem but i guess we will soon know once EBC hurries up and get me the right damn rotor i need :mad:
  18. May 30, 2017 at 2:22 PM
    #78
    Buck18
    Buck18 Well-Known Member
    Buck
    Euharlee GA
    01 Tacoma DC 4wd Limited TRD
    881's on Billie 5100's, Dakar's and 5100's, grey wire mod, 265 75 ko2
  19. May 30, 2017 at 2:25 PM
    #79
    mechanicjon
    Jon
    Scottsdale Arizona
    They wont be any different then the stock lines as far the banjo fitting. They'll work if your casting is fairly smooth and straight were it seals. You might have to drill banjo bolt a little or use thicker copper washers.
    Buck18[QUOTED] likes this.
  20. May 30, 2017 at 2:30 PM
    #80
    Buck18
    Buck
    Euharlee GA
    When you say drill banjo bolts. What do you mean exactly? Drill the hole where the fluid passes thru?
